Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 28327 Location: Free State of Florida
Posted: Fri May 23, 2025 2:34 pm Post subject: Tip for fixing early popouts |
The early small popout windows (pre-'65) used a thin plastic compression washer to hold the window open. These washers become brittle and disintegrate after 60 years. An easy fix is to substitute an oil drain plug compression washer, which is a perfect fit.
Most of us have some of these left over in our toolbox. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11579 Location: Oregon
Posted: Fri May 23, 2025 2:57 pm Post subject: Re: Tip for fixing early popouts |
Perfect, simple, elegant, and, everyone that has owned a VW for any length of time has one or more of those drain plug seals waiting to be put into service.
Thanks for posting this idea.  _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1946 Location: N.W. Georgia
Posted: Sat May 24, 2025 4:21 am Post subject: Re: Tip for fixing early popouts |
I can use this, thanks bud _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7577 Location: Houston, Texas
Posted: Sat May 24, 2025 3:38 pm Post subject: Re: Tip for fixing early popouts |
I just had to deal with that. I wrapped a piece of twine around there and cut the ends off. A piece of plastic is much better to do.
How did you get the cap off to put that washer on? Did you just flex it around it? _________________ www.vwnos.com [email protected]
Posted: Sat May 24, 2025 9:00 pm Post subject: Re: Tip for fixing early popouts |
Just take it apart.
Loosen the small set screw on the knob, unscrew the knob completely off, and the whole elbow comes apart. The washer fits between the two arms, as you see in the photo. Normally this would be a narrow flat plastic washer, but they often break or are missing. Have a safe space to put the small parts as you work. Each side should take about five minuites to do.
This is more durable than the original equipment. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
heimlich  VWNOS.com
Posted: Sun May 25, 2025 7:07 am Post subject: Re: Tip for fixing early popouts |
| Blue Baron wrote: |
Just take it apart.
Thanks for that. I bet those who meet you call you a genius a lot.
I know you can disassemble it. There is a screw of some type in the hole. I could not see in the hole. I tried a screw to take apart glasses because maybe I need glasses here but that didn't fit. In the spare time I wrapped a piece of twine around it and tied a knot. That worked well but that twine will come apart. _________________ www.vwnos.com [email protected]
Posted: Mon May 26, 2025 1:51 am Post subject: Re: Tip for fixing early popouts |
I call myself a genius.
There is a tiny screw in the knob. You use a jewelers flathead screwdriver to loosen it. You can then unscrew the knob entirely off and pry the whole thing apart. The central shaft fits through a cone-shaped eccentric that holds it all in place. it's a very simple arrangement. Good luck! _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
heimlich  VWNOS.com
Posted: Mon May 26, 2025 8:35 am Post subject: Re: Tip for fixing early popouts |
| Blue Baron wrote: |
| You use a jewelers flathead screwdriver to loosen it. |
That's what I needed. Thank you Mr. Genius. _________________ www.vwnos.com [email protected]
JollieOllie Samba Member
Posted: Thu Jul 17, 2025 2:07 pm Post subject: Re: Tip for fixing early popouts |
Thanks Blue Baron for this and the earlier post with the photo. My pop out window always closed once I started driving. I kept it open with two velcro straps. Well today I hit a serious rain shower out of nowhere and I had to unwrap the velcro to close the window. (Soaker for me) I had marked this page for future use, but now I went ahead to fix the window. This solution, so simple, fixed the problem. Well described - thank you!!!
| Blue Baron wrote: |
Just take it apart.
This is more durable than the original equipment. |
Posted: Fri Aug 08, 2025 5:20 pm Post subject: Re: Tip for fixing early popouts |
Thanks!
I used the copper compression washer rather than an O-ring, but the principal is the same. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
