Sodo Samba Member
Joined: July 06, 2007 Posts: 10934 Location: Western WA
Posted: Sat Oct 19, 2024 7:45 pm Post subject: 90 Amps load test at alternator post |
I just did this test.
I was reading another thread: (In for a penny, in for a pound) and suggested the member do this test.
Then thought maybe I should see how my van responds before suggesting it to someone else.
So here's the test. You can see there are a few places that volts can be lost.
I did not expect to find anything wrong on my van, it's not misbehaving at all.
Maybe nothing is wrong?
But 2 volts is a LOT of lost volts.
I will find where the volts are lost.
The lobsterclaw ammeter shows the load-tester pulling 90.5 Amps from the alternator post.
Somewhere between the battery, and the direct 4ga to chassis, 90.5 amps load causes voltage to drop from 12.5v to 10.4v, a 2.1volt drop.
My van has a new, oversized 3ga cable from the alternator to the starter post.
From the starter post to the battery, is the 1990 fat cable 10.5 feet long.
My newish, upsized cable,
3AWG from alternator to starter post (2021?) (by the numbers) should be responsible for only about 0.12v of the loss.
I will find the reason for this 2.1v loss!
I have a 130A Tribeca alternator.
So does this mean......
that driving home Sunday eve after a few days camped
IF:
very hungry LiFePO4 battery (50A Renogy DC-DC charger),
a hungry start battery (25A?),
400W headlights aburnin' (30A)
---->50A+25A+30A = 105A....
Does this test suggest I'd have only (~14.5 - 2.1 =) 12.4 volts to charge the start battery?
OK....the start battery would NOT suck 25A if there's not 14.5v available.
But I bet the DC charger would boost 12.4v to suck 50A for the LiFePO, letting loose some amps sometime AFTER it regained a full charge the start battery.
(what a HOG!)
This makes me want an ammeter on my alternator cable.  _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
harvgwen Samba Member
Joined: February 11, 2021 Posts: 310 Location: Okanagan Valley, British Columbia
Posted: Sat Oct 19, 2024 9:00 pm Post subject: Re: 90 Amps load test at alternator post |
Are you saying that you are losing 2V while cranking your engine? If so, that sounds like a fairly reasonable number. If you check the voltage across your 2 battery terminals while cranking the engine, you may find that you actually haven’t got much of a voltage drop at all between the battery and the starter. The battery cannot maintain 12.5V with a heavy draw coming from it. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia |
Sodo Samba Member
Posted: Sat Oct 19, 2024 9:15 pm Post subject: Re: 90 Amps load test at alternator post |
Not cranking.
It's losing 2volts at the alternator post - while holding "the button" down on the load tester.
========= EDIT =========
OK Harv! YES I knew something was wrong here.
I was enamored by the thought of "not cranking"
and missed a step!
FIRST I need to test the battery to find the voltage the battery can sustain with a 90A draw.
If it drops 2v right at the battery, then 2.1v back at the alternator is not significant.
But I'll still do the voltage drop tests of each leg just to solidify this procedure in my mind.
The load is similar to a starter load (90A) but quieter and more consistent.
If the starter had an intermittent problem, that additional fault would add confusion to the diagnosis.
This tester produces a known consistent load.
I like this method better than cranking.
Does anyone know the "wire gauge" and length of the fat battery cable?
VW upsized them over the years. _________________
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3632 Location: San Diego (Encinitas)
Posted: Sat Oct 19, 2024 10:19 pm Post subject: Re: 90 Amps load test at alternator post |
If you're getting a 2 volt drop with the load connected directly to the alternator, then there are two possibilities:
1) if the engine was running, the alternator couldn't supply 90 amps at the speed it was turning, so the alternator voltage dropped and could not be made up by current from the battery, due to wiring resistance from the alternator to the battery, and/or battery condition.
2) the voltage drop is at the connections between the load and the alternator and/or ground - especially if the voltmeter is in the load device. (90 amps is a lot of current, so it wouldn't take much connection resistance to drop 2 volts [2 volts / 90 amps = 0.022 ohms between both connections, to be exact]. To avoid this problem, use a separate voltmeter (directly connected to the alternator, not to the load clips) to make the measurement. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 6009 Location: Bemidji, MN
Posted: Sun Oct 20, 2024 4:18 am Post subject: Re: 90 Amps load test at alternator post |
| telford dorr wrote: |
| 2) the voltage drop is at the connections between the load and the alternator and/or ground - especially if the voltmeter is in the load device. (90 amps is a lot of current, so it wouldn't take much connection resistance to drop 2 volts [2 volts / 90 amps = 0.022 ohms between both connections, to be exact]. To avoid this problem, use a separate voltmeter (directly connected to the alternator, not to the load clips) to make the measurement. |
^^^^^ this!
