59Canadian Samba Member
Joined: May 23, 2020 Posts: 11 Location: Ontario, Canada
Posted: Wed May 07, 2025 4:25 pm Post subject: Exhaust fumes in cabin, holes behind rear seat |
My wife has been pointing out for a while now that there is always a strong smell (to her) of exhaust fumes in the cabin of our car. I’ve been riding in and driving old cars since I was a kid so I don’t really notice it that much, but I feel I should try and get to the bottom of it.
My car has had the heating system removed so it’s definitely not anything to do with heat exchangers or anything like that. All of the holes under the rear seat appear to have been patched and sealed properly.
While checking around for the source of the fumes, I discovered 2 holes in the sheet metal on each side of the car, directly beside the rear seat back. They appear to be factory holes to allow access to something behind the metal, possibly the fasteners for the exterior trim piece. Could these holes be the source of the exhaust fumes being drawn back into the car? Are these holes supposed to be plugged and the PO didn’t bother replacing them after the car was painted?
I’ve attached some photos for reference.
Thank you.
zerotofifty Samba Member
Posted: Wed May 07, 2025 8:46 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
Assure the engine bay pillows are installed. These go in the pillar openings on either side of engine bay, these will keep fumes out and reduce noise. see link
https://www.thesamba.com/vw/forum/viewtopic.php?t=734234&highlight=pillows
in our old Bugs the pillows were made of upholstery scraps, later bugs used expanding foam the expanding foam however tended to trap moisture between it and the sheet steel, resulting in bad rusting. The cloth pillows can breathe, and thus will not trap water. many late Bug has this area, right behind the rear quarter window rust thru completely do to the expanding foam.
use of pillows can prevent the smells from getting from engine bay to the cabin
check that yours is present. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Joined: April 27, 2002 Posts: 6751 Location: Pentwater, Michigan
Posted: Thu May 08, 2025 6:57 am Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
There was someone selling reproduction pillows for the engine bay but I'm not finding them now. They were triangular shaped. Really any kind of fabric shoved in the cavity would work. _________________ Roads Scholar
Member# 2059 |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6126 Location: 37.5N 77.1W
Posted: Thu May 08, 2025 8:01 am Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
put the tool box on the floor. Front end collision will turn it into blunt trauma to the back of your wife's head.
As for your concerns over the holes, maybe fill the holes with expanding foam from a can. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1413 Location: San Diego
Posted: Thu May 08, 2025 7:22 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
tasb wrote: |
There was someone selling reproduction pillows for the engine bay but I'm not finding them now. They were triangular shaped. |
Here you go ...
https://www.thesamba.com/vw/classifieds/detail.php?id=1742547 _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Thu May 08, 2025 8:54 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
runamoc wrote: |
As for your concerns over the holes, maybe fill the holes with expanding foam from a can. |
No, foam can hold moisture against the body, and thus cause corrosion.
Them holes can be covered with tape. HVAC aluminum foil tape will work well on them there holes.
like here...
https://www.amazon.com/Pack-Professional-Grade-Alu...1&th=1
As for the box, I do much like the choice in caliber _________________ Sorry About That Chief.
Words to live by. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3342 Location: Memphis
Posted: Mon May 12, 2025 7:10 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
I like to share 3M's tech youtube any time these kind of topics come up!
Here's one with an overview on their foams:
And this one is about installing it:
Foams and adhesives are a SCIENCE. They are engineered for specific areas, with specific goals. The automotive collision industry has volumes of great information people like us can use to make good choices using products that weren't even on the radar 50, 60 years ago! _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Mon May 12, 2025 11:36 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
scrivyscriv wrote: |
Foams and adhesives are a SCIENCE. They are engineered for specific areas, with specific goals. The automotive collision industry has volumes of great information people like us can use to make good choices using products that weren't even on the radar 50, 60 years ago! |
Given the problems of rust when VW used the foam in the location we is discussing, Id avoid foam there. Foam was also factory used on another car I own, a 914, and it has caused rust also. it can trap water between it and the panel. Unless you can be assured it stays dry, it can be a problem. The breathability of the pillow is good, they work for the intended purpose. That is the science
see links for some gore that is the result of "death foam" used in late VW Bugs...
https://www.thesamba.com/vw/forum/viewtopic.php?t=738766&highlight=rust+foam
https://www.thesamba.com/vw/forum/viewtopic.php?t=792302&highlight=rust+foam
https://www.thesamba.com/vw/forum/viewtopic.php?t=787834&highlight=rust+foam
Words to live by. |
Posted: Tue May 13, 2025 2:32 am Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
I thought about that. But it seems like the late model foam problem stems from the crescent vents. I know I’ve pulled foam out of my C pillars in my ‘67 bug and I don’t have any of the death foam rot associated with late models.. notice all the topics you linked to are exclusively late model.
