Heat exchangers
Alex6373
Alex6373 is offline
PostPosted: Wed Jun 04, 2025 6:35 pm    Post subject: Heat exchangers Reply with quote
Hi there
I am wondering what the best way to re attach the flanges to the heat exchangers ?.
Allso anyone have any info on how the were originally pressed together .
What about brazing them back together ?
Thanks
busdaddy
busdaddy is offline
PostPosted: Wed Jun 04, 2025 7:05 pm    Post subject: Re: Heat exchangers Reply with quote
I'm not sure just what sort of savagery occured there, at the factory the flanges are slipped over the ends of the tubes and oven brazed into place in a jig fixture.
Sawing them off below the flange is going to make alignment impossible without a head to bolt them to, and welding that close to a brazed joint will surely contaminate the weld and make a bubbly poo speckled weld that's an embarrasment for even an amature.
Good luck! Confused
Слава Україні!
Alex6373
Alex6373 is offline
PostPosted: Wed Jun 04, 2025 7:50 pm    Post subject: Re: Heat exchangers Reply with quote
Who said anything about about sawing them off !!!!!
Thanks for the input!
Also your comments about being an amateur!
All welded and reinstalled
The factory brazing was not existing and exhaust was leaking out of the joints .
Thanks for your help Busdaddy !
busdaddy
busdaddy is offline
PostPosted: Wed Jun 04, 2025 9:11 pm    Post subject: Re: Heat exchangers Reply with quote
Oh my, that must have been running super lean to melt the bronze out of the joints, wow! Shocked
Слава Україні!
Erik G
Erik G is offline
PostPosted: Thu Jun 05, 2025 8:38 am    Post subject: Re: Heat exchangers Reply with quote
those pushrod tubes though... d'oh!
Alex6373
Alex6373 is offline
PostPosted: Thu Jun 05, 2025 10:02 am    Post subject: Re: Heat exchangers Reply with quote
Ya not pretty but thy work you guys are quite a bunch .
These days sourcing all these parts is difficult and expensive.
So until i know what i have upgrading will wait till later .
Push rod tubes are an easy change later !
I suggest you guys get away from your computers and actually do some work
Ha ha
vamram Premium Member
vamram is offline
PostPosted: Thu Jun 05, 2025 12:42 pm    Post subject: Re: Heat exchangers Reply with quote
Alex6373 wrote:
... you guys are quite a bunch .
Ha ha
Reads like a setup!
Click to view image
Save the Supers!!
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jun 05, 2025 10:34 pm    Post subject: Re: Heat exchangers Reply with quote
What Mark said. Over time the brazing burns away. It was a silver brazing material that came up in a couple threads in the bay forum. Used ones almost always leak. Carbon builds up and plugs the area, but the hotter the exhaust is, the sooner the brazing fails. The reason brazing was used is that welding will create a fracture line when they are heated and cooled. They were never designed to last 50 years like a set of stainless welded headers on a water cooled engine might. They were painted in the brazing solder and flux, tack welded on a jig and oven brazed.
George Carlin:
Skills@EuroCarsPlus:
oprn
oprn is offline
PostPosted: Fri Jun 06, 2025 4:27 am    Post subject: Re: Heat exchangers Reply with quote
Brass/bronze is a "hot short" metal meaning that the hotter it gets the weaker it is. I cannot understand why anyone would use that on an exhaust system. That is a surefire recipe for weld failure!
