Turn signal relay buzzing
walarson
walarson is offline
PostPosted: Fri Dec 06, 2024 2:54 pm    Post subject: Turn signal relay buzzing Reply with quote
My 76 FI bug sedan has a buzzing sound.
When I turn on the right turn signal I get no turn signal lights and the relay makes a pronounced buzzing sound.
Left turn signal lights work fine.
Turn signal relay going bad?
How do I test it?
Thanks in advance.
1976 FI Beetle Sedan
walarson
walarson is offline
PostPosted: Fri Dec 06, 2024 3:11 pm    Post subject: Re: Turn signal relay buzzing Reply with quote
How do I test it?
Thanks in advance.
One more piece of the puzzle.
I swapped out the relay and tried the signal lights.
Left signal is fine but the right signals flash very briefly and faster than normal.
Any ideas?
Thanks.
bsairhead
bsairhead is offline
PostPosted: Fri Dec 06, 2024 3:15 pm    Post subject: Re: Turn signal relay buzzing Reply with quote
It is telling you.
ashman40
ashman40 is offline
PostPosted: Fri Dec 06, 2024 5:11 pm    Post subject: Re: Turn signal relay buzzing Reply with quote
Check your bulbs. The corner turn signal bulbs should be a 21W/25W filament bulbs (1156 or 1157). These provide the proper load the stock flasher is expecting. Are you running a stock VW flasher relay?
Could your corner light assembly be miswired with the black/striped turn signal circuit being wired to the weaker 5W parking light bulb?
To troubleshoot turn signals start by disconnecting/removing the turn indicator lamp from the speedometer. Once you have all four corner lamps working as expected, reinstall the indicator lamp and retest.
Are you running LED bulbs (or lower wattage bulbs) in place of the stock incandescent bulbs? The stock flasher relay expect 21W bulbs in each corner. Using lower watt bulbs will cause the flasher relay to quick flash to indicate a bulb has burnt out. Lower the wattage even further and the flasher relay may stop flashing at all.
AshMan40
walarson
walarson is offline
PostPosted: Sat Dec 07, 2024 7:07 am    Post subject: Re: Turn signal relay buzzing Reply with quote
Thanks for the suggestions.
I have stock bulbs- no LEDs and the flasher relays are stock parts.
The signal lights were working correctly so I doubt it is a miswiring with the backup lights.
I have removed the turn signal lamp from the speedometer assembly and no change.
Also the voltage coming into the relay is fine.
I'll keep tracing wires and will let you know status.
Regards.
bsairhead
PostPosted: Sat Dec 07, 2024 7:31 am    Post subject: Re: Turn signal relay buzzing Reply with quote
So the lamps "bulbs" are good? Does it do the same thing with the hazard switch on?
walarson
walarson is offline
PostPosted: Sat Dec 07, 2024 9:03 am    Post subject: Re: Turn signal relay buzzing Reply with quote
The bulbs test fine.
Emergency flasher relay lights all bulbs correctly and no buzzing sound occurs.
Thanks for the suggestion.
ashman40
ashman40 is offline
PostPosted: Sat Dec 07, 2024 9:55 am    Post subject: Re: Turn signal relay buzzing Reply with quote
Remove the flasher relay. Using a jumper wire in place of the relay, jumper the #49 and #49a female openings in the relay bridge. This bypasses the flasher relay. The #31 position is left unused.
Leave the speedometer turn indicator lamp disconnected.
Turn the ignition switch ON and move the turn signal lever into the L position. Both front and rear corner turn signal lamps will turn ON and remain ON (no flashing).
Move the turn signal lever into the R position and confirm the right side corner lamps turn on solid. If the lights do not turn ON try wiggling the lever to see if the internal switch contacts are bad.
If the right side corner lamps do not turn ON, remove both right side turn signal bulbs and test that the contact at the bottom of the bulb socket has 12v. If not, there is a disconnect between the turn signal switch and the junction where the E-Flasher switch outputs merge with the turn signal outputs. Look under the steering column for the large black plug with the black/green right side turn signal wire. Follow this wire (not easy) until it merges with the black/green wire coming from the E-Flasher switch plug. Somewhere between these two plugs there is a disconnect.
AshMan40
walarson
walarson is offline
PostPosted: Sat Dec 07, 2024 10:12 am    Post subject: Re: Turn signal relay buzzing Reply with quote
I jumped the 49 and 49a terminals. Turned on the right turn signal switch and front and rear right lights come on and stay on. Same result with the left signal lights.
Could it be two bad relays? One is original and a second was a jbugs purchase a year ago?
ashman40
ashman40 is offline
PostPosted: Sat Dec 07, 2024 10:30 am    Post subject: Re: Turn signal relay buzzing Reply with quote
Are all four corner lamps the same brightness? For incandescent lamps the watt rating is directly related to brightness. All corners should have a 21W (or 25W) bulb. So should be around the same brightness.
Do you have a multimeter? Test the resistance to ground from the 49a relay bridge opening to ground. Move the turn signal lever into the L and R positions and measure the resistance thru the pairs of corner lamps. They should be similar in their resistance readings. A significantly higher/lower reading along either path could mean a short or mismatched bulbs. You could remove the corner lamps and test the resistance thru each individually to see if one of the right side ones is significantly different. For example, I have run into a front turn signal dual-filament bulb (1157) that should only be possible to be inserted in one orientation but was forced into the socket in the incorrect orientation (reversed). So while there was nothing wrong with the wiring, the turn signal was powering a 5W filament instead of the normal 25W filament.
Could you have two bad flasher relays? Maybe. The stock flasher relays are not simple devices. Many folks think flasher relays just work by heating up a bimetal element and when it warms up it opens the circuit until it cools then it closes the circuit once more. The VW flasher relay is a load sensing circuit. It expects a certain load before it starts working. The load can be generalized by the resistance to ground thru the circuit.
