replacing fuel pump, suggestions on how to drain fuel tank??
bcolins
bcolins is offline
PostPosted: Sat Nov 19, 2022 9:08 am    Post subject: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
My (Edit) 1995 EVC is remotely parked, and I am replacing the fuel pump to hopefully get it driveable enough to get to my spot next to my home and pull the cylinder head off. The black rubber vibration isolator blocks on the pump assembly have begun to break down into small black bits and black goo, so, I want to drain the tank and attempt to manually clean it.
My current idea is to hand pump the 5-10 gallons of old gas into 5 gallon buckets, then take them to our local hazardous waste center in Austin.
Once empty I plan to attempt cleaning with some long rubber gloves, and possibly Acetone as my solvent if needed. T
Looking for suggestions on how to transfer the fuel from my fuel tank (the fuel pump is already removed) I have one of those red Harbor Freight hand pumps and have also seen a youtube video of a guy using a cheap suction/siphon hand squeezed pump that he says is about $4.
Just looking for any input, thoughts, suggestions.
Brian in Austin
Abscate
Abscate is offline
PostPosted: Sat Nov 19, 2022 9:18 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Pour it into another 5 gallon container though fine wire mesh then use it in another car. You can actually buy a funnel with mesh built in at your FLAPS
bcolins
bcolins is offline
PostPosted: Sat Nov 19, 2022 10:16 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
This is my 95 with the dead cylinder #3. The van had been sitting for 3-4 years when I bought it Steve,...now another year since I bought it,....I did add fuel stabilizer and another 3 gallons or so of fuel and drove it a bit,....the fuel is old, stinky, and now black from the black pump vibration dampers decomposing, So I am just going to dispose of it all and start with fresh fuel.
Brian
Saturn
Saturn is offline
PostPosted: Sat Nov 19, 2022 12:26 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
bcolins wrote:
My (Edit)
Brian in Austin
What about using a 5psi electric fuel pump? Hook that into the line going into the fuel filter and draw it out that way. Power it through the cigarette lighter or just leads to the battery. Amazon has simple pump set-ups for under $10. Not sure how long it will last if there is a lot of junk mixed in with the fuel.
Here is an example: (not a recommendation of this particular item, just showing what is out there. Amazon won't ship this particular item to California but I'm sure Texas is fine.)
https://www.amazon.com/Leadrise-Universal-Electric...amp;sr=8-1
bcolins
bcolins is offline
PostPosted: Sat Nov 19, 2022 6:35 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Saturn wrote:
bcolins wrote:
My (Edit)
Brian in Austin
interesting idea,....with the in-tank fuel pump,....is the fuel filter down stream of the fuel pump? thinking it would have to be,.....if that is the case, then there wont be fuel available at the filter location since I have removed the defective fuel pump. (???)
Saturn
Saturn is offline
PostPosted: Sat Nov 19, 2022 6:59 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
If you have the fuel pump out and direct access into the gas tank, then get several feet of carb-rated fuel hose (not FI rated) and just suck it out with the electric pump that way.
Just replaced the filter out in my 95EVC and that is something you will need to do in cleaning out your fuel system. The fuel filter is located down stream, underneath of the left side of the van and just behind the crossmember. This is the write up on replacing that out:https://www.thesamba.com/vw/forum/viewtopic.php?p=9917841#9917841
bcolins
bcolins is offline
PostPosted: Wed Nov 23, 2022 9:32 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
I ended up going with Saturnโ€™s recommendation and buying the 5- 6 psi 12 V pump. Digging around in my shed I found I had a 12 V power cord with a male plug and about 10 feet of 5/16 diameter fuel hose so it was kind of a no-brainer for under 10 bucks. worked like a champ. I did zip tie a bit of terry cloth towel around the intake and of the hose in the fuel tank to keep debris out of the pump, I plugged the pump in to my lithium ion battery bank; perfecto. Now I have cleaned out the tank, and tomorrow will be putting in the new pump and installing a new filter and fresh fuel and hopefully it will start and run.
Saturn
Saturn is offline
PostPosted: Thu Nov 24, 2022 11:04 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Nice touch with the first stage towel filter, don't think I would have thought of installing something like that to the set up. The 12V plug into the battery pack is smart addition, makes the pump more like a tool and easier to set up in the future.
With a couple other cars, I have jumped the fuel pump relay to transfer gas out of the tank in prep of it being scrapped. This has also been done this more than once while on vintage car events to help a car suffering from the vapors make it to the next filling station. This is helping get my friend's 1966 Volvo 122S get to Markleeville on the eastern side of the Sierras, its Weber carbs were a thirsty addition.
bcolins
bcolins is offline
PostPosted: Thu Nov 24, 2022 11:22 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Pics of one of my 122s back in the day
VWinny
VWinny is offline
PostPosted: Sat Nov 26, 2022 8:26 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
take it off drain it and clean it with oven cleaner to remove any ethanol deposits. Clean fuel will keep your engine running well and your pump and injectors in good condition.
bcolins
bcolins is offline
PostPosted: Sat Nov 26, 2022 9:30 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
See above to see how I drained the tank. New fuel pump and filter going in today or tomorrow.
