Smith's Speedometer not working
csmith181
csmith181 is offline
PostPosted: Sun Mar 02, 2025 3:01 pm    Post subject: Smith's Speedometer not working Reply with quote
So I've searched the forums and this topic hasn't come up as far as I can tell..
After multiple odometer failures and frustrations from having slightly larger tires messing up the accuracy of the speedo, we decided to go ahead and get one of the new Smith's electronic speedos from CIP1. It has a settable odometer and calibratable speed settings as well as electronic trip odometer and looks original (except for the LCD odo and reset button)
The instructions were a tad thin, but I was able to sort it all out.
However it doesn't work.
I've swapped the old speedo back in to double check that the cable is still spinning properly, even through the EGR box, and it still works.
I believe the issue is the sensor that connects to the original speedo cable (replaces the EGR box, a bonus in my mind) needs a square drive that is significantly larger than what's on the cable. It did need an adapter for the cable to screw onto the sensor (not documented BTW) and there were missing screws from the kit, so perhaps there is a missing square-drive fitting??
Anyone have experience with these in late busses, or am I on the bleeding edge here?
TIA!
SGKent Premium Member
SGKent is offline
PostPosted: Sun Mar 02, 2025 3:09 pm    Post subject: Re: Smith's Speedometer not working Reply with quote
bleeding edge. Call the manufacturer tech support is what I would do.
aeromech
aeromech is offline
PostPosted: Mon Mar 03, 2025 8:59 pm    Post subject: Re: Smith's Speedometer not working Reply with quote
No experience with smiths speedos but their tach seem to look and work well
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