If you suspect both could be bad, just hop down to your FLAPS and find an "EP-35" flasher relay (any manufacturer). These are modern LED compatible flasher relays but still compatible with the VW turn signal circuit. The LED compatibility means they work with a wider range of circuit loads.
AshMan40
walarson
walarson is offline
PostPosted: Sat Dec 07, 2024 10:33 am    Post subject: Re: Turn signal relay buzzing Reply with quote
Fixed.
I was tracing and checking wires and noticed a wire in the rear wiring harness appeared to be only partially inserted. I reseated the wire, reinstalled the relay and the signal lights worked fine.
Duh. I am getting used to be an idiot.
bsairhead
PostPosted: Sat Dec 07, 2024 10:35 am    Post subject: Re: Turn signal relay buzzing Reply with quote
Sounds like terminal 31 doesn't have a proper ground.
walarson
walarson is offline
PostPosted: Sat Dec 07, 2024 11:29 am    Post subject: Re: Turn signal relay buzzing Reply with quote
That may have been part of the issue. Before I found the loose wire in the rear harness I put a new connector on the 31 ground and reattached. The relay still buzzed but the lights at least came on then when I reseated the rear wire things worked fine.
walarson
walarson is offline
PostPosted: Sun Dec 21, 2025 4:38 pm    Post subject: Turn signal relay buzzing round 2 Reply with quote
Ok round 2.
My right turn signal/buzzing relay issue has returned.
Left turn signals work fine.
Right turn signals come on but do not flash, but the relay buzzes.
Emergency flashers work fine.
I had a spare flasher relay and installed and got the same results.
I replaced the light bulbs and the fixtures are all new. I replaced a few ground wires and tightened up the remaining grounds with a needle nose.
For fun (desperation) I replaced the emergency flash switch and had the same results.
Thoughts? What am I missing?
Thanks in advance.
walarson
walarson is offline
PostPosted: Mon Dec 22, 2025 5:32 pm    Post subject: Re: Turn signal relay buzzing round 2 Reply with quote
walarson wrote:
Ok round 2.
Solved.
Bad flasher relay.
Quick trip to FLAPS and problem solved.
It had to be the relay. I'd sanded all ground points and replaced a few ground connections. The 31 relay ground got extra attention.
All bulbs were replaced and the mountings were all new.
Thanks in advance.
ashman40
ashman40 is offline
PostPosted: Thu Dec 25, 2025 7:59 pm    Post subject: Re: Turn signal relay buzzing Reply with quote
Some suggestions....
    Swap the left side turn signal bulbs to the right side and see if the problem moves to the left indicating it is a bulb problem. You say you swapped bulbs but I'm guessing you are using new bulbs. Try testing with known working bulbs.
    I suspect there is a difference in the resistance (load) between the left and right side circuits. I'm guessing your '76 is a SB? I'm not sure where the left side and right side corner turn signal wires come together. In the STD Beetles there was a 4-way junction where all the black/green (right) wires came together and another 4-way where the black/white (left) wires did the same. Here you could separate the corner wires and test each for resistance to ground. The path is longer for the rear wires so they show higher resistance, but both front wires thru the bulb filaments should be a similar resistance reading and both rear paths should be similar readings. If you find one path is much lower or higher resistance you have a problem. The higher the resistance the less current flows down the path. The stock flasher relays require a minimum current flow to flash properly. Too little current draw and they will hyper flash to let you know one bulb is out. If the current draw drops even more (eg. 2W LED bulb) the flasher relay will not flash at all.
    You could disconnect the wires from the turn signal switch below the steering column as well as disconnect the L and R wires at the E-Flasher switch. This should isolate the left and right sides of the circuit. Testing the resistance on the black/green and black/white wires at the E-Flasher switch should show similar resistance to ground readings.
    Next, remove all corner turn signal bulbs and recheck the resistance. Since you remove the bulbs there should no longer be a path to ground and your readings should show infinite resistance (open circuit). If you still show resistance to ground it means there is a short in one of the wires. I don't think this is what your problem is but you can check.
    Reinstall one corner bulb at a time and measure the resistance to ground. This resistance will be thru the one bulb. This should give you and idea of the resistance down each path. Both rear paths should have higher but similar resistance readings. The fronts should be less resistance than the rears but should be similar left to right as their paths are similar in length (technically, the fuse box is located closer to the driver's side making the passenger side length slightly longer = slightly more resistance).
AshMan40
walarson
walarson is offline
PostPosted: Mon Dec 29, 2025 5:34 pm    Post subject: Re: Turn signal relay buzzing Reply with quote
Greetings.
In the end I purchased a new flasher relay and the problem was solved. I suspected something was wrong when the two existing relays when swapped in each caused slightly different problems.
At least now I have a good collection of spare bulbs.
Appreciate the insights.
ashman40
ashman40 is offline
PostPosted: Tue Dec 30, 2025 11:11 am    Post subject: Re: Turn signal relay buzzing Reply with quote
Do you mind me asking what make/part# your new flasher relay is? Is it an LED compatible flasher relay? LED compatible relays work well with a large range of loads from the corner bulbs.
AshMan40
walarson
walarson is offline
PostPosted: Tue Dec 30, 2025 4:58 pm    Post subject: Re: Turn signal relay buzzing Reply with quote
Certainly. This was purchased at O'Reillys for about ten dollars.
ashman40
ashman40 is offline
PostPosted: Wed Dec 31, 2025 8:00 am    Post subject: Re: Turn signal relay buzzing Reply with quote
Ahh yes, EP35 flasher relay. Good choice for a modern LED compatible relay. They are readily available and relatively cheap.
Very Happy
AshMan40