your battery clamps have probably two tiny points of contact, maybe only one, on the half of the clamp with the cable going to it. the other side of the clamp is conducting thru a loose steel rivet. and the clamps themselves are just copper plated steel. PLUS, look at the actual diameter of the conductor on the clamp... not the thick insulation (plastic is cheaper than copper). it all adds up to internal voltage drops inherent in the tester.
on my favorite battery chargers, i have a bunch from people throwing them away, i replace the crappy steel post clamps with 100% copper Mueller brand clamps. not only do they not rust/corrode but i get far better contact into the battery post. they are $4.50 each but oh so worth it. one of those quality things where you smile every time you use them. _________________ -dan
www.thefixitworkshop.com |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19166 Location: Retired South Florida
Posted: Sun Oct 20, 2024 5:13 am Post subject: Re: 90 Amps load test at alternator post |
| I have a similar load box from long ago. Take yours and connect it to the battery posts directly to apply the load with your amp meter on the alternator cable. Report your findings. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10320 Location: Mt Lemmon, AZ
Posted: Sun Oct 20, 2024 7:35 am Post subject: Re: 90 Amps load test at alternator post |
| I suspect that 'toaster' you're connecting to the electrics is drawing down the voltage. |
Sodo Samba Member
Posted: Sun Oct 20, 2024 8:31 am Post subject: Re: 90 Amps load test at alternator post |
The cart jumped ahead of the horse right out of the gate but I'm still enamored by "testing without cranking".
That the toaster produces a draw appx same as a starter (90A) is a beautiful thing.
| the voltmeter is in the load device |
Yes Telford there's a significant difference between the voltage measurement being "in the load",
and the "voltage drop test"with its independent, microamps voltage measurement.
I'm curious if.....in the voltage drop test - the voltages could be so accurate the segments add up to equal "the 2.1v".
The repeatability of "the toaster" is key here (I think).
That's my project for this morning.
We'll go thru the exercise and then just repeat stuff we all knew already, right?
Yeah. We've all seen that ! It has a normal component called 20/20 hindsight.
But......when "the other" Samba members understand "the voltage drop test" it will become more common in TheSamba discussions.
And develop ability to identify the problem BEFORE resorting to the "parts cannon".
The parts cannon may be efficient (for the customer as opposed to the shop that's billing $150/hr for deep diagnosis) but can be costly for a DIY.
Slow starting is a popular Vanagon problem,
and as such, its solution intrigues me
'cuz it has the possibility of keeping a LOT of vans off the towtruck.
A lot of Van owneers NEED this and I think starter reliability can be improved with better testing skills.
One apple every 8 hours keeps 3 doctors away, right?
Do toyota 4runners have similar starter problems for example?
There's a lot of 30, 40 year-old 4runners out there. _________________
Posted: Sun Oct 20, 2024 8:44 am Post subject: Re: 90 Amps load test at alternator post |
| Sodo wrote: |
by and large no. one thing German engineering has taught me is how clever the Japanese are. from materials to waterproofing to oil sealing. admittedly, most of their base vehicles lack Fahrvergnügen but they also just run. _________________ -dan
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Sun Oct 20, 2024 10:42 am Post subject: Re: 90 Amps load test at alternator post |
What RPM was the load test done under? I would suspect you need to be at 3000 RPM to produce enough current at higher loads. _________________ 89 Westy 2.1 Auto |
Sodo Samba Member
Posted: Sun Oct 20, 2024 12:14 pm Post subject: Re: 90 Amps load test at alternator post |
| PDXWesty wrote: |
| What RPM was the load test done under? I would suspect you need to be at 3000 RPM to produce enough current at higher loads. |
Zero RPM.
Alternator performance is not part of this test, it's intent is to test the wire & connections amps capacity. _________________
fxr Samba Member
Joined: December 07, 2014 Posts: 2709 Location: Bay area CA
Posted: Sun Oct 20, 2024 12:23 pm Post subject: Re: 90 Amps load test at alternator post |
| Sodo wrote: |
| PDXWesty wrote: |
Zero RPM.
