Distributor
DSVW
DSVW is offline
PostPosted: Fri Jun 13, 2025 5:49 pm    Post subject: Distributor Reply with quote
Hi,
All original 1966 Bug here.
I had to pull my distributor up about a 1 inch to make clearance to remove my condenser. I am not sure if I seated it all the way down before I tightened it up.
I went to start the car, and it turned freely but didn't start.
I now know the condenser is bad, but did I do any damage by not pushing it down far enough?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jun 13, 2025 6:43 pm    Post subject: Re: Distributor Reply with quote
If it's not all the way down, it may not turn when the engine turns.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
DSVW
DSVW is offline
PostPosted: Fri Jun 13, 2025 7:40 pm    Post subject: Re: Distributor Reply with quote
So I wouldn't have done any damage?
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Fri Jun 13, 2025 7:51 pm    Post subject: Re: Distributor Reply with quote
Yeah it’s pretty easy to *not* get the clamp and distributor seated fully, especially with a new o-ring. Most likely didn’t hurt a thing. Just loosen it back up and rotate the shaft while pushing down on the body, it will find the slot and go down.
Robert in Memphis
Engine rebuild thread
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Jun 14, 2025 1:05 pm    Post subject: Re: Distributor Reply with quote
In the future you can completely remove the distributor with the clamp attached to replace the points and condenser. As long as you don’t move the crankshaft of your engine (turn it) it only installs one way. Removing the distributor would allow more accurate points adjustment and to fully install the condenser
If you cranked the engine but the distributor shaft didn’t turn then you have mis or untimed your engine. You will need to do a full timing procedure starting with finding top dead center (TDC).
Roads Scholar
Member# 2059
