Air dam on a Baja?
DurocShark
Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
DurocShark is offline
PostPosted: Sun Jun 23, 2024 9:17 am    Post subject: Air dam on a Baja? Reply with quote
My 68 Baja has a problem. On the freeway, anything over 75mph I can feel the nose lifting. (I'm very familiar with this feeling, had a 280z that did the same thing.)
Anybody put a spoiler on the front of their baja to resolve this?
No boom today. Boom tomorrow. There's always a boom tomorrow.
Wulfthang
Wulfthang is offline
PostPosted: Sun Jun 23, 2024 7:22 pm    Post subject: Re: Air dam on a Baja? Reply with quote
My Rat Rod Trail Rail does the same thing at about 80 mph. It's because of that big flat pan on the underside. I decided to just keep it under 80, at least on the road.
Dusty1
Dusty1 is offline
PostPosted: Mon Jun 24, 2024 6:10 am    Post subject: Re: Air dam on a Baja? Reply with quote
"Doctor, doctor. My arm hurts when I move it like this!"
Doctor:
"Don't do that!"
Seriously, why did you build an off- road car? Slow down and see the sights! Imagine how many snail darters you're annihilating at those speeds, how many endangered desert turtles are becoming speed bumps. Rolling Eyes
A VW Bug is shaped like a pregnant airfoil. Lifting it makes it a better airfoil.
A regular old air dam isn't exactly sleek and slippery. Maybe a sprint car style nose wing? Or look at a few F1 cars. See where you can find some downforce.
Dusty1
Dusty1 is offline
PostPosted: Mon Jun 24, 2024 6:12 am    Post subject: Re: Air dam on a Baja? Reply with quote
Doctor:
"Don't do that!"
DurocShark
PostPosted: Mon Jun 24, 2024 6:45 am    Post subject: Re: Air dam on a Baja? Reply with quote
I daily this thing. So it must perform in all conditions.
Plus the air conditioning (windows) works better the faster you go. Wink
As for slippery... This thing's about as aerodynamic as a dirt clod. I'd rather break up the airflow than pick up 1 or 2 mph at the top end.
Dusty1
Dusty1 is offline
PostPosted: Mon Jun 24, 2024 10:14 am    Post subject: Re: Air dam on a Baja? Reply with quote
Add some downforce. A spoiler mostly adds drag.
Some of the newer Class 5 one piece front ends look like they add a little downforce.
Build a shroud over where the gas tank would normally be. If you can intake air down near the lower torsion tube and release it in front of the windshield... you might make a little downforce like that.
Ducting air out to reduce lift is as important as ducting air in to make downforce.
These are all things we do on our short track racers. We're going just fast enough to make it worthwhile.
Another short track racer trick... add lead if there's no other way to make it stick. A couple hundred pounds in a weight box bolted to the front of the beam should make your front end stick like a booger. Cool
oprn
oprn is offline
PostPosted: Mon Jun 24, 2024 10:38 am    Post subject: Re: Air dam on a Baja? Reply with quote
It’s pretty simple really, it’s just the wrong tool for the job. Ya you can cut a plank in half with a hammer if you are stubborn enough but there are better ways. To successfully make it do what you apparently need, it will no longer be a Baja Bug and for good reason.
DurocShark
PostPosted: Mon Jun 24, 2024 11:44 am    Post subject: Re: Air dam on a Baja? Reply with quote
Typical Samba. Ask a specific question and get a bunch of comments that have zero to do with the question.
Laughing
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Mon Jun 24, 2024 12:02 pm    Post subject: Re: Air dam on a Baja? Reply with quote
Why don't you add a front spoiler and let us know?? I make sure to have a full tank of gas and I have a full size spare with steel rim up front my bug is fine at 75MPH maybe you should try an alignment and add weight.
DurocShark
PostPosted: Mon Jun 24, 2024 12:03 pm    Post subject: Re: Air dam on a Baja? Reply with quote
Yeah, I just wanted to see some existing installs. All good. I'll figure it out.
