Fun With VDubs Samba Member
Joined: October 05, 2023 Posts: 87 Location: Northern Illinois
Posted: Fri Dec 13, 2024 3:20 am Post subject: Heater Channel Baffles |
Looking through the ankle vents and down the defroster tube openings I notice there are baffles directing the air through the heater channels. How far rearward do they extend from the defroster tubes? The reason I ask is that I'm installing a diesel heater up front and am running the hot air in the opposite direction through the channels. I'd like to cut a pair of new vents into the channel just behind the front seats. _________________ Swing on over to our YouTube channel. There we post work we're doing on our VWs, and the adventures we take them on.
@FunWithVDubs |
aquifer  Samba Member
Joined: August 30, 2021 Posts: 333 Location: Nebraska
Posted: Fri Dec 13, 2024 6:06 am Post subject: Re: Heater Channel Baffles |
I’m 63% sure that the heated air runs in a metal tube inside what is always called the heater channels. That may not be true for aftermarket “heater channels”, but when I restored my first 67, I had to repair a rust hole in the bottom of the driver side channel, and I could see inside there. I was surprised to learn that there is a tube inside the channel that is actually where the air goes.
Maybe what I remember seeing was just part of the short tube that directs air to the heater channel from under the back seat, and doesn’t actually run the whole way forward. The rust hole was toward the back of the heater channel, so it’s possible that’s what I remember seeing. It’s been 25-30 years ago, which is why I’m not 100% sure!
Someone here will know for sure. You might edit your post to show what year your car is. Maybe VW did it different over time. _________________ Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown).
Also looking for used white headliner pieces, both perforated and non-perforated. |
finster Samba Member
Joined: May 26, 2012 Posts: 9973 Location: not far from the madding crowd
Posted: Fri Dec 13, 2024 8:17 am Post subject: Re: Heater Channel Baffles |
see this thread - https://www.thesamba.com/vw/forum/viewtopic.php?p=9990308
the inner tube runs from the rear inlet to the front
you will have trouble feeding anything into it - if you remove the bottom plate then you can replace the inner heater tubes - this guy used 2" dia galvanised tubing
_________________ "we're here on Earth to fart around" kurt vonnegut
Posted: Fri Dec 13, 2024 8:20 am Post subject: Re: Heater Channel Baffles |
aquifer wrote: |
Someone here will know for sure. You might edit your post to show what year your car is. Maybe VW did it different over time. |
Right you are about me needing to specify the year, it's a 1960. I did notice that our '70 Beetle does have round tubes running through the heater channels. I guess I should ask; in the earlier years did they have these separate heating tubes? _________________ Swing on over to our YouTube channel. There we post work we're doing on our VWs, and the adventures we take them on.
@FunWithVDubs |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11040 Location: Oregon
Posted: Fri Dec 13, 2024 9:06 am Post subject: Re: Heater Channel Baffles |
https://www.thesamba.com/vw/forum/viewtopic.php?t=493257
The thread above is a heater channel replacement on a 60 Cabriolet.
It should be the same for your 60 sedan. Scroll down and you can see the remnants of the rusted out inner heat transfer tube. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Fri Dec 13, 2024 9:12 am Post subject: Re: Heater Channel Baffles |
dec 56 was the introduction of the inner heater tubes _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
