Late fuse panel connector pins available?
Altoona
Altoona is offline
PostPosted: Wed Jan 24, 2024 9:36 am    Post subject: Late fuse panel connector pins available? Reply with quote
Has anyone found replacements for the connector pins on the back of the late fuse panels? Looking for the round female connectors that snap into the various plugs on the back. Both sizes would be great but specifically need the larger of the two.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Wed Jan 24, 2024 10:32 am    Post subject: Re: Late fuse panel connector pins available? Reply with quote
How many pins do you actually need?
They are available in small quantities from various sources such as VanCafe and that is where I would source a few.
The VW dealer sells them already crimped onto a wire for splicing, a pin on both ends of a short wire. $$$ for 1.
A seller on Amazon has the large pins bare in a 6 pack from Europe.
Mark
do.dah
do.dah is offline
PostPosted: Wed Jan 24, 2024 10:34 am    Post subject: Re: Late fuse panel connector pins available? Reply with quote
https://vancafe.com/vanagon-ac-connector/
Altoona
Altoona is offline
PostPosted: Wed Jan 24, 2024 12:18 pm    Post subject: Re: Late fuse panel connector pins available? Reply with quote
Nice! Thank you. I didn't even think to check the vendors.
Chilepines
Chilepines is offline
PostPosted: Thu Jan 25, 2024 1:57 am    Post subject: Re: Late fuse panel connector pins available? Reply with quote
I got mine from VanCafe, but I think these are also the right connectors.
https://www.amazon.com/gp/product/B077CTYTBM/ref=ox_sc_saved_image_6?smid=A28UR7K5OC7F9U&psc=1
White 89 Westy with 2004 Subaru EJ25 and Subarugears 5MT - Betty
ZsZ
ZsZ is offline
PostPosted: Thu Jan 25, 2024 5:01 am    Post subject: Re: Late fuse panel connector pins available? Reply with quote
They are standard AMP Round automotive connectors.
You can find them at TE, through Mouser, Digikey or other electronic part distributors.
Eg:
https://www.te.com/usa-en/product-CAT-R7602-T273.html
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
