Wiring for rear window defroster
Newbie69
Newbie69 is offline
PostPosted: Thu Dec 08, 2022 1:33 pm    Post subject: Wiring for rear window defroster Reply with quote
I have a 08/69 beetle sedan. I'm trying to connect electrical wiring for thr rear window defroster , I can not locate the regulater? The previous owner may not have reinstalled it during their complete rewire. Hoping for help where the regulater should have been placed?
Cusser
Cusser is offline
PostPosted: Thu Dec 08, 2022 1:41 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
The switch for the defogger was under the dash near the driver. The relay was under the rear seat, driver side. For USA VWs with driver on the left....
vamram Premium Member
vamram is offline
PostPosted: Thu Dec 08, 2022 2:24 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
You need a 30A general purpose relay; it gets its power from fuse #10,at least on a '73 Super. Check the Samba technical section for the wiring diagram for your year.
Come to think of it...did '69 even have a defroster?? Think
Click to view image
Save the Supers!!
Cusser
Cusser is offline
PostPosted: Thu Dec 08, 2022 3:14 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
I think 1969 was first year of rear window defroster.
I got my 1970 sedan in 1972, and I must say that this didn't seem to work very well on mine, maybe because most trips in winter were under 30 minutes.
Newbie69
Newbie69 is offline
PostPosted: Thu Dec 08, 2022 5:05 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
From the wiring diagram which I viewed for 08/69 .there is a regulater C1 that appears to be between the generator and (relay that is under back seat). Most likely not the right way, wondering if I could just run a hot straight from the B+ generator to the relay with an inline fuse? Or tap into the starter wire that is next to the relay.
All other wires that are needed for relay and defroster switch are there.
Jimbug57
Jimbug57 is offline
PostPosted: Fri Dec 09, 2022 5:41 am    Post subject: Re: Wiring for rear window defroster Reply with quote
I would tap into the starter wire with #10 AWG and a 30 amp inline fuse. I never connect anything direct to the gen/alt.
Repeat after me "I am smarter than metal!"
sb001
sb001 is offline
PostPosted: Fri Dec 09, 2022 7:22 am    Post subject: Re: Wiring for rear window defroster Reply with quote
The voltage regulator under the rear seat has nothing to do with the rear defrost system. VW just used the B+ terminal on it as a convenient location to branch off the hot lead from the battery over to the rear defrost relay, since they are both under the back seat.
Since you have switched to an internally regulated alternator and are now missing that voltage regulator, I would just simply run a wire with an inline fuse directly from the battery + terminal over to terminal 30 on the rear defrost relay.
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
sb001
sb001 is offline
PostPosted: Fri Dec 09, 2022 7:35 am    Post subject: Re: Wiring for rear window defroster Reply with quote
Actually you should just be able to splice in to this wire since it comes over from the battery, and run a FUSED lead over to terminal 30 on the rear defrost relay. This would basically be the same thing VW did.
1600 SP engine
cletus_zuber
cletus_zuber is offline
PostPosted: Sat Dec 10, 2022 7:14 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
Read this before getting too far into it, your grid is most likely long dead.
http://www.vw-resource.com/defogger.html
HPMX 40's & 019
vwracerdave
vwracerdave is offline
PostPosted: Sat Dec 10, 2022 7:21 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
Show of hands.
Lets see how many people have a working rear window defroster.
I have never talked to anybody that does.
vamram is offline
PostPosted: Sat Dec 10, 2022 8:06 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
vwracerdave wrote:
Show of hands.
My '73 Super has a working rear defrost....an aftermarket window. I have an original rear window from a '71 that has good continuity across all the lines. Never had a car for it though, bought it before I learned '72 rear windows were slightly bigger.
Click to view image
Save the Supers!!
Cusser
Cusser is offline
PostPosted: Sun Dec 11, 2022 8:32 am    Post subject: Re: Wiring for rear window defroster Reply with quote
vwracerdave wrote:
Show of hands. Lets see how many people have a working rear window defroster. I have never talked to anybody that does.
Mine worked on my 1970, purchased in 1972. At least it did work somewhat, and that was in the 1970s. I'm in Arizona desert, so there really wasn't much reason to even try to use it.
When I resurrected that VW in 2016-2017 after its retirement in 1993 I did check for continuity on its rear window grid when I had the rear window out to replace the rubber seal, and I had no continuity by then. So I just ignored that, and re-installed it with the new seal.
I wonder if there are small-enough stick-on rear window defroster grids available......they exist for larger windows....
Multi69s
Multi69s is offline
PostPosted: Mon Dec 12, 2022 5:25 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
vwracerdave wrote:
Show of hands.
I've had 7 different VWs, and none of the rear defrosters worked.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Dec 12, 2022 5:33 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
Mine worked when new (1971), but not well since about the late 1980s.
What you see are the primer paint lines, not the actual conductive/resistive material, which likely has long since evaporated.
They were always treated gently, it was just a poor electrical/mechanical design that can't last. You'd be far better off with a small forced air heater aimed for best effect, using the same wiring and relay.
vamram is offline
PostPosted: Mon Dec 12, 2022 6:37 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
That sounds like a really good idea...any particular heater/fan in mind?
Click to view image
Save the Supers!!
madmike
madmike is offline
PostPosted: Mon Dec 12, 2022 7:23 pm    Post subject: Re: Wiring for rear window defroster Reply with quote
Good luck with that,Most all of them suck up to many Amps Crying or Very sad
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
KTPhil is offline
PostPosted: Tue Dec 13, 2022 11:22 am    Post subject: Re: Wiring for rear window defroster Reply with quote
I don't have a particular suggestion, and they are not super hot/super flow, or they take too much current. But a well-aimed air pusher, plus a little heat, might go a long way.
Maybe check the Bus forums for heater/blower suggestions, since they have well-known heater issues!
sb001
sb001 is offline
PostPosted: Tue Dec 13, 2022 11:33 am    Post subject: Re: Wiring for rear window defroster Reply with quote
KTPhil wrote:
They were always treated gently, it was just a poor electrical/mechanical design that can't last. .
What part about the original system was the main design flaw- did the system send too much current through it, did they use bad adhesive to stick the grid to the window, etc? I've always wondered if buying one of the new windows with a new defrost grid would yield better, same, or worse results
https://www2.cip1.com/vwc-111-845-501-k/
1600 SP engine
KTPhil is offline
PostPosted: Tue Dec 13, 2022 11:37 am    Post subject: Re: Wiring for rear window defroster Reply with quote
The resistive material degraded over time, even if on the shelf, I have read.
In aerospace, we do "high temperature accelerated aging tests" to predict life expectancy. Maybe VW (or their suppliers, Sekurit, Siglia?) didn't do this back then?
