Black color sand/buff issues
Dan2973
Dan2973 is offline
PostPosted: Sun Oct 06, 2024 11:53 am    Post subject: Black color sand/buff issues Reply with quote
Hello everybody, please help me. I am so frustrated. I recently painted my 1958 beetle that I’m restoring single stage black Omni. The paint Job came out pretty good with only a little bit of peel in some areas. I decided to start color, sanding and buffing and immediately ran into problems doing the driver side door. The process was exactly the same as the last car I painted. I started off wet sanding with thousand grit, 1500 grit, 2000 grit and then I started to buff. I am using Maguires ultra cut because that’s what I use last time. I am also using 3M polish because that’s what I use last time with great results. The problem is no matter what I do , I am not getting a deep black shine. I am getting areas that are very cloudy and it looks like crap. I tried re-wet sanding. I’ve tried buffet multiple times. I just cannot figure out what is going on. I have three heavy coats of paint on there I just keep getting and milky cloudiness all over the door panel please help what am I doing wrong? I’ve tried letting compound dry. I’ve tried wiping it off wet after I buff. I cannot figure it out.
67ctbug
67ctbug is offline
PostPosted: Sun Oct 06, 2024 5:34 pm    Post subject: Re: Black color sand/buff issues Reply with quote
You need to be sanding way finer. On black, I would go up to 5000 grit. I'd also recommend trying the Rupes compound system, it's the best I've used.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
74 Thing
74 Thing is offline
PostPosted: Mon Oct 07, 2024 1:26 am    Post subject: Re: Black color sand/buff issues Reply with quote
Yes, as recommended above I would use a good quality paper and a higher grit.
What kind of polisher, pads, and speed, and technique you are using helps determine the final results as well.
Put a bright light on those panels and take a photo and then post them to see if they are finishing out swirl free.
Dan2973
Dan2973 is offline
PostPosted: Mon Oct 07, 2024 4:20 am    Post subject: Re: Black color sand/buff issues Reply with quote
Thank you I will post some pics after work today
Bulli Klinik
Bulli Klinik is offline
PostPosted: Tue Oct 08, 2024 8:26 am    Post subject: Re: Black color sand/buff issues Reply with quote
Though I agree with what has been said about your buffing technique, I've sprayed the same product and I thought that the paint looked a bit brown and not pure black. I also thought it looked a little cloudy. The ladies at the paint shop told me that to get a very pure black, I'd have to move up to a more expensive paint.
Just my experience. Good luck with your project.
Mike K
Bulli Klinik
Colorado Springs
