Possible bad O2 sensor?
Page: 1, 2, 3, 4, 5, 6  Next
AirCooledCurtis
AirCooledCurtis is offline
PostPosted: Tue Oct 22, 2024 1:19 pm    Post subject: Possible bad O2 sensor? Reply with quote
Looking for some ideas on what to check. Here's the scenario:
'86 Digifant Syncro. It was apart for a few months getting too much work done. While apart it got the injectors cleaned and flow tested, plugs and wires, TPS adjusted and checked at the plug on the manifold, o2 signal wire replaced (Vanagain kit), fuel lines, fuel filter, fuel pump. AFM physically bench tested and cleaned.
On startup, cold or hot, the engine will immediately fire and find idle. It'll rev well and respond to throttle input exactly as it should. After it gets warm, or if hot start, 10 seconds or so has passed, it'll progressively stop wanting to rev until the engine will just die when you give it throttle. The o2 shows it go super super lean with throttle. While idling (it idles well) the o2 swings from .1-1V at a healthy tempo. Engine off key on I get .5V at the o2 signal wire when unplugged (good). Pin 19 at the ECU plug to the chassis ground under the back seat shows that the ground reference wire is good.
If I unplug the o2 signal wire this issue goes away and the van will rev.
I've had a similar issue with the o2 sensor before on another '86, I'm just puzzled why the o2 is causing this and what else I can rule out.
DigiMatrix
DigiMatrix is offline
PostPosted: Tue Oct 22, 2024 1:54 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
Do you have anything connected to the O2 signal wire other than the ECU? I had an issue when I had an O2 led monitor connected to my O2 signal and it ran fine for a long time and then caused me all sorts of grief. When I finally ripped it out in frustration, the issue was gone. Lesson to self - never connect a secondary gauge to the O2 signal wire. Weld in a second bung, add a second O2 sensor and use that for whst ever you want.
'91 Syncro Westfalia
soon to be 2.5 liter stroker WBX 10:1 comp
Digifant ECU with knock sensor and custom
cylinder selective knock control by me
AirCooledCurtis
PostPosted: Tue Oct 22, 2024 2:47 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
Nope, the o2 wire is new. It goes straight to the ECU, and the shield is spliced (soldered) to the old wire coming off pin 19. Ground strap on the transaxle is also good.
zerotofifty
zerotofifty is offline
PostPosted: Tue Oct 22, 2024 3:42 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
If in doubt, change it out. oxygen senders are consumable, a bad one can ruin a very expensive catalyst.
AirCooledCurtis
PostPosted: Tue Oct 22, 2024 4:00 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
I've already ordered one, it says it'll be here tomorrow. Some idiot before me spliced the o2 signal wire to the wire that runs off of the hall sensor to the idle control module (both are green shielded wires, this is now fixed). All that to say the cat has already been emptied. Fingers crossed the bores aren't wiped, I don't smell oil or rich mixture from the tail pipe.
latelogan
latelogan is offline
PostPosted: Tue Oct 22, 2024 4:02 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
i just want to remind you to check the ground wires to the o2 sensor as well as the signal wire and power wire. That caused my shop and me about 3 weeks of heck. Although, your symptoms sound different than mine (black exhaust on start).
ohm them to the frame is prob best.
Wondering if this is more like the temp sensor. I had a bad connection on mine and replaced the entire connector.
1991 Westy stock 2.1 auto transmission
1978 Westy (Sold)
1971 Westy (Sold)
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Oct 22, 2024 4:53 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
Pin 19 doesn't reference the chassis ground, it references the engine ground while the engine is running.
The wiring bundle that connects to the hall sender also has a brown wire that doesn't go on to the hall, but is supposed to be screwed down to bare engine metal.
That wire connects to pin 19 to ground the shield and provide the O2 sensor reference ground for use by the ECU.
Due to the alternator output currents which vary by what loads are being powered, there can be small and varying voltage differences between the chassis metal and the engine metal.
Since the O2 sensor signal works with fractions of a volt and relies on its threaded contact with the exhaust for the signal ground, it needs to use a good engine ground to avoid having its reading affected by the alternator currents.
Edit: to perhaps clarify, the pin 19 should not have a direct wire connection to chassis ground and didn't from the factory by design.
Mark
AirCooledCurtis wrote:
....... Pin 19 at the ECU plug to the chassis ground under the back seat shows that the ground reference wire is good.
AirCooledCurtis
PostPosted: Tue Oct 22, 2024 5:11 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
Mark
Yep, I understand how the o2 wiring works. I was just making sure that there wasn't a break in the wire from pin 19 to ground. If it's actually grounding on the block, and the ground strap on the transaxle is good, then it'll show up as a complete circuit with the chassis ground. This won't tell if there's an issue with current load, but it's a quick check I did.
AirCooledCurtis
PostPosted: Tue Oct 22, 2024 5:15 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
The o2 grounds through the exhaust. There's a brown ground wire on the o2 but it's for the heater. Seeing how quickly it starts sweeping I can tell that the heater is working. I've checked the signal wire. I'm more familiar with Bosch LH Jetronic, LH will take the resistance from the temp sensor with key on (before start) which is reflected in how it runs right after it fires up. Considering it runs best cold or hot, tells me that the mixture is correct on startup.
crazyvwvanman
PostPosted: Tue Oct 22, 2024 5:23 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
As another check, try to measure on low DC volts with a meter probe on the shield strands near the sensor and the other on bare engine metal.
