Transaxle big nut pinion and bearing question
flashbackbug
flashbackbug is offline
PostPosted: Fri Feb 21, 2025 6:33 pm    Post subject: Transaxle big nut pinion and bearing question Reply with quote
My pinion bearing does not have any notches in it to stake the pinion nut. Should I grind notches and dress the threads with a thread file so I can stake the nut or just use loctite knowing that I will have to cut the nut off next time (if there is a next time)?
Casting Timmy
Casting Timmy is offline
PostPosted: Sun Feb 23, 2025 3:52 pm    Post subject: Re: Transaxle big nut pinion and bearing question Reply with quote
Blue Loctite is what I use there, don't go all the way around just a small area and then put it on.
T1 IRS Rebuild Book on Lulu.com
http://www.lulu.com/shop/tim-marshall/t1-irs-transaxle-book/paperback/product-24055997.html
As seen in Volks America Issue 14 Page 11 (Full page review)
flashbackbug
PostPosted: Mon Feb 24, 2025 6:33 am    Post subject: Re: Transaxle big nut pinion and bearing question Reply with quote
Thanks
mcmscott
mcmscott is offline
PostPosted: Mon Feb 24, 2025 8:54 am    Post subject: Re: Transaxle big nut pinion and bearing question Reply with quote
I use 271(red) and torque to 160, never had a problem removing them afterwards
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
