Beetle doesn’t run very well
459032 is offline
PostPosted: Thu Mar 16, 2023 7:34 pm    Post subject: Beetle doesn’t run very well Reply with quote
Just bought it. Got it running. Addressed vacuum leaks and it ran better but not great.
Just did a compression test on cylinders one and two
1) 40 psi
2) 110 psi
3) 100 psi
4) 110 psi
What to do from here? Rebuild? Or check valves?
edit: remaining cylinder compression
Cusser
Cusser is offline
PostPosted: Thu Mar 16, 2023 7:54 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
1) 40 psi
2) 110 psi
FOR SURE: adjust the valves to 0.006" when stone cold.
459032
459032 is offline
PostPosted: Thu Mar 16, 2023 9:21 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Where do you recommend getting rebuild parts or kits?
Nicholas D Premium Member
Nicholas D is offline
PostPosted: Fri Mar 17, 2023 4:39 am    Post subject: Re: Beetle doesn’t run very well Reply with quote
If you take Cusser's advice, which I personally think you should, you don't need any type of rebuild kit. Only thing you should get would be valve cover gaskets. Cip1, Wolfsburg West or any other VW parts supplier will have them. The link to the thread below is in the stickies. Some of the information may be a little old but there are tons of threads on here about parts suppliers.
https://www.thesamba.com/vw/forum/viewtopic.php?t=523195
71 Westfalia
73 Beetle
radstude
radstude is offline
PostPosted: Fri Mar 17, 2023 6:21 am    Post subject: Re: Beetle doesn’t run very well Reply with quote
May be a Valve sticking.
1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i
Cusser
Cusser is offline
PostPosted: Fri Mar 17, 2023 6:43 am    Post subject: Re: Beetle doesn’t run very well Reply with quote
Cusser wrote:
1) 40 psi
2) 110 psi
After valve re-adjustment, re-do compression test.
459032
459032 is offline
PostPosted: Fri Mar 17, 2023 12:28 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Assuming it’s a sticky valve, how is that fixed? Is that fixed either the valve adjustment?
459032
459032 is offline
PostPosted: Fri Mar 17, 2023 6:06 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Took off the valve cover. One of the rocker arms is not seated on the push rod.
Cusser
Cusser is offline
PostPosted: Fri Mar 17, 2023 6:56 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
That will affect compression and performance !!!
459032
459032 is offline
PostPosted: Fri Mar 17, 2023 7:03 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Do I just pop it back in? Why would the rocker arm come off the push rod?
gt1953
gt1953 is offline
PostPosted: Fri Mar 17, 2023 7:54 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Bent push rod maybe. Loose valve adjustment.
72 type 1
72 Squareback
459032
459032 is offline
PostPosted: Fri Mar 17, 2023 8:08 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Push rod was a little bent. I straightened it and now this car runs great! Y’all are awesome!
gt1953
gt1953 is offline
PostPosted: Sat Mar 18, 2023 7:20 am    Post subject: Re: Beetle doesn’t run very well Reply with quote
Source outa replace stockpushrod as it may even bend again.
72 type 1
72 Squareback
Cusser
Cusser is offline
PostPosted: Sat Mar 18, 2023 8:45 am    Post subject: Re: Beetle doesn’t run very well Reply with quote
Replace that "straightened" pushrod or risk consequences !!! It bent for a reason, and "straightened" won't stay straight !!!
459032
459032 is offline
PostPosted: Sat Mar 18, 2023 1:39 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Will do. Are all 1600’s or type 1’s the same length push rod?
A couple more questions:
Cold it’s hard to start. Hitting the throttle causes it to stumble. When warm starts right up and runs pretty good. A little bit of a shake cause by misfire
High idle. I advanced the timing which causes a high idle.
My plan is to re adjust valves and do a general tune up.
Cusser
Cusser is offline
PostPosted: Sat Mar 18, 2023 2:01 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
No, not all Type 1 use same - they've been making Type 1 for sale since 1946 !! Their early 1100cc and 1200cc engines were quite different !!!
All 1600cc engines for the US had same pushrods, and 1500cc were the same ones as well.
No one here will yell if you just buy a single new push rod.
459032
459032 is offline
PostPosted: Sat Mar 18, 2023 3:01 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
I’m also in hot AZ. Where do you recommend getting a push rod
jinx758
jinx758 is offline
PostPosted: Sat Mar 18, 2023 4:11 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
Howdy ...
Congrats on fixing vacuum leaks & getting it to run.
Now focus on getting it to run as best as it can.
Cold start :
Ensure choke is not only set correctly but fully opens after about 3-4 minutes.
If PICT (?) carburetor set fast idle cam screw so it JUST barely touches stepped cam plus 1/4 turn & leave it. Best done stone cold. Also fuel/air & rpm settings.
Too much timing can cause a hard start & is not good for cruising. We don't drive at an idle.
Tune up :
Scrape ALL ignition surfaces - cap, rotor, & make sure everything is fully seated.
I do this once a year to eliminate potential problems.
Shaky idle :
Performance cam
Throttle shafts on carb leaking (can't really tune it)
Plug wire problems (not seated or shorted)
Sticking fuel pump rod (took me a while to find that one)
Spark plug fouled
Low compression on one or more cylinders
Vapor lock (full or partial) keep fuel lines & hoses away from heat sources
It's better to try & eliminate "what ifs" in the driveway.
Good luck ... stay safe
jinx
PS ...
Please post distributor, carb, & etc.
Lots of knowledgeable people with sharp eyes can spot problems if we had some pics. Thanks
You got this !
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
459032
459032 is offline
PostPosted: Sat Mar 18, 2023 4:49 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
This is fuel injection. I va plan on keeping it that way
459032
459032 is offline
PostPosted: Sat Mar 18, 2023 9:19 pm    Post subject: Re: Beetle doesn’t run very well Reply with quote
I apologize for not specifying earlier. I need to remember to put that on my signature.
Great write up. Thank you.
1978 beetle convertible With fuel injection. I believe everything is stock. Not sure.