Of course the engine should be running and the alternator warning light should have turned off.
Mark
DanHoug
DanHoug is offline
PostPosted: Tue Oct 22, 2024 5:54 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
a poor ground on the alternator can raise the voltage potential of the engine block and can mess up O2 signal to the ECU. so many have added an extra ground from the alternator case to the body.
but more likely in your scenario is an exhaust leak introducing oxygen that the O2 sensor sees as a lean mixture and consequently over-richens the mixture to the point where it runs terrible. additionally, anything that causes a cylinder to miss adds oxygen to the exhaust stream and can cause a low voltage on the sensor.
and just to make sure, when you say it goes "super lean" you are seeing a LOW voltage on the O2 sensor, correct?
-dan
www.thefixitworkshop.com
1988M5
1988M5 is offline
PostPosted: Tue Oct 22, 2024 5:58 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
Are you sure you’re dealing with LH Jetronic (hot wire. luft=air, heiss=hot ) vs L Jetronic (still has the barn door AFM with a separate temp sensor.
1991 tin top GL
Some BMWs.
AirCooledCurtis
PostPosted: Wed Oct 23, 2024 4:51 am    Post subject: Re: Possible bad O2 sensor? Reply with quote
Yes, as from Volvos, Saabs, and M119 powered MB's. It's a fantastic injection system.
AirCooledCurtis
PostPosted: Wed Oct 23, 2024 4:58 am    Post subject: Re: Possible bad O2 sensor? Reply with quote
The alternator is grounded through the engine, so I'd assume it's fine but I'll check. I've considered the exhaust leak theory, but I've had Digifant Vanagons with completely broken header pipes that ran okay, and fresh air contaminating the o2 reading would make it run rich. The o2 voltage will read incredibly low, around 50mV and under. I've had ECU's fail regarding lambda control, I've heard that Digifant might not be referencing the o2 the same way at idle as it will off idle.
zerotofifty
PostPosted: Wed Oct 23, 2024 9:09 am    Post subject: Re: Possible bad O2 sensor? Reply with quote
the exhaust leak you mention may not cause the O2 sender to read low, rather if the O2 system is working, it may cause the ecu to enrichen the mixture until the O2 sender reads normal (if the leak is within a certain size) The excess fuel will in part be burnt with excess oxygen in the exhaust, often resulting in popping in the exhaust,
DigiMatrix
PostPosted: Wed Oct 23, 2024 9:22 am    Post subject: Re: Possible bad O2 sensor? Reply with quote
In the code, the ECU just reads the O2 reading at the analog to digital converter and does nothing to change that value. The only thing that changes is in the Proportional gain PID loop. The number of strokes with the same AFR between the OXS proportional update does change with RPM. It is 9 strokes from 260 to 1650 RPM and reduces to 3 strokes at the rev limit. The proportional update adds or subtracts fuel to make the O2 sensor swing between rich and lean.
AirCooledCurtis
PostPosted: Wed Oct 23, 2024 10:59 am    Post subject: Re: Possible bad O2 sensor? Reply with quote
That's awesome
AirCooledCurtis
PostPosted: Wed Oct 23, 2024 11:10 am    Post subject: Re: Possible bad O2 sensor? Reply with quote
An update for people wanting to play armchair mechanic. I installed the new Bosch o2, and it's still doing the same thing, except it's not better if I unplug the o2. Not sure what was happening before but I can't replicate it now. So I turned to looking to other systems. The ECU is seeing the TPS. The idle control valve isn't doing anything, I jumped the 2 wires on the PS pump which is supposed to raise the idle, right? Well it didn't do anything. I pulled the top off of the AFM, and if I physically richen the mixture while it's stalling, which isn't really scientific or probably healthy, it'll not stall. I have to nearly max out the arm so it needs a lot of encouragement to add fuel. I clamped the regulator return and the issue really improves. I don't have a way to test the fuel pressure right now, but the fuel pump and filter, along with lines, are new so I trust that the pressure is at least higher than what the regulator is suppose to "regulate" It's having a grossly under fuel situation that for some reason somewhat goes away with a key cycle.
My flat lifter pumped up so it's not clacking, so I can confidently say that it's not got any exhaust leaks. If it does it's a slow seep and won't be causing mixture issues.
AirCooledCurtis
PostPosted: Wed Oct 23, 2024 1:27 pm    Post subject: Re: Possible bad O2 sensor? Reply with quote
More updates, the fuel pressure is good. 38psi with the vacuum line unhooked, 32psi with some vacuum. It also holds pressure. I'm thinking that the same buffoon who hacked up the o2 signal wire could've messed with the AFM. It's a rebuilt Syncro one and the traces look good. I'll check that next, I'm not ruling out the ECU though.
Could the idle control circuit be causing any issue off idle?
AirCooledCurtis
PostPosted: Thu Oct 24, 2024 5:27 am    Post subject: Re: Possible bad O2 sensor? Reply with quote
This morning I tested output voltage from the AFM while the car was off but key position 2. No dead areas. I tried to replicate sudden movements in the range that it'll die and I couldn't get anything out of the ordinary. I may have to test it while it's on the car and running. It still seems to me like the lambda control in the ECU is toast.
Last edited by AirCooledCurtis on Thu Oct 24, 2024 8:56 am; edited 1 time in total
Page 1 of 6
