Heat exchanger fresh air inlet flap box
Who.Me?
Who.Me? is offline
PostPosted: Fri Dec 20, 2024 2:34 am    Post subject: Heat exchanger fresh air inlet flap box Reply with quote
Anyone ever cut open the fresh air inlet part of the later style heat exchanger?
I'm wondering if it's possible to shave the top down a little to improve fitment in early buses/trucks where the later style clashes with the firewall?
I know some folks remove the HE and install after installing the engine, but that's a pain to do (restricted access, getting it in round tinware etc.), so I'm wondering whether it's possible to reduce the height.
The closest to a cutaway I've found is this, but it's too blurry to see whether the flap extends right to the top of that 'box' at the inlet end.
I've already hammered down the seam, which helps a little. Just wondering if it's possible to gain a little more space?
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Dec 20, 2024 6:04 pm    Post subject: Re: Heat exchanger fresh air inlet flap box Reply with quote
Uncrimp the double exit valve on the rear of the head of the heat exchanger. Then you can see what is inside. Maybe you could drop that area just above the pivot for the flapper valves down a 1/4" or so.
Think if you cut a 1/2 to 3/4"wedge out of the forward side of the neck of the heat exchanger you could tilt the top front end forward and downward some to get a lot more clearance.
In Stereo, Where Available!
Who.Me?
Who.Me? is offline
PostPosted: Sat Dec 21, 2024 6:39 am    Post subject: Re: Heat exchanger fresh air inlet flap box Reply with quote
Thanks. The picture in that serivice note suggests that might work.
Andy
Stocknazi
Stocknazi is offline
PostPosted: Sat Dec 21, 2024 8:07 am    Post subject: Re: Heat exchanger fresh air inlet flap box Reply with quote
If you are successful can you post a pic of the area you are cutting out.
Never thought about bending that seam over for clearance; that's a good idea.
WANTED:
Thomas Jefferson