I’m betting it’s a combination of wind-driven moisture intrusion from the crescent vents, and an absorbent foam behind them. I’ve been looking into the 3M foam for a while now and I think I may give it a go. _________________ Robert in Memphis
Posted: Tue May 13, 2025 6:27 am Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
Water may enter via the window seals leaking as there is a pathway in the window channel. Water may wick in via the fender bolts. water may wick in at roof seam.
Water may enter from washing engjne bay. in cold humid conditions, condensation can also wet the foam by water dripping down the C channel from roof arch.
Note in the photo the drain holes in window seal channel, and caulking cracks at roof seam, two possible pathways for water to enter the death foam zone.
I highly advise against the use of the foam. _________________ Sorry About That Chief.
Words to live by. |
Posted: Tue May 13, 2025 2:23 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
Please let me preface with this: I don’t mean to be contentious.
Unfortunately advanced topics like body foams and adhesives tend to be quite polarizing, and it’s not just on VW forums. Without an engineered design to follow - because modern NVH and structural foams weren’t in the industry when our cars were being produced - everyone is just speculating on what is or isn’t a good idea.
Adhesives and seam sealers have a better defined role but you see topics all the time with guys completely misusing, say, 3M 08116 panel adhesive, explaining their rationale in a way that shows they have no idea what the OEM repair industry actually says you can and can’t do with it.
I admit foams are a big unknown for most of us, and we’ve all pretty much just seen the late model death foam as a reference for what poorly engineered foam practice can do. But surely it’s not as easy as “foam bad, pillows good.”
I really do believe the evidence shows “death foam” being directly caused by the added crescent vents. C-pillar foam isn’t exclusive to late models, but the corrosion perforation in that area is.
Here’s a topic of relevance
https://www.thesamba.com/vw/forum/viewtopic.php?t=706621&highlight=death+foam _________________ Robert in Memphis
Posted: Tue May 13, 2025 2:48 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
Quote: |
foams are a big unknown |
When I use foam, be it sound dampening or filler, I always use closed cell foam. It doesn't suck up water like a sponge, an open celled foam. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Posted: Tue May 13, 2025 9:39 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
https://www.thesamba.com/vw/forum/viewtopic.php?t=706621&highlight=death+foam |
Anyway for water to get in there can cause water to be trapped between the foam and the body. Granted the vent found on late model Bugs is a known source of water, but there are other ways for water to get in as has been listed. (plus sun roof leaks, and leaks from the belt line body trim strip mounting holes)
What it comes down to if it is known that the foam can trap the water against the body and cause rust, this does not appear to be a problem with the pillows, so then, why install the foam rather than the pillows? If any of the other water entry points allow water in, and you have foam, then you will likely have a very bad rust problem. There is no need for the foam, it is a potential HUGE problem, the pillows do not have this problem. Thus I think it is a bad idea to use foam. That is the science I trust in. You may have other reasoning.
Where we is talking about, foam is a bad choice in my opinion. you can not access the body insides once the foam is installed, you can not see the rust until it is poking thru, by which time it is much too late. I see no up side to using it, only down sides, potentially a big expensive down side.
But hey, if some folks want to try it, be trendy, be modern, or what ever other reason, well it is your ride, so your choice.  _________________ Sorry About That Chief.
Words to live by.
Posted: Tue May 13, 2025 9:45 pm Post subject: Re: Exhaust fumes in cabin, holes behind rear seat |
runamoc wrote: |
When I use foam, be it sound dampening or filler, I always use closed cell foam. It doesn't suck up water like a sponge, an open celled foam. |
I believe the issue is not that it is open cell, in the Bugs I am pretty darn sure it is closed cell, and over time its adhesion is lost to the body panel, so it pulls back ever so little, just enough to allow water to get between the body and the foam, and there the foam holds the water against the body. this is a similar effect to placing a non breathing plastic tarp on the car and allowing a bit of moisture to get trapped. you may have seen the result, paint failing, rust coming thru the paint if the plastic tarp is left on the car for a long time.
The foam in the early 70's 914s was closed cell, yet it caused a lot of rust thru issues, much like is seen on the Bugs that used foam. It is a curse from Hell as far as I am concerned.
The pillows work fine, and have no rust issues associated with them. _________________ Sorry About That Chief.
Words to live by. |
