yellowdubmarine Samba Member
Joined: January 03, 2023 Posts: 1 Location: North Carolina
Posted: Tue Jan 03, 2023 11:17 am Post subject: looking to start VW tour bus business |
| Hey guy- Planning to start a vw tour bus business and need some advice. First off looking to use a bay window passenger bus. If I might have as many as 7 adults onboard what should I be looking for in regards to engine size and braking capacity ( i have 2 straight, rust free buses I'm considering but probably putting a new engine in). Also wondering about insurance,especially liability insurance. If anyone has any thoughts, fire away! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80189 Location: Sneaking up behind you
Posted: Tue Jan 03, 2023 11:20 am Post subject: Re: looking to start VW tour bus business |
When new they could handle a full load with the stock engine and brakes.
Upgrades, might be advisable but not mandatory. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36248 Location: Conejo Valley, CA
Posted: Tue Jan 03, 2023 11:45 am Post subject: Re: looking to start VW tour bus business |
Insurance cost/availability may be a shocker, once the insurer sees the vehicle!
For starters, you'll want 1776cc minimum, front power discs, properly-rated tires, inertial 3-point belts for all passengers, rear view camera mirror, a Blaze Cut system plus multiple fire extinguishers in the passenger compartment. Probably a higher-current alternator for electronic gizmos for you and your passengers. I'd add a step that mounts to the jack points like many campers had. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42886 Location: at the beach
Posted: Tue Jan 03, 2023 11:56 am Post subject: Re: looking to start VW tour bus business |
since it is a business, maybe you might share what type terrain you see driving in and what kind of initial cash investment you will be putting into the business.
As to power etc., the braking will be fine fully loaded unless you are going down extremely steep hills all the time. As to power, I had a 1971 with a stock 1600 once upon a time. Several times we had 6 to 7 people in it. You will do a lot a gearing down on even the slightest grades. There is a reason that in the 1970's an 80's etc all the churches and civic groups used big American vans for people transportation. Look at what Airport shuttles are using around town. Same thing. Buses were made in a time when people didn't mind not having AC and going slow.
As to insurance, best to ask your agent. He/she is licensed to offer quotes and recommendations in NC or that area. I was a licensed agent in CA for years, and would not even suggest the answer to that question because it will be complex. All you need is some meth crazed contractor driving a coal truck to rear end you fully loaded, saying it was your fault because you were a slow hazard on the road. I can't begin to imagine how many attorneys it would take to straighten that one out. I have seen first hand how those trucks drive in TN, KY, W VA , and NC. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
metahacker Samba Member
Posted: Tue Jan 03, 2023 12:09 pm Post subject: Re: looking to start VW tour bus business |
If you are asking about making a significant upfront investment in order to provide the lowest maintenance, highest reliability and maximum performance/ enjoyment... this would be my personal approach, below.
Perhaps not everyone's cup of tea... but after daily driving Buses, this is how I feel..... try and change my mind, if you want :)
Transmission:
AT: 010 with Lubegard ATF (preferable)
MT: 091 (or 002, depending on chassis/engine) with Amsoil + Lubegard MT supplement
Lobro CVs, Tiguan boots, NEO HPCC#1 calcium grease
Final drive R&P ratio swap so that the RPMs are where they should be for the choice of engine. Stock final drive if air cooled (no "freeway flyers", please, "Pyramid" gearing would be OK with shorter 4th and slightly taller FD).
Engine: Subaru EZ30D JDM swap or USDM Subaru EJ25 (both retaining stock ECU)
or if you want to keep it VW, Type 4 with hydraulic lifters and freshened up Jetronic bits and wideband tuned AFM + 123 BT distributor
or, the total opposite end of the spectrum a simple Type 1 like a 1600, 1776 or (my recommendation, if you go this route) the "no machine 1800" 74 x 88 thick wall (e.g. https://www.aircooled.net/1800cc-vw-engine-no-machine-combo/ )... running something simple like a PICT carb, or Kadrons... and a SVDA... since you're going to be doing valve adjustments regularly. I'd personally want EFI (the DubShop, LowBugget, VWSpeedShop UK or a Holley Carter AFB hack) and/or the 123 Bluetooth distributor and a German Porsche 6cyl red 1.5ohm coil. At least then you're only doing valve adjustments and the engine will keep itself in perfect tune.
Fellows UK radiator + heater core/blower for Suabru
Otherwise, Propex or modern euro petrol heater for air cooled VW engines (no heater boxes, please.. your engine and customers will thank you, particularly a 2.0L T4) .. and no Chinese diesel heater for professional business use IMO
Oil system plumbed for updated Frantz oil filter https://www.toiletpaperoilfilter.com, running Redline 20W50 motorcycle Ester based synthetic and a spin-on Amsoil EA series filter like EA42
Denso Iridium spark plugs and Magnecor wires (where applicable)
Goodridge Stainless brake lines
WagensWest Wilwood front caliper kit, Polymatrix-Q (ceramic) pads
GoWesty Vanagon rear disc kit (requires minor modification - although a Bus version is supposed to be out R.S.N.), substitute Brembo ceramic pads
Stock front rotors (Brembo or Zimmerman) and rear GW rotors, all cryo treated and CNC slotted by FrozenRotors.com
Castrol SRF or LMA brake fluid
New Ball joints from Rare Parts Taiwan (or Lemforders that you grease yourself and spin with a drill)
New tie rods/ drag link
New center pin
Bilstein or Fox shocks
EMPI sway bars, front & rear
Koni 76-1099 steering damper, set to softest
Wolfsburg West "green" rear torsion bars
Rear spring plates indexed with the slightest upwards rake
Steering box flushed, refilled with 50/50 SuperLube grease & gear oil and adjusted (ideally a Late bay box, swapping T2a->T2b on this part isn't that painful - one bolt hole stays)
You may also want to consider a dual-zone A/C system (e.g. rear evaporator) from Gilmore, specifically requesting the Sanden 7-piston over the standard 5 piston, and dual condensers. For Subaru, I would use a Denso 10-piston like stock on Subarus.
