hdaiken Samba Member
Posted: Sun Oct 29, 2023 1:10 pm Post subject: 1974 Ghia Vacuum advance distributor won't advance |
My '74 Ghia (engine code AH) single vac hose distributor is stuck (won't advance) and timed at about 30 degrees BTDC for all engine speeds. If I pull a vacuum on the vac advance hose, I can make the advance mechanism move sluggishly but there's too much friction for the spring to return it to position. It runs pretty decently with the fixed advance, but I assume I need to fix this. Is it possible to clean it well enough to restore operability or should I look for a replacement? The distributor VW part number is 113 905 205 M which I don't see in my manual but I assume it's the original (owned the car for the last 40 years or so). Would a cheap Bosch 009 distributor be adequate or do I need to spend more on this? Thanks for your help in advance. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3322 Location: Hamble, Hampshire, UK
Posted: Sun Oct 29, 2023 1:38 pm Post subject: Re: 1974 Ghia Vacuum advance distributor won't advance |
First, dont replace with an 009 , replace with an SVDA will be best.
It is possible to strip down the distributor, especially the moving plate and clean it up, although probably simply lubricating it with some sewing machine oil or engine oil may soften the grease and reduce friction .. _________________ Ancient vehicles and vessels
frenchroast Samba Member
Posted: Sun Oct 29, 2023 2:14 pm Post subject: Re: 1974 Ghia Vacuum advance distributor won't advance |
Pretty sure a 205M is an SVA for an earlier motor than a '74. What carb do you have (i.e., 34PICT3)? You will probably need and 034 SVDA. Don't put an 009 on; the correct dist for your carb will run so much better. |
Posted: Mon Oct 30, 2023 6:56 am Post subject: Re: 1974 Ghia Vacuum advance distributor won't advance |
Thanks for the replies. The carb on it now is a generic 34 pict 3; prior to that, it had a Solex 34 pict 3 (VW-432 stamped on the mounting flange), but I don't know if that carb was original to the car. My plan is to remove the distributor and try to clean it to free up the advance mechanism. If that doesn't work, I'll replace it with something other than an 009.
-update-
I was able to free up the frozen vacuum advance mechanism by spraying Liquid Wrench penetrating oil repeatedly on the advance mechanism while pulling a vacuum on the inlet and working the mechanism with a screwdriver. After about an hour, it was moving freely. I reinstalled it expecting to have solved the issue but not so. I timed the spark to about 15 BTDC with it running using a timing light. I then increased engine rpms but the timing stayed where it was, which is what the original problem was. Thinking that it wasn't getting a vacuum signal, I started to pull off the vacuum hose at the distributor and the timing retarded toward 5 degrees ATDC and the engine stalled. I static timed it to around 15 BTDC, left the vacuum hose disconnected, and started it up. I found the vac signal at the hose was around 20 inches Hg at idle and thruout the rom range. This is essentially the same as the intake manifold pressure. The vacuum port is on the side of the carb, near the air volume and mixture screws. It turns out that the vacuum sensing point is from a drilling that is just downstream of the throttle plate, not just upstream, as I think it's supposed to be. Therefore, now the distributor gets full vacuum, even at idle. I may post separately on this problem- whether the thtottle plate can be made to rotate further (the screw is adjusted so it isn't touching the stop) or whether it's a problem with quality control of generic 34 pict 3 carbs.
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7502 Location: Houston, Texas
Posted: Mon Oct 30, 2023 7:43 am Post subject: Re: 1974 Ghia Vacuum advance distributor won't advance |
Don't replace it with a 009. It will cause a flat spot at low RPMs unless you have a lead foot.
113905205M is for a single port motor or an engine using a single port carburetor. This is vacuum advance only. It will not run well with your 34 PICT 3 as the vacuum signal is not the best.
You have a 34 PICT 3 and that is for a dual port engine. You should get a 034 distributor or something similar. This is what is typically referred to as a SVDA.
Here are two options I have available:
https://www.thesamba.com/vw/classifieds/detail.php?id=2619759
https://www.thesamba.com/vw/classifieds/detail.php?id=2181010 _________________ www.vwnos.com [email protected]
