volky1970 Samba Member
Joined: November 11, 2006 Posts: 393 Location: A very hot Island with BUGS that KILL!!!
Posted: Fri May 09, 2025 5:35 am Post subject: B+ alternator bolt hot to the touch... |
Hi,
So yesterday I was warming up my car as usual and I decided to just touch the B+ terminal on the alternator and instantly gave me a blister.
I don't recall ever having this issue. Just popped up!
What could it be? Loose connection somewhere? B+ is tight.
Thanks. _________________ 1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52578 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 09, 2025 7:13 am Post subject: Re: B+ alternator bolt hot to the touch... |
Just because it's tight doesn't mean it's making good contact, take the connection apart and shine up all the parts, apply a little grease when reassembling as well to prevent corrosion.
You'll probably want to disconnect the battery before this job, unless you like excitement.  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri May 09, 2025 7:20 am Post subject: Re: B+ alternator bolt hot to the touch... |
busdaddy wrote: |
You'll probably want to disconnect the battery before this job, unless you like excitement.  |
Hi,
Thanks for the quick reply. The B+ terminal is nice and shiny. No rust at all on it or around the area.
I was thinking of putting in a new wire, just have to see the wire thickness and how it runs in the car.
Here's the car...
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4119 Location: Georgia
Posted: Fri May 09, 2025 8:30 am Post subject: Re: B+ alternator bolt hot to the touch... |
You’re making me want to touch mine.
Recently, I noticed mine had come loose. Not loose enough to come off but loose enough for an arc to happen that burned the post almost in half. In fact it broke in half when I tried to tighten it. Luckily I still had enough threads to save the situation. Now I check it every time before I start the car. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Fri May 09, 2025 8:31 am Post subject: Re: B+ alternator bolt hot to the touch... |
jeffrey8164 wrote: |
Recently, I noticed mine had come loose. Not loose enough to come off but loose enough for an arc to happen that burned the post almost in half. In fact it broke in half when I tried to tighten it. Luckily I still had enough threads to save the situation. Now I check it every time before I start the car. |
I guess I'll give it a little wiggle when I get home. _________________ 1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors. |
Posted: Fri May 09, 2025 9:57 am Post subject: Re: B+ alternator bolt hot to the touch... |
volky1970 wrote: |
busdaddy wrote: |
Hi,
Thanks for the quick reply. The B+ terminal is nice and shiny. No rust at all on it or around the area. |
It doesn't matter how good it looks, take it apart and see if it's just as pretty on the surfaces that make contact, bet ya there's some discoloration or corrosion. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25797 Location: Olympia Wash Rinse & Repeat
Posted: Fri May 09, 2025 10:25 am Post subject: Re: B+ alternator bolt hot to the touch... |
Even if the connection surfaces look clean it could be corroded just enough when pushing so many amps.
Had problem with starter turning over well. Cleaned the starter to transaxle surfaces and dielectric greased up, which improved the situation a notable amount. Pulled the starter solenoid off to do same between those parts and those surfaces looked nice and clean. Went ahead with the cleaning and greasing, and BOOM made huge difference. _________________ In Stereo, Where Available! |
Posted: Fri May 09, 2025 10:47 am Post subject: Re: B+ alternator bolt hot to the touch... |
Eric&Barb wrote: |
Had problem with starter turning over well. Cleaned the starter to transaxle surfaces and dielectric greased up, which improved the situation a notable amount. Pulled the starter solenoid off to do same between those parts and those surfaces looked nice and clean. Went ahead with the cleaning and greasing, and BOOM made huge difference. |
Super. I disassemble when I get home. _________________ 1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16485 Location: North Florida, USA
Posted: Fri May 09, 2025 5:16 pm Post subject: Re: B+ alternator bolt hot to the touch... |
Is the B+ wire the stock sized 6.0mm^2 wire (equivalent of 9AWG) or something else? A smaller diameter wire would increase the resistance and cause heat to build up. _________________ AshMan40
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4397 Location: viroqua wi.
Posted: Fri May 09, 2025 6:58 pm Post subject: Re: B+ alternator bolt hot to the touch... |
ashman40 wrote: |
Is the B+ wire the stock sized 6.0mm^2 wire (equivalent of 9AWG) or something else? A smaller gauge wire would increase the resistance and cause heat to build up. |
Smaller the gauge larger the wire  |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3539 Location: 802 The Pointless Forrest
Posted: Sat May 10, 2025 3:32 am Post subject: Re: B+ alternator bolt hot to the touch... |
volky1970 wrote: |
I guess I'll give it a little wiggle when I get home. |
Quote worthy _________________ "Albatross"! |
Posted: Sat May 10, 2025 7:25 am Post subject: Re: B+ alternator bolt hot to the touch... |
bsairhead wrote: |
ashman40 wrote: |
Is the B+ wire the stock sized 6.0mm^2 wire (equivalent of 9AWG) or something else? A smaller diameter wire would increase the resistance and cause heat to build up. |
Doh! Good catch. I've corrected my wording. _________________ AshMan40
Posted: Mon May 12, 2025 5:48 am Post subject: Re: B+ alternator bolt hot to the touch... |
Hi,
Saturday I disconnected the wire to find under the heat shrink a slightly loose connector and the strands being a bit separated. I cut off that part of the wire and used a new connector solving the problem. Now the terminal is nice and normal.
Thank you all for your time. _________________ 1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors. |
Posted: Mon May 12, 2025 8:03 am Post subject: Re: B+ alternator bolt hot to the touch... |
Good that it was a simple fix. Thanks for the update! _________________ In Stereo, Where Available! |
