74 no cables to fresh air vents...
vwfye
vwfye is offline
PostPosted: Mon Jan 13, 2025 8:33 pm    Post subject: 74 no cables to fresh air vents... Reply with quote
So
Where do I look to shut the vents for the winter? Thank you!
64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK"
Teeroy Premium Member
Teeroy is offline
PostPosted: Mon Jan 13, 2025 11:24 pm    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
Knobs under dash on driver side open and close flappers in the ducts by the hood hinges. There is a piano wire from each knob from the levers, passenger side runs through small diameter tube across dash
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
vwfye
vwfye is offline
PostPosted: Tue Jan 14, 2025 12:46 am    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
Nothing under there
1974 Ghia "PUK"
Redlabel6
Redlabel6 is offline
PostPosted: Tue Jan 14, 2025 6:53 am    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
On a '74, there should be two knobs below the radio, above the ash-tray. Those should turn the vents off.
If those are missing, you have no way to turn them off.
d
1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe
vwfye
vwfye is offline
PostPosted: Tue Jan 14, 2025 7:54 am    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
There is no where to manually close them until spring? Cables and all dash related items for fresh air are gone.
1974 Ghia "PUK"
vwfye
vwfye is offline
PostPosted: Tue Jan 14, 2025 10:57 am    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
Hey all, is the flap control set up this same way in a 1974 coupe? If so, I see a temporary solution. Whew!
1974 Ghia "PUK"
Teeroy is offline
PostPosted: Tue Jan 14, 2025 12:22 pm    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
That picture looks like my 70. You can always tape up the vent grills out front if all the flaps and cables are gone
ARR #3
vwfye
vwfye is offline
PostPosted: Tue Jan 14, 2025 1:22 pm    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
If I can get to the arm, I will just wire it closed for now. I just need there to be less cold air coming in than the heater can compete with. 33f was a bit brisk this morning with the dash vents blowing cold air.
1974 Ghia "PUK"
vwfye
vwfye is offline
PostPosted: Tue Jan 14, 2025 3:43 pm    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
Alright. I found the levers, but I can't tell whether toward the nose, or toward the cab is closed.
Anyone happen to know?
Thank you!
1974 Ghia "PUK"
vwfye
vwfye is offline
PostPosted: Tue Jan 14, 2025 10:32 pm    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
They are closed. What a difference!
1974 Ghia "PUK"
Dave
Samba Elder
Dave is offline
PostPosted: Wed Jan 15, 2025 10:21 pm    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
you're welcome, vwfye/1slo3/Vader did I miss any? Cool
2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter"
vwfye
vwfye is offline
PostPosted: Wed Jan 15, 2025 10:23 pm    Post subject: Re: 74 no cables to fresh air vents... Reply with quote
Grumpy, cantankerous, annoyed and old guy...
You were close Wink
1974 Ghia "PUK"