You may also consider the CruiseNComfort 12V A/C syste (which will necessitate an aftermarket alternator of significant output - easy with a Subaru... for example, the DC Power Inc. 270A)
Unless you go with the T1 engine approach...
neither the Subarus nor hydraulic/Jetronic/123 Type IV ACVW engine would require anything much in terms of maintenance....
simply change the roll of toilet paper every ~3K miles and top off the oil...and change the Amsoil Ea full flow every ~25K
Theoretically, you should be able to drive ~100K miles without doing anything other than the oil filter changes and chassis lubrication.
That said, a stock Bus was built to do exactly what you want. Even a Bus with a 1500, points and non-boosted 4 wheel drum brakes is technically supposed to do what you're asking. Whether it's going to be the most practical to operate from a business owner perspective, or whether your passengers will appreciate the nuances of specific challenges such as interior climate control and hill climbs.... I'd think only the former would be a real issue.
If you're OK with lots of tinkering, and the passion of hands-on work on your air-cooled Volkswagens is part of why you want to do this, you should just run them 100% stock with the best quality parts you can get. |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3235 Location: South Benfleet, Essex, UK
Posted: Fri Jan 13, 2023 12:46 pm Post subject: Re: looking to start VW tour bus business |
| yellowdubmarine wrote: |
Keep in mind that the weights of average male & female human adults in the USA and elsewhere have probably increased substantially since the 1970s, so you might want to weigh your SEVEN passengers to ensure that they, the driver & luggage collectively, do not exceed the vehicle's maximum payload of circa 1,000 kg; corresponding to an absolute maximum average occupant weight of 112•5 kg (n.b. 1 kg = 2•204 lbs). I was extremely shocked & disgusted by the CDC statistics, given at the following link!!!
https://www.cdc.gov/nchs/fastats/body-measurements...3A%20199.8
https://brandongaille.com/list-average-human-weight-by-country-and-american-states/
It would also be wise to provide proper lap & diagonal seat belts plus head restraints for all occupants.
https://www.thesamba.com/vw/forum/viewtopic.php?t=262433
Several years ago, I advised Kombi Nation in Uganda about safety issues re seat belts and head restraints pertaining to these vehicles, but regulations and attitudes to safety are much more lax in SECOND-WORLD & THIRD-WORLD countries!
https://kombitours.com
As at 2017, approximately 4% of Ugandan roads were paved.
https://en.wikipedia.org/wiki/Transport_in_Uganda
https://en.wikipedia.org/wiki/List_of_roads_in_Uganda
https://borgenproject.org/road-infrastructure-in-u...0in%20East
Some typical Ugandan roads, off the main routes.
_________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22681 Location: Escondido CA
Posted: Sat Jan 14, 2023 10:58 am Post subject: Re: looking to start VW tour bus business |
Convert them both to Subaru Engines. Or be doomed to find VW parts and or mechanics to work on them.  _________________
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
nemobuscaptain Samba Member
Posted: Sat Jan 14, 2023 11:06 am Post subject: Re: looking to start VW tour bus business |
You're going to need several spare busses and you better quickly learn to be your own mechanic. The availability of parts is sporadic and the quality of parts is... well... absolute shit.
I agree that a modern engine is a must if you are planning on running it hard every day.
Blazecut is a joke. I was a firefighter. It won't put out anything but the tiniest of fires. Even fullsize fire extinguishers won't touch a real engine fire especially if that gravity fed fuel tank is dumping all its contents. Once the fuel tank started dumping gas, you better have one or two large charged lines from the fire engine. You still may be getting your fire helmet faceshield melted. There are several other things you should do with that money to ensure fire safety first, namely improve the fuel hoses or maybe lines and the sort of things all other vehicles now have (electric ignition-controlled fuel cutoffs, antibackflow valves on the return line, etc).
Or a Sprinter, Transit or that Dodge/Fiat van that has a "groovy" hippy paint job or wrap?
Almost any flatnosed van is viewed by the public as a VW anyway. People actually think the Scooby Doo Mystery Machine was a VW despite the radiator steam often present and engine in the front. And the 60s model Dodge, Ford and Chevies are much less expensive, already water cooled.
Imported Mitsubishi Delica or Toyota Hiace? Over 25 year old vehicles can be imported. However, we cant newer import third world vehicles (newer Brazilian VW Busses) like the minions of the Queen can in UK.
Good luck. Are you SURE you don't want a cool Sprinter or something? You will soon. Look at the fleet of "peace vans" the rental company and others. They just have the occasional VW as the eye candy prop. _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
Last edited by nemobuscaptain on Sat Jan 14, 2023 11:38 am; edited 7 times in total |
4118thing Samba Member
Posted: Sun Jan 15, 2023 9:36 am Post subject: Re: looking to start VW tour bus business |
Where in NC? |
