Globedog12 Samba Member
Joined: April 11, 2024 Posts: 225 Location: Atlanta, GA
Posted: Tue Sep 10, 2024 5:17 pm Post subject: Distributor question |
I have a 76 bus from CA the current distributor is a 0231 170 034. From what I can tell this is from a Beetle? Should I change it out or is it ok?
_________________ 1976 VW Type 2 Original fuel injection |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79781 Location: Sneaking up behind you
Posted: Tue Sep 10, 2024 5:23 pm Post subject: Re: Distributor question |
The correct distributor is a 021-905-205P, but the 034 you have has very similar specs.
So if it's running OK... leave it alone. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Tue Sep 10, 2024 5:34 pm Post subject: Re: Distributor question |
| Glenn wrote: |
So if it's running OK... leave it alone. |
Good to know. Can you explain the similar specs or link to source so I can look myself? I’m very new to this and trying to learn all I can. _________________ 1976 VW Type 2 Original fuel injection |
Glenn  Mr. 010
Posted: Tue Sep 10, 2024 5:42 pm Post subject: Re: Distributor question |
Beetle 1974 * 1600 Federal Manual Trans
Distributor: VW 043-905-205, Bosch 0231 170 034
Can Use: VW 113-905-205AL, Bosch 0231 146 101, VW 043 905 205 ZB (Mexico) (See Note Below)
Timing Set At:: 7.5deg BTDC @ 800-950rpm w/strobe and w/single vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum: 8-12deg Adv; Centrifugal: 7-12deg @ 1600rpm, 20-25deg @ 3800rpm
Bus & Pickup Late 1976-1978 All States, 1979 Federal * 2000
Distributor: VW 021-905-205P, Bosch 0231 168 005 > 022-905-205S, 0231 170 093
Timing Set At:: 7.5deg BTDC @ 850-950 rpm (Man Trans), 900-1000 rpm (Auto Trans) w/strobe, vacuum hose connected
Advance/Retard Range: Vacuum: 8.5-11deg Adv @ 7.9 In. Hg; Centrifugal: 8-13deg @ 1600 rpm, 20.5-24.5 @ 3400 rpm _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue Sep 10, 2024 6:28 pm Post subject: Re: Distributor question |
Thanks! _________________ 1976 VW Type 2 Original fuel injection |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17662 Location: San Diego, California
Posted: Tue Sep 10, 2024 6:36 pm Post subject: Re: Distributor question |
https://oldvolkshome.wetwesties.org/ignition.htm _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7509 Location: Houston, Texas
Posted: Tue Sep 10, 2024 8:16 pm Post subject: Re: Distributor question |
It is ok to leave that distributor in your engine. It has not similar but identical specifications to the original distributor. VW made many distributors that were identical except the number that was stamped on them. _________________ www.vwnos.com [email protected]
