Searching for a good mechanic/mobile mechanic in San Diego
certifr1ed
certifr1ed is offline
PostPosted: Wed Jan 29, 2025 11:51 am    Post subject: Searching for a good mechanic/mobile mechanic in San Diego Reply with quote
In need of a vacuum pump delete, i have already purchased the block off plate and i am in need of a good mechanic to install it. im having a hard time finding a shop to do it and i dont feel comfortable doing it myself.
i have 2013 jetta 2.5l auto, please give me some leads.
thank you
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Wed Jan 29, 2025 2:16 pm    Post subject: Re: Searching for a good mechanic/mobile mechanic in San Diego Reply with quote
The vacuum pump for the brakes, right? Shops probably don't want to do the delete because it changes the braking system and they don't want to deal with the liability issues. For the brakes to work properly (or perhaps at all Shocked ), there would need to be an alternate vacuum source (more modifications). Is the old pump leaking? Here's a video that shows how to replace it:
https://www.youtube.com/watch?v=TvMWRCR7y_E
It doesn't look super complicated. One of those "take your time and plenty of photos" tasks. Time consuming, but manageable.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Jan 29, 2025 3:04 pm    Post subject: Re: Searching for a good mechanic/mobile mechanic in San Diego Reply with quote
Maybe search here?:
https://www.thesamba.com/vw/forum/viewforum.php?f=11
and maybe check this I found with a google search:
https://www.vwvortex.com/threads/vacuum-pump-delete.6906285/#replies
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
certifr1ed
PostPosted: Wed Jan 29, 2025 3:44 pm    Post subject: Re: Searching for a good mechanic/mobile mechanic in San Diego Reply with quote
thanks for the reply yes i was planning on using that guide and for the brake booster vacuum line i was going to tap into the n80 valve purge line as recommended in le0n guide on vwownersclub
