CoastalBug Samba Member
Posted: Sun Jun 15, 2025 8:40 pm Post subject: What's worse? Engine work or body work? |
Hello all, I just registered. First post.
Currently looking at getting my first bug. I've got a cash budget of $3K. I'm optimally looking for a daily driver project car and just to get around our small town. I've located two possibilities at this time.
Car 1 1968 regular beetle
PROS - running, minimal body rust (mostly surface). Car had a small engine fire from busted original filter and fuel line. Engine repaired and runs great. New parts installed to include wiring harness from firewall back, carb, fuel filter and lines, alternator and belt, distributor/rotor/cap/plugs/wires, engine shroud and seals, brake soft lines drums shoes and master cyl, front end rebuild, fuel filler neck, battery, new starter, and assorted body seals. Car has a clear title.
CONS - Located 5 hours away and will need to be towed, needs brake work to be road worthy, will need light body work and paint.
Car 2 1972 regular beetle
PROS - new rebuilt 1600 engine installed in january 2024 (less than 100 miles), has factory console and lines installed for DPD air conditioning (incomplete though), new gas tank, passed stated inspection last year, located an hour away.
CONS - car has no title, body has more dings and dents and has sever rust near fenders from failed seals, no back seat, no heater boxes, rear engine tin, needs brake work.
I'm leaning toward the '68 the hardest, mostly because the body is in better condition, and it has a title. I realize that without knowing all of my circumstances it will be hard to give me advice, I'm just kind of looking for general thoughts or things to ponder. |
DesertSasquatchXploration Samba Member
Posted: Sun Jun 15, 2025 8:54 pm Post subject: Re: What's worse? Engine work or body work? |
I learned early on with my 65 Stang Body work/rust repair is a nightmare. A good body is most important. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
Posted: Sun Jun 15, 2025 9:38 pm Post subject: Re: What's worse? Engine work or body work? |
DesertSasquatchXploration wrote: |
I learned early on with my 65 Stang Body work/rust repair is a nightmare. A good body is most important. |
Yeah, I think I made my mind up. I received videos taken earlier today of the '68 actually on the road. The seller is young but seems like a gearhead and knows what he's doing, and it's much futher along than the '72. It's actually DD ready from the videos he sent me, sans a little light brake adjustments. I guess I just had to get it out of my head in a place where people can understand.
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1430 Location: San Diego
No title is a deal killer for me no matter how good the car looks or how good the price is. Got burned once buying a motorcycle with paperwork issues. It took over six months to finally get a clear title ... and you don't want to invest much time and any money until you have the necessary documents to make it yours.
Aside from that, it depends what skills and equipment you possess. Generally you'll be able to get on the road sooner with a mechanical project than with a body project ... and driving the car is the fun part of ownership.
You say your cash budget is $3K ... is that for the purchase or to make the purchase and get it roadworthy? These cars can be a money pit. Generally speaking, you'll pay more for a car that needs little or no work, but not nearly as much as you'll end up spending to get most fixers up to comparable condition.
How long have you been looking? It took me almost a year and a half to find my '69, and I'm in Southern California where the rest of the world seems to think they're still a dime a dozen. Mighty glad I was patient. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4495 Location: viroqua wi.
Posted: Sun Jun 15, 2025 9:52 pm Post subject: Re: What's worse? Engine work or body work? |
To do yourself, body work is not for the faint at heart. I would at least double your budget and find the driest car you can. |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 376 Location: Eastern north carolina
Posted: Mon Jun 16, 2025 3:38 am Post subject: Re: What's worse? Engine work or body work? |
I agree the 68 sounds like the better candidate based upon the title issues and the rust you described. You may want to narrow down if you would prefer a swing axle car (the 6 or a later independent rear suspension car (the 72). 68 in the US was the last year for the swing axle. Do a little more research on the differences to understand that a little better before you buy. Good luck Bob |
bugger-off Samba Member
Posted: Mon Jun 16, 2025 5:56 am Post subject: Re: What's worse? Engine work or body work? |
I'd walk away from the '68. Five hours away and needs brakes. Nope, too much uncertainty and such a hassle, definitely not worth it.
Anyone who wants more than a few hundred bucks for a vehicle with NO TITLE is crazy. "Oh, but I promise it's not stolen." Who cares. RUN away from this one. Getting a title isn't just going to titles.com and getting one. In my state it is a royal PIA.
Don't rush into a bug just because you're sick of looking/waiting. I am sure you'll need to spend more than $3k to get something decent. Take your time.
IMO, look for a '69 or newer. IRS rules. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79563 Location: Sneaking up behind you
Posted: Mon Jun 16, 2025 6:06 am Post subject: Re: What's worse? Engine work or body work? |
I rather have a vw with rust free body and no engine/transaxle than a rusty one with a "chromed out" engine. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Schepp Samba Member
Posted: Mon Jun 16, 2025 7:06 am Post subject: Re: What's worse? Engine work or body work? |
I agree with everyone else. No paperwork. No deal. End of story. A body in better condition is the way to go. Starting with good bones is key to a build. You'd be a fool to dump $$$ into an engine before dealing with severe rust or body damage. Since bugs don't have a traditional frame rust is our killer.
