nextgen Samba Member
Joined: August 19, 2004 Posts: 6137 Location: CONGERS, N.Y.
Posted: Thu Nov 03, 2022 3:36 pm Post subject: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
I have been selling magnetic covers for bug louvers and have been warning customers NOT FOR A RUNNNG ENGINE. Covering my rear end in case some one forgets to take it off.
A few of the guys came up with a good question, bugs earlier then 72 did not have rear deck louvers and did not have any problems. Engines were 1600cc just like later engines. 73 was the year (may be wrong ) that had duel port heads, a bit more power.
Sure more air is better but why so many years later after the 1500 and 1600 came out. Heck of a lot of engines did not have louvers and lasted a long time. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11161 Location: Huntington Beach, CA
Posted: Thu Nov 03, 2022 3:43 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
Early convertibles had 2 openings for louvers.
1970 had 2 openings for louvers, because of the single port 1600 that was introduced.
1971 same thing.
1972 The doghouse oil cooler was introduced and thus required more air, hence 4 sets of louvers.
1973 and on - 4 sets! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2580 Location: formerly NY currently NC
Posted: Thu Nov 03, 2022 3:51 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
yes...larger fan in the doghouse setup needed more air...as well as increasing emissions controls with leaner mixtures and different advance curves causing the newer engines to run hotter...certain Cali cars even had another air inlet behind the license plate to deal with their specs....saying that earlier cars had no problems is pretty funny...countless pulled studs and dropped #3 exhaust valves proved otherwise and is the reason for first trying 2 extra louvers then finally the doghouse and 8mm studs being introduced
Posted: Thu Nov 03, 2022 3:53 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
volksworld wrote: |
yes...larger fan in the doghouse setup needed more air...as well as increasing emissions controls with leaner mixtures and different advance curves causing the newer engines to run hotter...certain Cali cars even had another air inlet behind the license plate to deal with their specs |
I think that was in 76 or 77. Funny little device! _________________ Jimbo
TDCTDI wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11081 Location: Oregon
Posted: Thu Nov 03, 2022 6:36 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
Ok. This louver, more air, doghouse fan blah, blah, blah... question comes up from time to time.
I have a 67, I know wrong forum. But my point is, I have ran my DH cooled 1679, 2180 with the decklid closed and no extra decklid louvers.
Without overheating the engine.
I even drag raced the 2180 with the decklid closed and didn't have any ill affect.
That said, I'm building a 2276 turbo. So it may now need the extra cooling air.
I have a 67 vert decklid with the 4 louver vents.
Joe, do you have the magnet covers for 2, 4 vane louvers like a 70 would have had? _________________ I have learned over the years.
Buy Once, Cry Once!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Thu Nov 03, 2022 7:02 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
Hi 67
I sure do email me (See my email address below ) and I will we can talk and give the pricing with
Free Shipping
Beetle Magnetic Deflector Shield B.M.D.S
Part Numbers:
BMDS - 1 REAR DECK LID GRILLE 1970 - Till end of production $25
BMDS - 2 FRONT WINDOW GRILLE 1968 - Till end of production $18
BMDS -3 REAR WINDOW GRILLE 1958 - Till end of production $25
BMDS -4 SHIELD KIT - ALL 3 SHIELDS 1 - 2 & 3 $45
FREE --- PRIORITY SHIPPING - FOR EACH and the 3 SHIELD KIT
Please note: Free shipping only in the U.S.A _________________ email: [email protected]
neil68 Samba Member
Joined: March 17, 2007 Posts: 3448 Location: Calgary, Canada
Posted: Fri Nov 11, 2022 4:33 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
1300 DP Beetles in Europe had the solid deck lid well into the 70’s. _________________ Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Fri Nov 11, 2022 7:05 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
Wow! Neil, thanks,
I should have added to my Disclaimer, something like. ( In different
countries there may be exceptions to years of beetles that were made with rear deck louvers ).
Actually a 1300 cc bug dual port, should run even cooler seeing that the 1600 dual port bugs, most likely put out more heat..
I have run into a bug convertible with the same over all louver area that my deck shield fits over , except it was made with out 4 louvers in the middle. The shield just covered the area were the missing 4 would have been. _________________ email: [email protected]
irvanm Samba Member
Joined: January 09, 2008 Posts: 610 Location: Lawrence, Kansas
Posted: Fri Nov 11, 2022 7:34 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
My 70 has louvers.
