ajsstormer Samba Member
Joined: April 19, 2020 Posts: 14 Location: North Saanich, British Columbia
Posted: Sun Jan 14, 2024 10:03 am Post subject: White sludge in buggy engine |
Observed a considerable amount of white sludge in our VW buggy engine. Installed an Empi aluminum oil filler w/ vent hose to the intake just before the carb a few yrs ago & now find the vent hose and oil filler neck partially plugged w/ a soft white oil sludge. Observed some oil weeping out f/ behind the lower belt pulley when motor running a few months before we parked it for the winter & after some research found that the cause may be insufficient crankcase venting. The big bore 1200 motor was rebuilt by a VW shop in 2020 & runs very well w/ about 6k miles on the rebuild. Never needed to add oil between oil changes. Been using regular 20/50 motor oil changed every 1500 miles. Buggy always parked in a dry garage. What causes this white sludge? Incorrect crankcase venting? Wrong type motor oil?
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11148 Location: Oregon
Posted: Sun Jan 14, 2024 10:26 am Post subject: Re: White sludge in buggy engine |
The white sludge occurs when the engine has been run, but not long enough to build sufficient heat to cook the moisture out of the oil in the crankcase.
In the spring, drive the car a fairly long distance, you want the engine to get hot and drive the moisture out of the oil. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79587 Location: Sneaking up behind you
Posted: Sun Jan 14, 2024 10:53 am Post subject: Re: White sludge in buggy engine |
you needed a vented 710 cap. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
DeathBySnuSnu Samba Member
Posted: Sun Jan 14, 2024 11:51 am Post subject: Re: White sludge in buggy engine |
You have water in your oil.
It could be from outside exposed storage and/or the engine never getting up to full running temperature and condensation not getting burned off
It is common when the thermostat has been removed and the engine has not been run hard/long enough to make any heat.
The oil neck extension fitting for a vent is wayyyy to small diameter (less that stock). You don't need huge breather boxes and hoses all over the place. Even stock would be good enough. So yes better venting but don't go overboard for a street engine you are not gonna wring the guts out of all the time. _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
Posted: Sun Jan 14, 2024 12:39 pm Post subject: Re: White sludge in buggy engine |
My Buggy engine very seldom will get above 170* F. engine oil. Especially in the fall and spring. A lot of my driving is to work and back ten miles each way. Oil temps sometime struggle to get over 160* F.
I have real time tracking of oil temp on a digital dash and the only time I see oil temps above 180-190 is long, high speed travel...or mid summer temps of 90* F. or higher.
Anything less than 180 degrees will give the Vaseline issue in an engine.
I have all the tins on plus a higher temp thermostat.
Getting an engine really warm in a buggy is not the easiest thing to do. _________________
richardcraineum wrote: |
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
cbeck wrote: |
His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
EVfun  Samba Member
Posted: Sun Jan 14, 2024 1:03 pm Post subject: Re: White sludge in buggy engine |
My first buggy ran a power pulley and I still had trouble getting the oil 90F over the outside temperature. Since Seattle has only a few days over 80F it usually had that sludge. My solution was changing the oil twice a year, the last one right before putting it into winter storage so the engine only ran maybe 5 minutes on the fresh oil.
I sometimes wonder if a beach buggy needs even the stock oil cooler. Don't want to take the chance of frying an engine to find out. _________________
Wildthings wrote: |
oprn Samba Member
Joined: November 13, 2016 Posts: 14825 Location: Western Canada
Posted: Sun Jan 14, 2024 1:36 pm Post subject: Re: White sludge in buggy engine |
That engine has never reached proper operation temperature, it's that simple! And whatever you do DO NOT leave that oil/water/acid sludge in it all winter! That is exactly what rots the sumps out of these engines!
Over the winter collect all the proper parts, thermostat, flaps, connecting rod, ALL the proper lower tins and a stock oil filler with the draught tube and hose connection for the air cleaner. Put them all on in the spring.
Oh, and the proper weight of oil may stay cleaner as well just due to the fact that it will be easier for the water to separate out... less tendency to turn into whipped cream. _________________ Our cars get old, we get old but driving an old VW never gets old! |
slalombuggy Samba Member
Posted: Mon Jan 15, 2024 10:10 pm Post subject: Re: White sludge in buggy engine |
The weight of oil has nothing to do with sludge build up. I've seen engines running 0W20 oil develop sludge in them. It's all about temperature pure and simple |
oprn Samba Member
Posted: Wed Jan 17, 2024 3:53 am Post subject: Re: White sludge in buggy engine |
Not the formation no but heavier oil whipped into an emulsion is a lot harder to clean up. I know this from years of work in the oil industry, heavier crude takes way more heat, time and chemicals to separate the water from the oil. It all comes out of the well whipped into a froth by the down hole pump, light crude will separate in seconds and heavier oil will take hours and sometimes days to settle and separate on it's own. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Wed Jan 17, 2024 9:03 am Post subject: Re: White sludge in buggy engine |
oprn wrote: |
Not the formation no but heavier oil whipped into an emulsion is a lot harder to clean up. I know this from years of work in the oil industry, heavier crude takes way more heat, time and chemicals to separate the water from the oil. It all comes out of the well whipped into a froth by the down hole pump, light crude will separate in seconds and heavier oil will take hours and sometimes days to settle and separate on it's own. |
This has no relavence for this discussion about engine oil. |
Glenn  Mr. 010
Posted: Wed Jan 17, 2024 9:40 am Post subject: Re: White sludge in buggy engine |
I would not vent the case to the carb... good way to make a mess.
BTW.. nice red cap. _________________ Glenn
Member #1009
#BlueSquare
oprn Samba Member
Posted: Thu Jan 18, 2024 5:48 am Post subject: Re: White sludge in buggy engine |
slalombuggy wrote: |
oprn wrote: |
Really? The time it takes for water to separate out of oil and boil off has no relevance to our engines? _________________ Our cars get old, we get old but driving an old VW never gets old! |
EVfun  Samba Member
Posted: Fri Jan 19, 2024 3:32 pm Post subject: Re: White sludge in buggy engine |
oprn wrote: |
oprn wrote: |
Really? The time it takes for water to separate out of oil and boil off has no relevance to our engines? |
IDK, does crude oil come with a detergent package and an active mixing system?
As Clonebug pointed out, even a working thermostat may not handle the issue on a cold running exposed engine. If the thermostat is present longer trips can help. A little redesign to provide a PCV system could help too. _________________
Wildthings wrote: |
oprn Samba Member
Posted: Sat Jan 20, 2024 4:33 am Post subject: Re: White sludge in buggy engine |
Don't take my word for it, take a cup of your favorite 50 wt oil, 1/4 cup of water, put it in a blender , pour it in a glass and time how long it takes to separate. Then do it with some 10 wt. Do it cold, do it hot...
Slalombuggy is right. The weight of your oil has no effect on how soon or how much sludge forms but it does effect how readily it separates and boils off. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Mon Feb 05, 2024 1:02 pm Post subject: Re: White sludge in buggy engine |
Thanks for all the advice on white sludge in our VW dune buggy engine. Cleaned out the breather and fill pipe thoroughly of sludge. Ran the motor until warm replaced the oil w/ 15W/40. Posted the buggy on FB marketplace & sold it to a local buyer. |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1234 Location: San Angelo, Texas
Posted: Mon Feb 05, 2024 4:56 pm Post subject: Re: White sludge in buggy engine |
Maybe overkill, but I like over doing everything. Vents in both valve covers, oil filler and where the fuel pump used to be. This can is filled with copper Brillo pads... Otherwise, I'm a fan of a pan evac system on a race motor.
_________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
