Extra sealer when installing windshields?
15W40
15W40 is offline
PostPosted: Fri May 30, 2025 9:37 am    Post subject: Extra sealer when installing windshields? Reply with quote
My bus had a bad water leak from both windshields. Upon removing the glass, I found lots of rust holes. I made a new lower channel for the windshields, welded it in and painted with epoxy primer and paint.
Despite my best efforts to be thorough, I know water leaks can be really tough to nail down. Is there anything worth smearing in the windshield channel before I put the new seals and glass in? Just thinking how instructions rarely say to put copper silicone on exhaust gaskets but things always go a lot smoother when you do. I have all sorts of silicone, urethane, and butyl tape.
1966 Standard Microbus 11 Window "El Sapo"
1975 Campmobile Westfalia "Smokey"
Eric&Barb
Eric&Barb is offline
PostPosted: Fri May 30, 2025 12:06 pm    Post subject: Re: Extra sealer when installing windshields? Reply with quote
Posting Messages Dos and Don'ts
DO use the search button before posting; your question may have been answered
From a search (top left side of the forum) of the forum for "Windshield Seal" with "Search Titles" box checked:
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly
In Stereo, Where Available!
PostPosted: Fri May 30, 2025 12:24 pm    Post subject: Re: Extra sealer when installing windshields? Reply with quote
Yes, please ask in ONE of the 2 top threads from the link above so that this question is in one of the longer threads.
The first thread:
Windshield seal replacement - How to?
https://www.thesamba.com/vw/forum/viewtopic.php?t=141872
is probably best since it's also in the Split Bus FAQ
Thank you.
There may already be an answer in one or both of those threads as well.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Split Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
