syncroid Samba Member
Posted: Tue Jul 30, 2024 10:41 am Post subject: Loose red wire in engine bay black box |
Is it supposed to attach to the open terminal on this little fuse block?
What is it for?
4Gears4Tires Samba Member
Posted: Tue Jul 30, 2024 11:50 am Post subject: Re: Loose red wire in engine bay black box |
Looks like something in your hand is missing it's female spade connector, just pointing that out.
What doesn't work on your van? _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Corwyn  Samba Member
Joined: December 29, 2009 Posts: 2419 Location: Olympia, Washington
Posted: Tue Jul 30, 2024 12:11 pm Post subject: Re: Loose red wire in engine bay black box |
Plug it in - lets find out. What doesn't work in your van? _________________ '90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
Posted: Tue Jul 30, 2024 12:31 pm Post subject: Re: Loose red wire in engine bay black box |
Corwyn wrote: |
Plug it in - lets find out. What doesn't work in your van? |
I'm thinking it's the reverse lights that suddenly stopped working - everything else in that circuit checks out ok. Engine also consistently dies at idle after rehabbing my idle control unit. Used to only die when cold right after startup. I'm just worried about doing some damage by just plugging it in.
Was hoping that someone else would have the same fuse block to confirm. |