Cusser Samba Member
Joined: October 02, 2006 Posts: 33085 Location: Hot Arizona
Posted: Sat Nov 12, 2022 7:57 am Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
VW_Jimbo wrote: |
Early convertibles had 2 openings for louvers through 1969.
1971 same thing.
1973 and on - 4 sets! |
As stated above; and 1970 and 1971 convertibles had 4 openings, but slightly different than on the new deck lids sold these days. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun Nov 13, 2022 10:09 am Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
1300s had much thicker cylinder walls and as a result the sealing surface to the head was wider...so the setup could handle more heat without distortion issues than the 1600...1300 lived on in Europe without issue while the 1600 was basically the equivalent of putting in a slip in big bore kit to hotrod the engine to try to keep up with large cubic inch american engines on our highways...and under those conditions with our additional emission requirements they needed additional cooling to stay together |
Posted: Sun Nov 13, 2022 12:18 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
That is why I wrote THE TYPE IV UPRIGHT CONVERSION MANAUAL back in 1993
T-4's Are hardly working when pushing a light Bug. a 2.0 like mine rarely gets over 110f
BTW I just posted on my facebook site that i have over 100 Original copies of my manual and the master copy that survived an 80 story fall and fire at the Twin Towers WTC in a huge safe found after a month after the massive clean up. The safe was in then office of my printer. When he called me he said Joe you are not going to believe me. Not knowing I had printed 200 copies made with out the Spiral black binder and clear plastic Cover. Those parts were unavailable at that time. Still $29.95
bnam Samba Member
Joined: July 02, 2006 Posts: 3461 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sat Jan 13, 2024 9:28 am Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
VW_Jimbo wrote: |
1971 same thing.
Correcting for future reference
1970 and 71 Sedans 1600s (SP in ‘70 and DP in ‘71) had 2 sets of louvres.
1970 and 71 1600cc convertibles had 4 sets of louvres in 7,7,7,7 configuration. This 2 year vert deck lid had the largest opening of the German made beetles.
72-on 1600 sedans and verts switched to louvres in 7,6,6,7 configuration - 2 fewer than the previous year verts. Not sure why it was made smaller.
Unvented decklids continued till 78 for 1200 and 1300cc engine Beetles sold elsewhere. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Sat Jan 13, 2024 11:13 am Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
bnam wrote: |
VW_Jimbo wrote: |
1971 same thing.
Unvented decklids continued till 78 for 1200 and 1300cc engine Beetles sold elsewhere. |
Sorry man. I should have included the convertibles! I just did not even think of them. But glad someone included it!
And….AMAZING! I had neve, ever counted the number of louvers. Never had crossed my mind. But in thinking back, I can recall the 2 outer openings being one slit more than the inside ones. Too cool and right under my nose. I typically ask questions when I see oddities, but in this scenario, I never had!
Thanks! Love learning something new! _________________ Jimbo
TDCTDI wrote: |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1616 Location: The South Zone
Posted: Tue Jan 16, 2024 4:53 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
Quote: |
I even drag raced the 2180 with the decklid closed and didn't have any ill affect . . . |
As mentioned above, a properly built engine can run very cool, and may not "need" as much air to keep cool as a poorly designed engine needs.
That being said, the "ill effects" of an engine that is starved for air may not always be apparent under certain circumstances. It's usually only when high ambient temps are paired with high speed, long distance highway runs that you really notice a cooling problem.
Many drag racers disconnect the cooling fan completely when they make a quarter-mile run, with no problem. However, a high displacement, high RPM ACVW engine can lose a significant amount of power if it has to compete with the cooling fan in a poorly ventilated engine compartment.
Here was my solution to poor ventilation: https://www.thesamba.com/vw/forum/viewtopic.php?t=742109&highlight=
A sweet pair of ram-air cooling ducts, and say goodbye to those lame deck lid louvers! _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79500 Location: Sneaking up behind you
Posted: Tue Jan 16, 2024 6:42 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
If you have a large displacement engine and IDAs, you need air to get in.
I've seen the decklids get sucked down at WOT. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
stagewex Samba Member
Joined: November 17, 2021 Posts: 191 Location: New Rochelle, New York
Posted: Tue Jan 16, 2024 8:26 pm Post subject: Re: Bugs older then 1972 no louvers on rear deck lid 73 and up do ? |
My '73 Super:
