Ghia_Z Samba Member
Posted: Thu Oct 17, 2024 6:10 am Post subject: 71 Brake light wiring |
Adding a third brake light to the Ghia and I’m at loss as to where to tap into the brake light wire. It appears that the taillight assembly is secured from behind as there are no visible fasteners under the lens. It’s an Autostick with full tar boards and the engine’s in, so getting at the rear of the assembly isn’t an option. I’m thinking that an access hole cut it the firewall tar board near where the license plate light wire braces off is what I need. Can anyone describe the routing of that wire so I don’t butcher the tar board looking for it? TIA! |
bnam Samba Member
Joined: July 02, 2006 Posts: 3462 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Oct 17, 2024 6:17 am Post subject: Re: 71 Brake light wiring |
Ghia_Z wrote: |
Getting under the left side tar board should be easy I would imagine. The wires are there. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1922 Location: Raleigh, NC
Posted: Thu Oct 17, 2024 6:31 am Post subject: Re: 71 Brake light wiring |
Please do not ruin your tarboard when it's easily removable. If your battery is still located in the factory spot on the driver side of the engine compartment, you'll need to remove your battery from the car. After you do that, you'll see 3 or 4 metal tabs holding the fender-side tarboard in place. Bend those tabs back, and remove the tarboard. From there you'll have access to the inner rear fender where the wiring connections are on the back of the tail light. Use a piggy back spade connector to run a wire from the driver side brake light to your 3rd brake light. Depending on what type of light your 3rd brake light is (incandescent in a housing, LED strip, etc) you'll need to find a spot to also take the chassis ground from. If the light is an actual housing that gets secured with screws, you can ground where they go through the sheet metal.
Also, cheers from NC! _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Ghia_Z Samba Member
Posted: Thu Oct 17, 2024 4:43 pm Post subject: Re: 71 Brake light wiring |
Thanks, Era. I’ll try that route. If nothing else, removing the battery will give me a break from obsessive-compulsively trying to make the horns work.
Regards from Hillsborough, neighbor. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6145 Location: 37.5N 77.1W
Posted: Fri Oct 18, 2024 8:45 am Post subject: Re: 71 Brake light wiring |
Quote: |
Adding a third brake light to the Ghia |
Depends on if you want it inside against the rear window or on the outside area between the rear window and the engine cover or on the rear engine cover. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Ghia_Z Samba Member
Posted: Fri Oct 18, 2024 9:30 am Post subject: Re: 71 Brake light wiring |
I have an LED strip that’s a perfect fit for the space between the hood and the rain tray to shine out the hood vents.
Partsam Submersible 17" Clear Lens Red 23 LED Trailer Truck RV Stop Turn Tail Rear 3rd Brake Identification Light Bar (Pack of 1) https://a.co/d/2uNKDyR
[/url] |
Posted: Fri Oct 18, 2024 9:52 am Post subject: Re: 71 Brake light wiring |
Quote: |
space between the hood and the rain tray |
The new wiring will have to follow and be part of the tag light harness on the engine cover. I also ran a ground wire to the tag light because you can't have too many grounds.  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Ghia_Z Samba Member
Posted: Wed Oct 23, 2024 5:41 pm Post subject: Re: 71 Brake light wiring |
Thank you all !
As described, getting the tar boards moved with the battery out was simple enough. Routed power from the left taillight, with the ground tapped into the license plate ground wire.
I’ll post pics soon. |
Ghia_Z Samba Member
Posted: Thu Oct 24, 2024 11:06 am Post subject: Re: 71 Brake light wiring |
Here are the pics…
_________________ Mark
Signal Orange ‘71 Ghia Coupe, “Otto Schtick” |
jpajya Samba Member
Joined: April 25, 2019 Posts: 69 Location: Northern VA
Posted: Thu Oct 24, 2024 2:05 pm Post subject: Re: 71 Brake light wiring |
Very nice Ghia and also appreciate the pics of your third brake light install.
Can you provide more info on how you mounted the light, and where you purchased it?
thanks, John _________________ John
'70 Ghia convertible |
Ghia_Z Samba Member
Posted: Thu Oct 24, 2024 2:32 pm Post subject: Re: 71 Brake light wiring |
I found it on Amazon.
https://a.co/d/654Pk2w
Partsam 17” submersible clear lens red 23 LED
While test fitting it for a fastener solution, I discovered that it wedged in there so nicely that all it took was adding a couple of 3” strips of body molding tape on the perimeter and pressing it back in tightly. _________________ Mark
jpajya Samba Member
Posted: Thu Oct 24, 2024 3:14 pm Post subject: Re: 71 Brake light wiring |
Nice. Looks like a good option. Thanks again. _________________ John
