talljordan Samba Member
Joined: January 10, 2012 Posts: 1188 Location: San Francisco, CA
Posted: Fri May 16, 2025 11:03 am Post subject: How to add a headlight warning buzzer |
Not once have I ever forgotten my keys in the vehicle and locked them in, however I frequently leave my park lights or headlights on, and return to a flat battery.
I decided to add a second buzzer to my 72 super that warns me if I open the door and the lights are still on. Here is how to do it!
First, we need +12V from the park lights. To get this you can tap into fuse 1 or 2, both of which operate the park lights. Hook this up to one side of the buzzer (which I installed next to the dimmer relay).
Next we need switched ground from the doors. The easiest place to access this is the passenger side. Splice in a second wire to the connection here that will eventually run to the other side of the buzzer.
HOWEVER, there is an important note. The door switch is not actually a true "switched ground", it actually is sometimes +12V, namely when the interior light is on switched mode, and the doors are closed (see wiring diagram). This terminal receives voltage through the interior light. This means that if you close door and the park lights are off, the buzzer will run in reverse and never shut off, draining your battery. The buzzer receives power through the dome light, then sinks it through the headlight switch acting as a ground.
To solve this, we simply need to prevent current from running in reverse. This can be done with a diode, I simply soldered a diode in line with the "ground" wire that I ran from the passenger side door to the new buzzer. This way current can only flow from the buzzer to the door, and never from the door to the buzzer.
Job done! Now my car buzzes at me if I forget my lights on while the doors are open.
_________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
vamram  Samba Member
Posted: Fri May 16, 2025 11:19 am Post subject: Re: How to add a headlight warning buzzer |
Nice. I miss the working dying mouse-like buzzer that worked on my '72 Super for the key and seat belts.
What did you use for the buzzer? The original VW buzzer relay mounted in the fuse panel? Any pictures the installed buzzer? _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53270 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 16, 2025 12:45 pm Post subject: Re: How to add a headlight warning buzzer |
Most piezo buzzers are already a diode and only work with the polarity one way, I usually connect at the fuse box between the park light circuit and the ignition circuit, if the lights are still on when the key is turned off the ignition circuit becomes a ground for the buzzer.
Jordan's method does allow sitting with the parking lights on if that's something you do often. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri May 16, 2025 1:19 pm Post subject: Re: How to add a headlight warning buzzer |
Im using a stock piezo buzzer, my original one worked, and then I bought another working one from a scrapper for a couple bucks. So I have 2 stock buzzers in the fuse box.
Neither of these buzzers have an internal diode. Both worked regardless of polarity, thus my added diode. If your buzzer has an internal diode, the install becomes much simpler.
The one thing that my implementation doesnt allow, is if the lights are on and a passenger leaves the door open, it will buzz. If it ends up annoying me Ill add a NC relay to the switched power that interrupts power to this buzzer when the car is running. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Cusser Samba Member
Joined: October 02, 2006 Posts: 33587 Location: Hot Arizona
Posted: Fri May 16, 2025 5:36 pm Post subject: Re: How to add a headlight warning buzzer |
Those are very similar to the ones I use, piezo, not analog like the OG VW key buzzers.
There were some really cool ones available in the 80's that were dedicated to the job, I recall having a couple that would quit beeping after 30 seconds so you could park with the parking lights on but the engine off. I even had one that had a built in wiper delay feature as well, a 2 for 1 crappy little box you stuck on your dash and wired in using the crazy Japanese translated instructions. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 27, 2025 1:02 pm Post subject: Re: How to add a headlight warning buzzer |
Took a photo yesterday! I also installed a fuel pump cutoff relay, so my fuse box is now full.
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4577 Location: viroqua wi.
Posted: Tue May 27, 2025 1:07 pm Post subject: Re: How to add a headlight warning buzzer |
| talljordan wrote: |
Whats with the floating terminal? Low 1/3 from left? |
Posted: Tue May 27, 2025 1:10 pm Post subject: Re: How to add a headlight warning buzzer |
Wiring is still a WIP. I havent hooked up the wipers or fan yet. So its from that. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Tue May 27, 2025 1:17 pm Post subject: Re: How to add a headlight warning buzzer |
| talljordan wrote: |
Posted: Tue May 27, 2025 1:19 pm Post subject: Re: How to add a headlight warning buzzer |
| Sorry about the double post. I made a cocktail came back and forgot I already hit send. |
