'66-'67 vs Earlier Steering Column Common Parts
Gary E 21
Gary E 21 is offline
PostPosted: Thu Mar 02, 2023 3:02 pm    Post subject: '66-'67 vs Earlier Steering Column Common Parts Reply with quote
I wasn't able to find parts lists for each for comparison.
Are there any parts in common between the '66-'67 to earlier years? ie, column tube, shaft, etc.
I know the turn signal mechanism is different, but what about the rest of it?
mukluk
mukluk is offline
PostPosted: Thu Mar 02, 2023 10:06 pm    Post subject: Re: '66-'67 vs Earlier Steering Column Common Parts Reply with quote
http://www.oacdp.org/type1part.html#f4
Gary E 21
PostPosted: Sat Mar 04, 2023 5:24 am    Post subject: Re: '66-'67 vs Earlier Steering Column Common Parts Reply with quote
Got it. Thanks a ton. Yu da man!
EVfun Premium Member
EVfun is offline
PostPosted: Sat Mar 04, 2023 10:48 pm    Post subject: Re: '66-'67 vs Earlier Steering Column Common Parts Reply with quote
My understanding is that '62-'67 use the same steering column assembly, the steering wheel itself did change but are interchangeable. The color also changed to black, I think in '66. The older '60-'61 steering column is very similar looking, but lots of parts inside are different.
Wildthings wrote:
