alidabiri Samba Member
Joined: December 01, 2024 Posts: 31 Location: Gaston, SC
Posted: Thu Jan 09, 2025 2:17 pm Post subject: 1972 assist strap installation |
Hi folks.
Anybody knows (with pictures) how to install the assist strap on a 1972 VW Super Beetle? I have the strap and the coat hanger cover and I can see the two vertical holes on the car, but don't know how to install. It seems that the the cover not fitting the strap. Any ideas?
NJ John Samba Member
Joined: September 21, 2007 Posts: 2882 Location: HdG, MD & NJ
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Mon Jan 13, 2025 9:37 am Post subject: Re: 1972 assist strap installation |
Google "ankle strap installation" for more info.
 _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Mon Jun 02, 2025 5:14 pm Post subject: Re: 1972 assist strap installation |
Hi folks.
I'm trying to install side chrome moldings on my 72 Super Beetle. The car had been applied putty and had been painted. There are supposed holes where the clips for the chrome moldings go. I could find under the front hood where the holes and the broken clips were, but I have no idea where these holes for the clips are on the door or the rear quarter panels. Any help would be greatly appreciated. |
viiking Samba Member
Joined: May 10, 2013 Posts: 3155 Location: Sydney Australia
Posted: Tue Jun 03, 2025 5:52 pm Post subject: Re: 1972 assist strap installation |
Remove the rear "door card" and have a look for the rear quarter. If the holes have bondo in them you'll see the extruded sausage. If it's welded then you'll probably see the nib of the weld. Use that distance from the waist line indent to find the correct heights. Then do the same with the front door card although this will be harder to get to. You can probably just use the rear measurement to reproduce to the front.
So long as you have the correct distance to the waist line you can always just drill new holes without even trying to line up with the old holes. The clips will slide to anywhere.
AFAIK the chrome strips were at slightly different heights depending on year model. So long as they line up. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Tue Jun 03, 2025 7:02 pm Post subject: Re: 1972 assist strap installation |
viiking wrote: |
AFAIK the chrome strips were at slightly different heights depending on year model. So long as they line up. |
thank you so much. I think this will work as you described. I have to drill holes, I think. I measured the thickness of the clip head that goes into the hole with calipers. It is 4mm. So, I have to find a 4mm drill bit and line up the holes below the waist line. thanks again. I have to start with lineup of the front hood and line everything up with that. thanks again. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33076 Location: Hot Arizona
Posted: Wed Jun 04, 2025 7:03 am Post subject: Re: 1972 assist strap installation |
This will likely offend you, but if this gives you significant trouble, you may want to stay away from an oil change, valve adjustment, or spark plug change. Because this should be quite straightforward.
The two screws go through the strap holes, then through the seat belt hook, and into the VW body. Then the cover slips over that, see photo from the 1971 owner's manual.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6124 Location: 37.5N 77.1W
Posted: Wed Jun 04, 2025 8:51 am Post subject: Re: 1972 assist strap installation |
KTPhil wrote: |
I've always called them 'Stirrups'  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 340 Location: Eastern north carolina
Posted: Thu Jun 05, 2025 10:55 am Post subject: Re: 1972 assist strap installation |
To make the molding install easier before you drill do some measurements. On one end of each panel put a pencil mark at the distance down from the indent you found when you took off the rear seat trim panel(aka door card) . Take the molding to be installed on that panel and place it with the top edge aligned with the marks you made. Extend the pencil line from one end to the other. Drill your holes along this line. This will insure you follow any curvature in the molding length. Good luck |
Chinaclipper Samba Member
Joined: October 03, 2019 Posts: 810 Location: Somewhere in the great Midwest
Posted: Fri Jun 06, 2025 8:28 am Post subject: Re: 1972 assist strap installation |
WIth apologies to Cusser et al...
I am doing a similar task now;1971 Super Beetle.
I put the headliner in already, and don't know just where to locate the screw holes for the assist straps. They are there, I just can't see 'em. Got all the parts. Can someone help or direct me?
Maybe you have a bug in the earlier stages of putting in the headliner, or yours doesn't have it one yet? Pictures or measurements?
Otherwise, it's gonna just be "poke and pray".
Did that with the visor installations-it wasn't too appealing, or pretty.
Just get me in the ballpark. I need the "A" and "B" distance...in metrics (mm) please if possible. After all, it is a VW...
_________________ China Clippers Official 1971 Super Beetle Project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=728089&highlight= |
talljordan Samba Member
Joined: January 10, 2012 Posts: 1099 Location: San Francisco, CA
Posted: Fri Jun 06, 2025 10:10 am Post subject: Re: 1972 assist strap installation |
I did the same thing, you can feel the screw holes if you poke your pinky finger around. Just give it some prodding with your pinky, then confirm with a phillips screwdriver.
The place it goes is also a bit of a flat platform. You should feel the ridge towards the rear of the car a few mm behind the screw holes. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Posted: Sun Jun 08, 2025 1:50 pm Post subject: Re: 1972 assist strap installation |
talljordan wrote: |
The place it goes is also a bit of a flat platform. You should feel the ridge towards the rear of the car a few mm behind the screw holes. |
Great advice! Apologies to alidabiri for somewhat hi-jacking his thread, but....
I guess I needed a bit of a push too, so got that as well. For those who may come after me, and with the same requests.
"A" (see previous post) is 30 mm. You don't need "B". As noted above, you can CLEARLY see/feel the outlines of the little "platform", so.... bada bing bada boom,
And finished.. Yes it's the original, 50+ years old like the rest of the car... And I like it. _________________ China Clippers Official 1971 Super Beetle Project!
Cusser Samba Member
my3bugs Samba Member
Joined: June 18, 2003 Posts: 858 Location: Moreno Valley
Posted: Sun Jun 08, 2025 5:25 pm Post subject: Re: 1972 assist strap installation |
ya ill mine broke including modern replacements . i dont bother anymore . |
