Aftermarket tank
Cptn. Calzone
Cptn. Calzone is offline
PostPosted: Mon Mar 20, 2023 4:01 pm    Post subject: Aftermarket tank Reply with quote
Std tank was full of junk so we got a Dansk.Fits good however the fuel vent bung is much larger 15mm/vs 9 mm of stocker Any suggestions without a Frankenstien solution
71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Wed Mar 22, 2023 9:06 am    Post subject: Re: aftermarket tank Reply with quote
show us a picture of to what you are referring, there is a late and an early tank
allaircooled
allaircooled is offline
PostPosted: Sat Mar 25, 2023 6:52 pm    Post subject: Re: aftermarket tank Reply with quote
I had the same issue with my replacement tank. I just found a plastic reducer, so a short piece of house that is the larger diameter, to the reducer, than the smaller diameter hose to the expansion tank.
Cptn. Calzone
PostPosted: Mon Mar 27, 2023 5:12 pm    Post subject: Re: aftermarket tank Reply with quote
any chance of the source for the reducer?
71 westfalia
Starbucket
Starbucket is offline
PostPosted: Tue Mar 28, 2023 4:56 pm    Post subject: Re: aftermarket tank Reply with quote
Ace Hardware.
Cptn. Calzone
PostPosted: Sun Apr 02, 2023 5:38 pm    Post subject: Re: Aftermarket tank Reply with quote
plastic or cpvc or neoprene? Def need this to move foward
71 westfalia
Starbucket
PostPosted: Sun Apr 02, 2023 6:30 pm    Post subject: Re: Aftermarket tank Reply with quote
Ace has plastic or brass.
allaircooled
PostPosted: Tue Apr 11, 2023 8:11 pm    Post subject: Re: Aftermarket tank Reply with quote
Sorry it took so long for me to get back to you. I'm away from home for up to 6 weeks at a time and I have a lot of family time to catch up with.
Anyways all I did was use a brass hose reducer. If you google brass hose reducer you will see what I am talking about. Just need the size of the hoses you are using.
'75 Porsche 911
Cptn. Calzone
PostPosted: Wed Apr 12, 2023 3:42 am    Post subject: Re: Aftermarket tank Reply with quote
thank you
71 westfalia
