Speed of Air pistons
PatJr
PatJr is offline
PostPosted: Mon Sep 11, 2023 10:08 am    Post subject: Speed of Air pistons Reply with quote
anyone seen these?
https://s19529.pcdn.co/wp-content/uploads/2021/05/3516diesel.jpg
pistons with golf ball dimples ?
1970 Transporter a orange one
SGKent Premium Member
SGKent is offline
PostPosted: Mon Sep 11, 2023 10:49 am    Post subject: Re: Speed of Air pistons Reply with quote
never seen it. Only thing I can think is that it increases surface area of the piston and conducts away heat. It may also cause more air mixing, which would reduce unburned HC. My instinct tells me there is no measurable gain in performance. It may increase efficiency slightly and reduce CO just like Honda did by introducing turbulence into their engines with 3 valves. Besides, the world is going to EV and these engines will all be obsolete in a few years. Your kids will ask, daddy, what was it like to drive a car powered by gasoline or diesel?
In diesels https://www.motortrend.com/news/golf-ball-dimple-diesel-piston-engine-technology/
George Carlin:
Skills@EuroCarsPlus:
TXHCBeetle
TXHCBeetle is offline
PostPosted: Tue May 07, 2024 4:41 pm    Post subject: Re: Speed of Air pistons Reply with quote
You probably would have gotten a lot more replies if you posted this in the performance/engines/transmissions forum.
Icon pistons offers a Speed of Air upgrade, you can see dimpled T1 pistons on page 4:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=60
In Progress:
1958 Beetle Sedan - L243 Diamond Gray
1967 Beetle Sedan - L456 Ruby Red
Wildthings
Wildthings is offline
PostPosted: Wed May 08, 2024 3:20 am    Post subject: Re: Speed of Air pistons Reply with quote
One article refers to a light truck, which is what an F350 pickup is as a heavy duty diesel and another claims a 15% increase in power which I would say it likely BS. As for aircooled engines, I think it is possible that dimples might lead to cooler running pistons and if it worked for the piston, it should do the same for the heads.
Cooler pistons and heads could mean more resistance to knock, which would allow for the use of higher compression, which would increase power and mileage a bit.
It would certainly be easy to build an engine with two stock pistons and two identical pistons that have been dimpled and compare the head and exhaust temps, maybe tightening the deck a bit on the dimpled pistons to keep the compression the same.
aeromech
aeromech is offline
PostPosted: Thu May 09, 2024 7:59 am    Post subject: Re: Speed of Air pistons Reply with quote
Interesting bit of trivia.
My university physics teacher invented those dimples in golf balls. Made the ball go further. The PGA outlawed them for tournament play. My instructor sued and won a million dollars.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
NASkeet
NASkeet is offline
PostPosted: Thu May 09, 2024 12:29 pm    Post subject: Re: Speed of Air pistons Reply with quote
I think the purpose of the golf-balls' dimples, was to trigger turbulent-flow, so that flow-separation occurred much further around the ball, and hence reduce drag. I think this is also the reason why aircraft wings have, or at least had, small fences on the wing surface.
https://www.livescience.com/32446-why-do-golf-balls-have-dimples.html
https://en.wikipedia.org/wiki/Wing_fence
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
NASkeet
NASkeet is offline
PostPosted: Thu May 09, 2024 12:35 pm    Post subject: Re: Speed of Air pistons Reply with quote
If I am not mistaken, purpose-built electric vehicles simply have a forward & reverse selector, rather like the Van Doorne variomatic transmission on my father's 850 cc DAF 44. If driving-school cars in the United Kingdom adopt such purpose-built electric vehicles, driving-test candidates will ONLY qualify to drive cars with automatic transmission! Most diesel and petrol engined vehicles in the United Kingdom have manual transmission
Regards.
Nigel A. Skeet
raygreenwood
raygreenwood is offline
PostPosted: Thu May 09, 2024 1:40 pm    Post subject: Re: Speed of Air pistons Reply with quote
Not quite on the wing fences. But they do work with the boundary layer air.
The dimples on the ball...yes...correct...they create uniform micro vortices which create a boundary layer around the ball reducing drag.
Nice explanation:
https://www.scientificamerican.com/article/how-do-dimples-in-golf-ba/
The wing fences (boundary layer fences) do exactly what they look like. Because of the sometimes not so sophisticated wing chord shape in the early jet days...coupled with a sweep back angle that is not always ideal, there was a tendency for the airflow that is going over the wing to slide sideways toward the wing tip, dumping lift. The wing fences literally halt this flow and force the air to move rearward over the top of the wing the way this air is supposed to go.
This mainly is an issue as airspeed drops toward the stall point and the nose angle has to pitch up. That lateral air movement loss along the wing can cause the plane to stall early.
https://en.wikipedia.org/wiki/Wing_fence#:~:text=B...%20energy.
Ray
jlrftype7
jlrftype7 is offline
PostPosted: Fri May 10, 2024 12:37 pm    Post subject: Re: Speed of Air pistons Reply with quote
Metric Mechanic was offering those on their BMW engines years ago if I remember correctly. I doubt I still have their literature from the early '90s on their offerings of BMW engine performance upgrades.
I just checked their website, they don't seem to mention or offer that service anymore. They're doing things differently to the older BMW engines these days. No idea when they stopped offering the 'dimples'.. Think Think
‘84 Tin Top - Hilga....Auto