67rustavenger
67rustavenger is online now
PostPosted: Thu May 08, 2025 12:56 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Brian,
Curious, did your fuel pump give you any warning that it was failing?
I ask because, yesterday my 2003 EV just randomly died while I was turning the van around in my driveway. It was the first time that I have any running issue since I bought the van in December 24.
The engine did restart after about 15 seconds with the key in the off position.
I didn't see any codes of failure on the dash or when I scanned the ODB with the ScanGuage II.
Lifting the rubber floor mat between the seats, I don't see any evidence of the carpet being cut to access the fuel pump for replacement. Not that, that's a clue, maybe the pump was replaced correctly by one of the PO's mechanics.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
bcolins
bcolins is offline
PostPosted: Thu May 08, 2025 6:50 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
67rustavenger wrote:
Brian,
No warning whatsoever. I was driving up Wolf Creek Pass north of Pagosa Springs Co. and as I crested the climb, the car just died. I coasted down about a half mile to a pull off, and the van would not restart. I started removing the engine cover and generally just looking around to see what might be wrong,.....and after about 15 minutes,...the van did restart. Upon restart, I did notice that I had a buzzing sound from what was likely a fuel pump.. I was able to make it to Durango after a few hours of cool down, and ordered a fuel pump at Autozone (VDO) and replaced it in the local Home Depot parking lot a few days later. All good since.
67rustavenger
PostPosted: Fri May 09, 2025 8:12 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Thank you.
I have a camping trip coming up next weekend. I'll pickup a replacement pump. just in case I need it. I'd rather be proactive than reactive.
The last thing I need to happen is getting stuck in central Oregon without a replacement pump.
Buy Once, Cry Once!
EuroTec
EuroTec is offline
PostPosted: Sat May 10, 2025 4:55 am    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
[quote="67rustavenger"]Thank you.
The last thing I need to happen is getting stuck in central Oregon without a replacement pump.[/quote
VDO pump is the best choice. More money but well worth it.
If it ain't broke, don't fix it!
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
67rustavenger
PostPosted: Sun May 11, 2025 2:50 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Well, I was forced to change the fuel pump yesterday. The only pump I could get on short notice was from AutoZone.
I already had the pump on order and was gonna just carry it on my trip next weekend, incase.
Well incase, came sooner than I really wanted it to.
Returning home from my grandsons soccer game, the engine died three blocks from my house.
I removed the passenger seat and cut the carpet as outlined above.
The e-brake lever needs to be moved out of the way to remove the fuel pump out of the tank. No big deal!
The fuel tank was drained like Brian did with an electric fuel pump I have as a spare from my drag race 67.
It took a little more than light tapping to get the tank collar loosened.
Getting the pump in the tank was easy. The tricky bit is getting the float in the correct position. I'm not sure that I have succeeded there.
When I put fuel back in the tank, 2.5gal. The dash gauge was reading 1/3 full.
So, it looks like I get to reorient the fuel tank cover in an effort to get the level float, floating freely.
Uhg, So much fun.
Eurotec, I did see your VDO recommendation. The timing of getting one here was too far out for the planned trip.
Buy Once, Cry Once!
EuroTec
EuroTec is offline
PostPosted: Sun May 11, 2025 7:24 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Getting that damned float lined up is tricky. There is ONE place it goes and works correctly. There are multiple places on the pump to mount it as well.
I messed with mine several times until I got right. Then I messed with the up and down angle of it by bending until I got it to read accurately. I calibrated it so that when the low fuel light comes on, there's about 3.5 gallons left in the tank and when its full it reads near the full mark.
Anyway, as I recall the float points towards the driver footwell far corner when it's in the proper position.
Good luck!
67rustavenger
PostPosted: Tue May 20, 2025 1:04 pm    Post subject: Re: replacing fuel pump, suggestions on how to drain fuel tank?? Reply with quote
Welp, last weekend, while traveling to our destination in central Oregon.
The engine died the same way it has been before the fuel pump was swapped out.
Pull up to an intersection and the engine just died.
Turned off the ignition and waited 30 seconds, fired it right up after the wait and it didn't happen again all weekend. Even after 6 miles of off road travel, in each direction.
I'm half tempted to reinstall the original fuel pump to get the fuel level gauge working again.
Buy Once, Cry Once!
