Rear Seat Back
tehillah1
tehillah1 is offline
PostPosted: Sat Dec 31, 2022 11:31 am    Post subject: Rear Seat Back Reply with quote
I know that the rear seat area changed in August 1955 (1956 year model) but I haven't found any clear info on what it would take to make a later seat back work in an earlier car. I have an earlier (April/May) 1955 standard and I'm wondering if anyone has had success fitting a later oval seatback into an earlier car. Can the swivel tabs be added to a later oval back to make it work/fit? I know that Mika has these tabs but I can't tell from photos whether these would work on a later oval seat back to make the fit.
Obviously finding an early seat back is a challenge but cost is another thing all together so I'm trying to find some experienced info on what my options might be. I have the seat bottom spring/frame but the seat back was missing when I got the car.
esde
esde is offline
PostPosted: Sat Dec 31, 2022 12:24 pm    Post subject: Re: Rear Seat Back Reply with quote
I believe I have a 56/57 seat back in my pile, if so I can take a pic of it side by side with a 55 and earlier seat back.
Mika makes the seat back pivots for very early cars ( pre 48 ) but they look pretty similar to a 55 style. The main difference I see is that one of the mounting holes is a slot on the later pivot
https://restorationpanels.com/product/brackets-for-rear-backrest-pre-48/
modok wrote:
tehillah1
PostPosted: Sat Dec 31, 2022 1:44 pm    Post subject: Re: Rear Seat Back Reply with quote
Thanks for the input SD. Pics of the differences would be great. I figured someone out there had some answers in a treasure trove...
Is there a difference in the actual seat back frame? It seems that maybe the ends (where the seat pivot is) are shorter on the earlier frames in order to accommodate the brackets where the later seat back does away with the bracket, lengthening the ends a bit for direct fastening to the body...
Mika has these brackets for the later (52-55) seats:
https://restorationpanels.com/product/brackets-for-rear-backrest-1952-55/
but I don't know if these could be added to a later (56-57) seat back to make it fit properly in an early 55...
esde
esde is offline
PostPosted: Sun Jan 01, 2023 7:35 pm    Post subject: Re: Rear Seat Back Reply with quote
Here are a few pics to start. I was out in the barn collecting bits to be sandblasted tomorrow, so the seat frames were coming out anyway
51-5/8" (outside to outside) between the tabs that the pivots mount to
Stand the seat on the "legs", and 4-3/4" underneath
I'll try to remember to dig out the later seat frame tomorrow
SD
modok wrote:
tehillah1
PostPosted: Mon Jan 02, 2023 9:03 am    Post subject: Re: Rear Seat Back Reply with quote
Thanks SD. That seat back looks like it has a different bottom bar shape than the pics I've seen on the later oval seat backs and the pivot point where the tabs fasten looks different than the pivot point on later seats as well. It'll be interesting to see the difference in comparison.
Happy New Year.
Jim
esde
esde is offline
PostPosted: Mon Jan 02, 2023 7:21 pm    Post subject: Re: Rear Seat Back Reply with quote
More for you.
close enough that you could make the frame fit, somehow. But then what cover would you use? I don't think a later cover would look correct, and an early cover wouldn't fit quite right.
Laying one over the other shows it better.
Might be wise to sell the later seat back, and watch for an early frame. I see far more backs than bases for sale, can't be that hard to find.
modok wrote:
tehillah1
PostPosted: Tue Jan 03, 2023 8:32 am    Post subject: Re: Rear Seat Back Reply with quote
Thanks for taking the time to take these pics SD. This certainly shows what you're saying...probably make a later seat back fit but...
The early seat backs come up now and then but folks are way proud of them. I missed one a few years back for $200. Everything I've seen in the last couple of years are upwards of $700. There's one listed right now (been out there for over a year) for $700 that is a later back listed as an early back.
I'll just be patient and probably make a nice platform set up until I can find a correct seat back. Maybe I'll get lucky and one will turn up in a garage sale.
Again, thanks for the help!
Jim
markendee
markendee is offline
PostPosted: Thu Apr 04, 2024 4:51 pm    Post subject: Re: Rear Seat Back Reply with quote
Jim
Hi Jim,
Did you find a seat back?
Just being nosy.
Regards,
Mark.
Member # 145244
tehillah1
PostPosted: Fri Apr 05, 2024 6:39 am    Post subject: Re: Rear Seat Back Reply with quote
markendee wrote:
Hi Jim,
Did you find a seat back? Just being nosy.
Regards,
Mark.
Howdy Mark. Thanks for looking in on me. Nosy is good.
I did find a rear seat back. Had it sent over from Poland...we're an international community here on TS aren't we?
I'm not even close to the upholstery part of this project yet. I'm prepping everything I can get to in anticipation of starting my next learning curve in do-it-yourself priming and sealing as soon as the temps hold. Springtime in the Rocky Mountains...our deepest snow months tend to be March and April so by June I hope to be set up to start hosing things down in my shop.
Cheers,
Jim
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Fri Apr 05, 2024 9:10 am    Post subject: Re: Rear Seat Back Reply with quote
Doug! You are having fun!
Let me add my 2 cents. In mid 55 year (remember it was a short one) the seat back pivot points changed from the 4 bolt pivot to the 2 bolt pivot. I would need to verify with my Garwood book, but that’s what I am coming up on my own!
But beyond that……almost any seat back frame will fit! When I got my June 55 out of the cornfield back in 87, there were no back seat pieces! So, when my father decided to save gas and utilize the 73 Super Beetle for a work truck, he removed the back seat. I took it and bolted it straight into the 55! I do not remember having to change anything. I may have had the machine shop, next to Dad’s cabinet shop, fabricate 2 pivot bolts for me (I think the smooth portion was wrong, but was easily turned down to work. The seat bottom was a tight fit, but it did!
I think you could place anything in your car, from any year beyond 55, in my experience.
Good luck!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
tehillah1
PostPosted: Fri Apr 05, 2024 9:45 am    Post subject: Re: Rear Seat Back Reply with quote
Good luck!
This 'Ol 55 was a work truck for the duration of it useful life while I had it...roof racks for lumber, no rear seat back, compressor, tools, materials all stashed in the back. My wife tied a ladder to the roof racks and ran around the mountains nearby doing real estate photography. I built a rear deck platform in a 70s beetle for a friend back in the late 80s and liked the way it came out...way more useful than the pile I had in my back seat. That still might be my initial option in getting this car back on the road.
Cheers,
Jim
VW_Jimbo is offline
PostPosted: Fri Apr 05, 2024 10:29 am    Post subject: Re: Rear Seat Back Reply with quote
Good luck!
Cheers,
Jim
Yep! Same here! The old man removed the back seat and fabricated a rear “floor” in the Bug! He got a job installing custom cabinets in several high rise apartment building in LA, maybe Hollyweird, or somewhere on the West side. We would carpool into LA early in the morning. I was the carpool dummy! To the site by 6:00am. Tools out of the Bug and up to whatever floor we were on. I unboxed them, He would connect them and level them. I followed up with screwing them to the wall. He would move onto the next unit, and I would hang doors and adjust, then cut and pin the moldings up. By the time I was done with the 1st unit, he had the second one ready for me. He would then hang the moldings and clean up while I hung the doors and drawers! On the road by 3:30 to beat the traffic home! We were a great team! Made damn good money too!
Jimbo
