3” Lift Spindles
Derickpete
Derickpete is offline
PostPosted: Thu Feb 06, 2025 12:56 pm    Post subject: 3” Lift Spindles Reply with quote
Do anyone know where I can buy 3” lift spindles for a 1960 bug. Or does anyone have any photos of making them from using a second pair of spindles.
BFB
BFB is offline
PostPosted: Thu Feb 06, 2025 7:58 pm    Post subject: Re: 3” Lift Spindles Reply with quote
Couple guys in the classifieds sell them.
Blindchicken racing has a page on building them.
Most experts aren't.
Mal evolent
Mal evolent is offline
PostPosted: Fri Feb 07, 2025 10:56 am    Post subject: Re: 3” Lift Spindles Reply with quote
my advice is get Thing spindles and trailing arms. sturdier, both ball joints point the right way, speedo cable hole. I say this in part because I already have mine, so I won't be competing with anyone to buy a set.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
Derickpete
PostPosted: Fri Feb 07, 2025 3:41 pm    Post subject: Re: 3” Lift Spindles Reply with quote
I went through the classifieds and only see drop spindles for link pin front ends. I cannot find a supplier for raised spindles.
BFB
BFB is offline
PostPosted: Fri Feb 07, 2025 5:40 pm    Post subject: Re: 3” Lift Spindles Reply with quote
OP said 1960, so KP not BJ. I almost missed that too and offered him a set of 4” raised BJ spindles i have for sale.
https://www.thesamba.com/vw/classifieds/detail.php?id=2361840
http://www.blindchickenracing.com/How_to/Lifted_Spindles/Raisedspindles.htm
They do BJ spindles but it’s the same process with KP, ive done a couple.
Kustom1warehouse.net Premium Member
Kustom1warehouse.net is offline
PostPosted: Tue May 13, 2025 10:30 am    Post subject: Re: 3” Lift Spindles Reply with quote
[/img]
Schepp
Schepp is offline
PostPosted: Tue May 13, 2025 12:46 pm    Post subject: Re: 3” Lift Spindles Reply with quote
I'm using K1W's 3" BJ spindles. The quality of the welds are top notch all around!
trilogymac
trilogymac is offline
PostPosted: Wed May 14, 2025 5:40 am    Post subject: Re: 3” Lift Spindles Reply with quote
Russell at Old Speed makes 2-1/8" link pin lift spindles. I went this route with Airkewld adjusters for 4-1/4" overall lift.
Rear will be large nut RGB's with approx 1" lift on the spring plates.
Hope this helps.
Bill
Crogg
Crogg is offline
PostPosted: Wed May 14, 2025 11:11 am    Post subject: Re: 3” Lift Spindles Reply with quote
You can find lifted combo spindles. I recommend this as they are a lot stronger to take the stress of where the spindle is. Yes! You will need BJ backing plates and new tie rods and figure out modifications for your idler arm to accept the heim joint or larger style tie rod end!
I dont run lifted... but i am very happy with my combo spindles!
mnelsonvw
mnelsonvw is offline
PostPosted: Wed May 14, 2025 2:57 pm    Post subject: Re: 3” Lift Spindles Reply with quote
I have the Kustom1 spindles on a 73 standard. Had them on for two years and love them.
MattyMatt
73 standard beetle
