viperjcr Samba Member
Joined: January 03, 2006 Posts: 64 Location: Salt Lake City, Utah
Posted: Sat May 25, 2024 12:14 pm Post subject: compression ratio |
What would be a recommended compression ratio for this engine?
90.5 pistons
76 crank
Engle 100 cam
Stock valves ported
weber 40 carb |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79790 Location: Sneaking up behind you
Posted: Sat May 25, 2024 12:18 pm Post subject: Re: compression ratio |
8.0 - 8.25 _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7873 Location: Videbaek Denmark
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Sat May 25, 2024 1:33 pm Post subject: Re: compression ratio |
Piston size and crank stroke does not matter.
Do you have single carb or dual carbs?
What is your elevation?
What octane gas do you want to run? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sat May 25, 2024 2:13 pm Post subject: Re: compression ratio |
single carb, elevation 4300ft, 87 or 91 octane |
Posted: Sun May 26, 2024 12:44 am Post subject: Re: compression ratio |
vwracerdave wrote: |
[/b] |
Mmmhh, actually it does. But in those bores you are correct it is minimal.
It has been a while since I was in the SLC area last, so I do not remember which octanes are available. With the W100 cam and 9-1 up there, 89 was the fuel I would use.
If the jump is from 87 to 91 you would have to go with 91.
If you want to be able to use 87 you should set the CR to 8,5 _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
