Inner rocker details
sgellis
sgellis is offline
PostPosted: Thu Jan 26, 2023 10:31 am    Post subject: Inner rocker details Reply with quote
I am looking for some info on the inner rocker panels for my 54.
Did they have notches in the top flange that lined up with floor drain holes? If so did both side get them? I cant find any NOS photos.
Was the inner rocker profile the same as later splits?
Were there any drain holes in the inner rocker?
Thanks
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
RockStock
RockStock is offline
PostPosted: Fri Jan 27, 2023 2:49 pm    Post subject: Re: Inner rocker details Reply with quote
Rarely photographed area, especially on a solid bus
There’s a couple of reference pictures on David’s thread that may be useful (solid 52 Deluxe, shortside sill)
See pages 1 & 2
https://www.thesamba.com/vw/forum/viewtopic.php?t=674670
-StockRocks-
sgellis
sgellis is offline
PostPosted: Sat Jan 28, 2023 5:51 am    Post subject: Re: Inner rocker details Reply with quote
I looked at those and couldn't see any notches. But it is a 52... It seems the drain holes were drilled after the floor was installed as they are not even. My 54 looks like the holes were punched. Three holes still exist. Unfortunately the inner rocker flange has dissolved at those hole.
sgellis
sgellis is offline
PostPosted: Sat Jan 28, 2023 10:55 am    Post subject: Re: Inner rocker details Reply with quote
I was going through my pile of rust and inspecting everything and found this. A cargo floor drain hole that shows it was drilled after floor install.
This is why I never throw anything out. Smile
So no notches.
Seams there should be a drain hole somewhere on the long side rocker though. Doesn't appear there was any on the outside...
sled
sled is offline
PostPosted: Wed Feb 01, 2023 7:47 pm    Post subject: Re: Inner rocker details Reply with quote
there is a hole on the outside rocker at the forward end, to act as a drain for the B pillar and ingress from semaphore opening. Hole is about 3/16"-1/4" in diameter and centered in the B pillar.
Inner rocker has two holes at each end, approx 7/16" on center from ends. Also approx 1/4" diameter. (both cargo and drivers side)
drive your split.
sgellis
sgellis is offline
PostPosted: Fri Feb 03, 2023 9:01 am    Post subject: Re: Inner rocker details Reply with quote
I see those on later buses but didn't think they overlapped with the outer pillar holes. I had assumed the change was post barndoor.