Another option is to drop the nose a bit, but then I lose clearance.
PostPosted: Mon Jun 24, 2024 12:13 pm    Post subject: Re: Air dam on a Baja? Reply with quote
I even have a 24X30 skid plate on the front. With a half tank and no front spare the bug is scary past 60 its all about weight. If your toe in its really scary
Dusty1
Dusty1 is offline
PostPosted: Mon Jun 24, 2024 2:47 pm    Post subject: Re: Air dam on a Baja? Reply with quote
Handy thing about stock Bug bodywork is you can fill the spare tire well full of rocks to tone down sketchy handling. It won't fix a woefully mis- aligned front end but it sometimes makes an un- drivable VW... drivable.
Lose the rocks for spirited off- road driving. Cool
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Mon Jun 24, 2024 3:20 pm    Post subject: Re: Air dam on a Baja? Reply with quote
1 down vote
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
cbeck
cbeck is offline
PostPosted: Mon Jun 24, 2024 4:00 pm    Post subject: Re: Air dam on a Baja? Reply with quote
Fab a fromt bumper/skidplate that you can flip over into a cow catcher
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
PostPosted: Mon Jun 24, 2024 4:05 pm    Post subject: Re: Air dam on a Baja? Reply with quote
Rocks really??? WOW Rolling Eyes Sand works much better I did that in the early days it worked. Like I said add weight.
DurocShark
PostPosted: Mon Jun 24, 2024 4:09 pm    Post subject: Re: Air dam on a Baja? Reply with quote
Hmmmmm....
Dusty1
Dusty1 is offline
PostPosted: Mon Jun 24, 2024 5:28 pm    Post subject: Re: Air dam on a Baja? Reply with quote
I like rocks. Easier to load and unload compared to sand. It sounds like a joke but it isn't. Every short track racer knows the quick way to change your chassis balance is to move some weight around. We're supposed to use bolt- in lead with our car number on it if we add weight. Rocks work just as good if you don't have to please a tech inspector.
Re- locating your ten gallon stock tank takes over 60 pounds off the front end. Moving the battery to the passenger side front puts some of that weight back. That doesn't apply as much to Optima batteries.
DurocShark wrote:
Hmmmmm....
Some of our local mud boggers cut up rubber "cow mats" and make a giant mud flaps on the front of their rigs. The idea is if you get into a deep sippy hole under the mud your rig won't submarine and pack the radiator and everything else full of mud. A piece of aircraft cable and / or a couple pieces of tubing behind the flap keeps it where it's supposed to be.
You could probably "borrow" a mud flap off a semi and accomplish something similar on a Baja bug.
PostPosted: Mon Jun 24, 2024 6:05 pm    Post subject: Re: Air dam on a Baja? Reply with quote
Now I know your Full of BS first 39MPG and now sand bags are hard to move Laughing OMG
Dusty1
Dusty1 is offline
PostPosted: Tue Jun 25, 2024 6:01 am    Post subject: Re: Air dam on a Baja? Reply with quote
O.k., Richard. Rolling Eyes I learned decades ago many s0- called VW "experts" are grumpy narcissists. I've been studying narcissists lately. One symptom... they don't value opinions other than their own. Rolling Eyes
PostPosted: Tue Jun 25, 2024 10:05 am    Post subject: Re: Air dam on a Baja? Reply with quote
Rocks will cut their way thru any container or bag you use thus dropping them all over the highway cracking windshields and causing an accident. Also would you like a face full of sand or rocks when you get in a wreck???? I always think about other people in everything I do, Sand is much safer that's just fact has nothing to do with my opinion.
If you can figure out how much weight works speedway has a good selection of mounts and lead weights for a more permanent install. Its just expensive https://www.speedwaymotors.com/Search?query=ballast. You can also pour concrete in custom molds and just use their mounts.
Dusty, Im sorry YOU got butt hurt because YOU give dangerous advice.
