Blue smoke on Gear change
Brycepj
Brycepj is offline
PostPosted: Wed Jun 04, 2025 7:33 pm    Post subject: Blue smoke on Gear change Reply with quote
Hello everyone need some advice,recently I’ve noticed that if I accelerate aggressively and change up a gear I get a puff of blue smoke. If I drive gently no smoke.
This is the only time I see it while driving.
Is this a concern should I just watch and see if it gets worse .
Doesn’t appear to be using any additional oil?
I have read about engine oil additives that supposedly reduce it or stop it by regenerating the seals.
The engine still has plenty of power and effortlessly will cruiser at 60-70 mph with no smoke.
Would appreciate everyone’s thoughts.
Regards
Peter
71’ super beetle
Mark1303
Mark1303 is offline
PostPosted: Sat Jun 07, 2025 3:06 am    Post subject: Re: Blue smoke on Gear change Reply with quote
I would say if it's just a small puff of smoke and it's not smoking at other times then just something to keep an eye on.
I guess it must be the increased vacuum when rpms drop which is showing up a small amount of wear somewhere and causing oil to get into the combustion chamber.
What oil are you running? Sometimes a thicker oil might help stop it getting past a slightly worn piston ring or valve seal. I run 20w-50 in mine, but I still get occasional puffs of smoke on start up, but it isn't getting any worse so I'm not worrying about it. As you say, you could try and additive also.
Cheers
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Sat Jun 07, 2025 9:05 am    Post subject: Re: Blue smoke on Gear change Reply with quote
ACVW's dont use valve seals, so worn valve guides and or rings.
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
bsairhead
bsairhead is offline
PostPosted: Sat Jun 07, 2025 10:05 am    Post subject: Re: Blue smoke on Gear change Reply with quote
A little top end lubrication is a good thing.
Multi69s
Multi69s is offline
PostPosted: Sat Jun 07, 2025 10:41 am    Post subject: Re: Blue smoke on Gear change Reply with quote
Typically a little smoke at aggressive gear change is valve guides. However, don't worry too much about it. just keep an eye on the oil level, but don't get too paranoid about it.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Mark1303
Mark1303 is offline
PostPosted: Mon Jun 09, 2025 2:04 am    Post subject: Re: Blue smoke on Gear change Reply with quote
D'oh, yes apologies, I am still fairly new to these so force of habit!