Good bugs are getting a lot harder to find. $3k in CA isn't going to get you one.
They're not as cheap as they used to be. For $3k expect to put at least another $3K+ into making it a DD worthy car.
Also don't be fooled by new paint jobs and/or new carpet kits.
I recommend posting the cars your are interested in on here for us to help determine if its worth it or not.
If a seller isn't cool with you putting the car on jack stands or taking out the back seat for inspection. Walk away. |
rg65 Samba Member
Joined: January 24, 2025 Posts: 7 Location: New Mexico
Posted: Mon Jun 16, 2025 7:13 am Post subject: Re: What's worse? Engine work or body work? |
Go with the 68. I have also done the no title route and it is a pain in the ass. Will not do that again. |
Posted: Mon Jun 16, 2025 1:14 pm Post subject: Re: What's worse? Engine work or body work? |
Here are more photos from the listing. The rust on the drivers side rear was from a small engine fire. It’s surface rust only. The only other place of concern is a silver dollar sized hole in the battery compartment.
Posted: Mon Jun 16, 2025 1:23 pm Post subject: Re: What's worse? Engine work or body work? |
And here are some videos he sent me.
[/youtube]
Cusser Samba Member
Joined: October 02, 2006 Posts: 33103 Location: Hot Arizona
Posted: Mon Jun 16, 2025 2:47 pm Post subject: Re: What's worse? Engine work or body work? |
Just for your general knowledge here are some changes that have been made to that 68 bug
1) the steering wheel is from a later bug probably 72 or newer
2) the decklid is from a later bug, 68 had no vents on the lid
3) the air cleaner looks different to me
I am pointing this out to you in case you are looking for a stock original car. The body looks good from the outside. Prepping, priming, and painting should be done to the fire damage soon. That stuff will rust deeply quickly. I would want to know about the condition of the heater channels and floor pan, and the support panel below and behind the front suspension beam. These are all common rust areas on these cars. Hope this helps Bob |
Posted: Mon Jun 16, 2025 3:00 pm Post subject: Re: What's worse? Engine work or body work? |
Bobs67vwagen wrote: |
Just for your general knowledge here are some changes that have been made to that 68 bug |
Thanks Bob. I knew a few things weren’t original, like the steering wheel. I did not know about the others. Here is what the underside looks like.
diamondblue1969 Samba Member
Joined: February 19, 2010 Posts: 142 Location: ONTARIO
Posted: Mon Jun 16, 2025 3:05 pm Post subject: Re: What's worse? Engine work or body work? |
Looks really solid and complete, except the missing bumpers ! |
Posted: Mon Jun 16, 2025 4:21 pm Post subject: Re: What's worse? Engine work or body work? |
The pan looks pretty good as does the underside of the heater channels. Heater channels are hard to ascertain without being at the car and going inside and tapping the channels from front to rear. They are covered in carpet so you can not really see any hidden rust. If the owner is willing ask to photo the area behind and below the front suspension beam. Another common rust area is the package shelf behind the rear seat. This also is hard to examine as it's covered in carpet. It looks to be a pretty solid car. Hope this helps. |
Posted: Mon Jun 16, 2025 7:21 pm Post subject: Re: What's worse? Engine work or body work? |
3) the air cleaner looks different to me |
The deck lid is from a '70 ... probably to replace the fire damaged one. The air cleaner looks like a sawed off '67 ... again, probably to replace the fire damaged one. The steering wheel bothers me though. The '71 - earlier steering wheels were not interchangeable with the '72 - later ones. That suggests that the steering column was replaced. Why? Possible accident? Might be worth giving it a pretty close look for evidence of front end damage. Have a look at the VIN plate behind the spare tire and compare the number to the one stamped on the tunnel under the back seat. If different numbers, that car has probably had fairly significant front end damage and multiple parts replaced. Just something to be aware of. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Mon Jun 16, 2025 7:33 pm Post subject: Re: What's worse? Engine work or body work? |
OldSchoolVW's wrote: |
If different numbers, that car has probably had fairly significant front end damage and multiple parts replaced. Just something to be aware of. |
Or, it’s an early 70’s model that’s been titled incorrectly. I’ve seen it happens with boats personally so I don’t see why it can’t happen with cars of this age. He’s sending me the pic of the title and the registration application forms so I’ll be able to verify things soon. |
Posted: Mon Jun 16, 2025 8:36 pm Post subject: Re: What's worse? Engine work or body work? |
CoastalBug wrote: |
The VIN/Chassis number stamped on the tunnel is the only one most DMVs will go by. Have him send you a photo of this too. Then go to this table to verify what year that VIN corresponds to (keep in mind that the model year ran from August - July):
https://www.thesamba.com/vw/archives/info/bugchassisdating.php
If it is a '68, the VIN should start with 118.
BTW, if the VIN plate behind the spare is missing, that's almost a guarantee that the front apron has been replaced.
VW started using a collapsable steering column in '68. The fact that the steering column was replaced (hence the '72 - later steering wheel) suggests a fairly significant front end collision. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
