52 crotch cooler deluxe split fusebox
dave1
dave1 is offline
PostPosted: Tue Nov 05, 2024 3:14 pm    Post subject: 52 crotch cooler deluxe split fusebox Reply with quote
Hi all,
Can someone please forward a picture of the fusebox area under the spare wheel area. Are there two fuseboxes in this area, next to each other?
Thanks for you help Dave
splitjunkie
splitjunkie is offline
PostPosted: Tue Nov 05, 2024 7:30 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
There is only one fuse box up front. It's a 6 location fuse box.
Chris
dave1
dave1 is offline
PostPosted: Wed Nov 06, 2024 3:16 am    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
Hi Splitjunkie ,
Thank you for the pictures. I'm still a bit confused as a 52 wiring diagram shows another 3 fusebox next to the six fusebox. Where should this be located? Car manufacture is Feb 1952 if this helps.
diagram as shown
I appreciate the help Dave
wagen19
wagen19 is offline
PostPosted: Wed Nov 06, 2024 4:49 am    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
dave1 wrote:
Hi Splitjunkie ,
diagram as shown
Hello Dave,
the part "M4" you are probably referring is no fuse box, it´s the connector for three wires, two red-black ones for the brake light and the yellow-black for the horn. Have a look on the pics. Compare the symbols for the 3 fuse box in engine compartment "L 3"and the 3-connector beside the front fuse box "M 4". They are different.
finster
finster is offline
PostPosted: Wed Nov 06, 2024 8:10 am    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
the key/legend for each wiring diagramme is in the next column to the right
https://www.thesamba.com/vw/archives/info/wiring/4_52bug_key.jpg
google translate can help decipher the german
splitjunkie
PostPosted: Wed Nov 06, 2024 8:49 am    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
As others have said, M6 is the three position screw terminal block that you can partially see under part of the wiring harness in the pictures I posted.
Chris
virtanen
virtanen is offline
PostPosted: Wed Nov 06, 2024 9:03 am    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
I'm also putting wiring for my split right now and wonder why there is connector "M2", in-line from ignition switch to coil? Why not connect the wire direct to the switch?
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
dave1
dave1 is offline
PostPosted: Wed Nov 06, 2024 5:06 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
Hi all,
Nice one. Thank you for the feedback & information great help
Dave
splitjunkie
PostPosted: Wed Nov 06, 2024 7:47 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
I think it is there to give a spot for adding a radio or other accessory that needs to have switched 6 volts. Safer than having people messing around with screw terminals on the back of the ignition switch. Just a guess, but makes sense to me.
Chris
virtanen
virtanen is offline
PostPosted: Wed Nov 06, 2024 11:02 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
Yes, that makes sense. I can't find the M2 connector on my 48 instruction book, maybe added later. The schema is also rather messy there.
Mika
New projects
dave1
dave1 is offline
PostPosted: Fri Nov 08, 2024 1:40 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
Hi Splitjunkie,
Would it be possible to see what the M4 connector looks like so that I can purchase one through the forum
Thanks Dave
finster
finster is offline
PostPosted: Sat Nov 09, 2024 12:26 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
that's it near the bottom of this photo, they usually come in a strip and you cut off how many you want.
dave1
dave1 is offline
PostPosted: Sat Nov 09, 2024 1:10 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
Thanks Finster, thought it might be like that but wanted to make sure. Mine at present has a 3 way fusebox which I will change out
Thank you all
Dave
splitjunkie
PostPosted: Sat Nov 09, 2024 7:39 pm    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
This is a modern version. Certainly not exact, but gives you a pretty good idea how they look.
Chris
dave1
dave1 is offline
PostPosted: Sun Nov 10, 2024 10:52 am    Post subject: Re: 52 crotch cooler deluxe split fusebox Reply with quote
Thanks Splitjunkie
