ggolds5 Samba Member
Joined: April 12, 2022 Posts: 135 Location: Farmington, CT
Posted: Sun Mar 05, 2023 9:29 pm Post subject: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
I'm sure this has been covered in here somewhere. Can anyone tell me if there is any reason a Vanagon kitchen unit cannot go into a Bay window Bus, specially a 76. I've given up on finding a kitchen unit from a Bay. They are never in good shape. I have found a few good Vanagon units. SO, will it fit without issue?. Thanks. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15351 Location: Syracuse, NY
Posted: Mon Mar 06, 2023 2:20 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
with a little bit of work
from this member's post
Andre4 wrote: |
I did this with my 78 passenger van. I found a 76 Westfalia at the wrecker with no sink/stove cabinet and bought an early vanagon sink/stove cabinet from another wrecker. I removed the icebox from the icebox cabinet in the 70s stuff then had to shorten that whole cabinet 1 1/4" I re-laminated the vanagon unit and here's the (sort of) end result:
It was a lot of work and there's still a lot to do but I'm in love with my van now, I guess if you put that much time and energy into something it's bound to happen. |
Abscate wrote: |
Posted: Mon Mar 06, 2023 3:50 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
danfromsyr wrote: |
Andre4 wrote: |
This is exactly what I need to do , just the sink stove unit , so I guess it works. Was the sink stove unit easy to put in, or were there modifications you had to make. I just want to put the 2 bottles underneath. One for sink drain and the other for fresh water. Then attach a small propane bottle to the stove , not attach it to the underneath since there isn't a propane system installed in the Bus. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42514 Location: at the beach
Posted: Mon Mar 06, 2023 3:55 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
It says in the text there were modifications needed, and he had to re-laminate it when done. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Mon Mar 06, 2023 3:58 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
SGKent wrote: |
It says in the text there were modifications needed, and he had to re-laminate it when done. |
I just wasn't sure if he had to shorten the lower icebox unit, I think that is what he meant. I'm assuming the Sink stove unit for the Vanagon unit is 1.5 inches wider from what he's saying. I wonder what the dimensions are on the Bay Window unit as far as width. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52775 Location: Surrey B.C. Canada, but thinking of Ukraine
my59 Samba Member
Joined: August 13, 2003 Posts: 3973 Location: connecting the dots
Posted: Mon Mar 06, 2023 4:17 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
Propane is heavier than air, which is why you keep it outside. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3312 Location: Hamble, Hampshire, UK
Posted: Tue Mar 07, 2023 2:02 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
my59 wrote: |
Propane is heavier than air, which is why you keep it outside. |
But unless your sliding door is amazingly well sealed, the propane runs across the floor and then outside.. As implemented by Devon Conversions over here in the UK, my gas bottles are fairly well ventilated in the hinged, demountable cooker unit beside the sliding door. Its not something that has worried me over the last 13 years.
VW camper vans are not like boats that fill up properly with various hydrocarbons. _________________ Ancient vehicles and vessels
The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 846 Location: Arizona
Posted: Tue Mar 07, 2023 8:05 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
It takes a long time to find Westfalia cabinets, and most likely you will have to build from many sources. It took me two years, and by using the “ alert” ad function in the Samba I finally found ALL of what I needed to rebuild a nice stock kitchen for my 76. In almost all cases, you will need to remove cracked and chipped laminate and replace. The nice kitchen cabinet in this thread required a LOT of work to carefully measure and replace the Vanagon laminate with period correct laminate to go with his ‘78. Either way, you are looking at becoming at least a journeyman carpenter to do either! Unless…. You have a buddy that is a cabinet maker. Not trying to discourage you, but I wish somebody had cautioned me on how much work it is. In my case, glad I took the time… and thanks to Eche bus for his fantastic restoration threads here! Bob _________________ 1964 vert "Patience"
2002 Eurovan MV “Winnie”
Sold the 63 vert “ Lizzie”
Sold the 76 Westfalia “ Winnie” |
Posted: Tue Mar 07, 2023 8:55 pm Post subject: Re: Sink/Stove/Fridge unit from a Vanagon into a Bay Window. |
The Volkswagen Ranch wrote: |
It takes a long time to find Westfalia cabinets, and most likely you will have to build from many sources. It took me two years, and by using the “ alert” ad function in the Samba I finally found ALL of what I needed to rebuild a nice stock kitchen for my 76. In almost all cases, you will need to remove cracked and chipped laminate and replace. The nice kitchen cabinet in this thread required a LOT of work to carefully measure and replace the Vanagon laminate with period correct laminate to go with his ‘78. Either way, you are looking at becoming at least a journeyman carpenter to do either! Unless…. You have a buddy that is a cabinet maker. Not trying to discourage you, but I wish somebody had cautioned me on how much work it is. In my case, glad I took the time… and thanks to Eche bus for his fantastic restoration threads here! Bob |
Well: I found a rear closet with mirror in upstate NY. Drove from CT. about 5 hours during sleet and fog to pick it up from a guy on here at a Walmart. Spent this past week restoring it. Now looks great. Found a headbanger at Way-out Salvage in Arkansas. He shipped it. Cost almost as much to ship as to buy it. Derrick and Barb were great!!. Just restored that and now both cabinets are ready to install. I just need a kitchen unit now. Like I said, a Vanagon unit would be fine. Found a NEW old stock unit on here but very expensive and shipping, probably will make that unit a no go. $1100 for the unit and likely 3-400 for shipping. The 2 cabinets I just purchased ran about 900 to get them. So that kitchen unit just is more then I can afford, but perhaps might be my best option. Id rather find a Bus unit, but those are in awful shape always, and I did find a Vanagon unit from a guy in Rhode Island on here but he isn't getting back to me no matter how much I've attempted to reach him. (Slow Rhode). I hope he's just away on vacation or something and not sick or something. I always think of that. Anyway, hoping to get a kitchen unit SOON. Thanks for writing. |