Alternator performance is not part of this test, it's intent is to test the wire & connections amps capacity. |
You need two voltmeters that you know agree with each other - one on the battery, one at the alternator, and *then* do the load test. The voltage drop is just the difference between the two readings, regardless of the actual voltage. No point measuring at the alternator if you don't simultaneously measure at the battery. _________________ Jim Crowther
Vespa GTS 300 |
E1 Samba Member
Joined: January 21, 2013 Posts: 8916 Location: Westfalia, Earth
Posted: Sun Oct 20, 2024 12:34 pm Post subject: Re: 90 Amps load test at alternator post |
Knowing how attentive you are to these cables and connections, I’m curious what the battery’s actual CCA might show on a load tester — for it to be losing nearly two volts to just to run the tester… that almost can’t be.
Or maybe your tester’s gone bad… _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?”
Posted: Sun Oct 20, 2024 3:21 pm Post subject: Re: 90 Amps load test at alternator post |
I still think that drawing 90A will cause the battery voltage itself to sag to the tune of 2V, and that there isn’t really a lot of Voltage drop at all. The way I think this should be tested is to apply the same 90A load, but this time measure the voltage at the battery itself. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Posted: Sun Oct 20, 2024 3:53 pm Post subject: Re: 90 Amps load test at alternator post |
| Sodo wrote: |
| PDXWesty wrote: |
Zero RPM.
Ahhh...I thought you were load testing the alternator, not the battery. _________________ 89 Westy 2.1 Auto |
fxr Samba Member
Posted: Sun Oct 20, 2024 3:54 pm Post subject: Re: 90 Amps load test at alternator post |
| PDXWesty wrote: |
| Sodo wrote: |
| PDXWesty wrote: |
Zero RPM.
Ahhh...I thought you were load testing the alternator, not the battery. |
He's trying to load test the wiring... _________________ Jim Crowther
Vespa GTS 300 |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10504 Location: Orbiting San Diego
Posted: Sun Oct 20, 2024 5:11 pm Post subject: Re: 90 Amps load test at alternator post |
That battery load tester EXPECTS the battery voltage to drop when you switch it on.
That is how it works!
It measures the strength of a battery, by measuring the how much the battery voltage sags under its load.
Then you find the colored zone on the meter face that matches the factory cranking amp rating of the battery and see where the needle points with respect to that colored zone.
The larger the battery the less expected voltage drop when the switch is held on.
A smaller battery is expected to sag to a lower voltage and still be considered GOOD.
His photos are too fuzzy to see the cranking amp numbers in the green zones.
Mark |
Posted: Sun Oct 20, 2024 5:56 pm Post subject: Re: 90 Amps load test at alternator post |
| crazyvwvanman wrote: |
| ...His photos are too fuzzy to see the cranking amp numbers in the green zones... |
Here's the dial on mine (I think it's the same unit). A useful tool within the limits of its design.
Sodo Samba Member
Posted: Sun Oct 20, 2024 6:49 pm Post subject: Re: 90 Amps load test at alternator post |
Keep in mind I'm doing this on a van that exhibits absolutely NO starter deficiency.
I'd do it on a van that HAS a starter deficiency,
but nobody I know has starter trouble.
I only READ about them on the internets (currently).
I have to CAUSE trouble.
Maybe I'll be lucky enough in the future to have an actual starter problem.
( dutifully following the tool's instructions to the T )
Using 100A battery load tester (actually 90A) on the bare battery it shows 1.6v drop.
That suggests my wiring has 2.1v - 1.6v = 0.5v drop.
0.5v / 12.5v = 4% ......hmmmmm
I HEAR 2% is the acceptable number,
so I'm gonna take 4% as 2% too MUCH...
and git after it!
I'll go thru the 'circuit' methodically with a voltmeter and this "special tool" to find where that "lost 0.5v" is hiding.
Getting a little wild here.....
beyond the limits of the tool's design....
but well within it's capabilities (as a simple 90A resistor).
Probably should test Vdrop between each wire segment (across each connection). _________________
Posted: Sun Oct 20, 2024 7:30 pm Post subject: Re: 90 Amps load test at alternator post |
There’s certainly no harm chasing this, and I know you’ll keep us all in the loop, so this will be a good learning experience for all of us. I’m not an electrical expert, but my suspicion is that your van is fine. I don’t know if 2% is a good number or not. If 2% is a good number on a “standard” vehicle with the battery near the starter, it may be an optimistic number for our vans with a long cable from the battery to the starter. Also, I’ve felt that the said cable is a little on the thin side for what it does, which will also contribute to a voltage loss, as will the fact that it’s (probably?) a 40 year old cable.
Again, I’m not an electrical expert. I will be eagerly following this thread. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
