trilogymac Samba Member
Posted: Mon May 12, 2025 11:36 am Post subject: Micarta beam bushing press fit |
I bought new Micarta beam bushings from CIP1. They measure 1.785/.790 od. Thats .015 to .020 over my beam ID of 1.770/.771. Seems like an awful lot of press..
Seems to me .005 would be more in line. Thoughts? Input?
Thanks,
Bill |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11506 Location: Huntington Beach, CA
Posted: Mon May 12, 2025 10:58 pm Post subject: Re: Micarta beam bushing press fit |
They are not rigid. The material has a lot to give. They will press in with no issues. You definitely want them tight! Highly recommend just pressing them in, as is.
FWIW. I completed this exact task a year ago or so. You would need to read the date on the page 79.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...start=1560
Not to bad of a job! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Tue May 13, 2025 4:35 am Post subject: Re: Micarta beam bushing press fit |
VW jimbo,
That is exactly the information I was looking for. I have access to a lathe and if I knew the crush ratio, I'd bore the bushing to the correct size (oversize) before installation. I've read 65% of the OD press is what the ID will move but thats a crap shoot. You didn't take any before and after measurements on the ID's and OD's did you? Fingers crossed.
The read on page 79 was great!
Thanks
Bill |
Posted: Tue May 13, 2025 8:34 am Post subject: Re: Micarta beam bushing press fit |
| trilogymac wrote: |
VW jimbo,
Thanks
Bill |
I did. But not knowing how much crush would happen, I was willing to go for it. It worked out great! If I had to do it again, I would press them in straight away, just like I did and team them slowly, no more than a 3/64th at a time. The reamer chatters pretty badly if you try too big of a cut. The material is like a fiberious plastic. Those fibers grab and the plastic just balls up. So slow and steady with lots of grease!
I am so glad I went through and created that index. Makes
My life way easier referring back to stuff. Glad Everett could get that posted into the first page for everyone! _________________ Jimbo
| TDCTDI wrote: |
Posted: Wed May 14, 2025 4:09 am Post subject: Re: Micarta beam bushing press fit |
An update VW Jimbo!
Bushings from CIP1
I only needed to replace the outer bushings.
Beam ID's. 1.770/.771
Micarta bushings OD 1.785 .005 out of round. Consistent size and egg
Micarta bushing ID 1.741 (would need opening up).
trailing arm OD 1.455/457
So, there was .015 press fit into the beam. I built an installation tool from allthread and hardware. I didn't want to buy a reamer but I had access to a lathe. Bored the 1st bushing.010 over my trailing arm diameter to compensate for the ID shrinkage, I didnt want to overbore. I took your advice and pressed the bushings in with the full .015 press. Almost a perfect SWAG. Installed the first bushing and it was spot on, same size as the trailing arm. I honed .003 out with a 3 stone hone and brake cleaner. Fit perfect. Bored the final 3 bushings out to 1.470, a couple of swipes with the hone and all 4 trailing arms will stand/hold in position and move with light pressure using 2 fingers. I'm thrilled with the outcome.
Thanks for the help and I hope this helps someone else. |
Posted: Wed May 14, 2025 9:29 pm Post subject: Re: Micarta beam bushing press fit |
Glad that you got it! Glad my journey was of value and helped you out. That is a huge compliment! So, from me to you, THANK YOU!
Nice job man! _________________ Jimbo
| TDCTDI wrote: |
