Steering box leak
Axitech
Axitech is offline
PostPosted: Fri Jul 04, 2025 1:03 pm    Post subject: Steering box leak Reply with quote
Hello all, I’ve been away for a while. Work is trying to run me into the ground.
N Dug out the Rail from winter storage today.Needs to get State Inspected this week. It’s 5 days past due. Anyway, took it for a drive around the block to check brake function, steering, tires, all the good stuff.Brought it back and blew all the leaves and winter debris off the front end. As I passed over the steering box, oil sprayed out of box. Not like squirting out, more like it got siphoned out by the Venturi effect of a high speed wind going over a hole.
Sure enough, there’s an open hole in my box. Anyone know what goes there? Is it a plug? Threaded rot pushed in?
Thanks guys, I always appreciate the great advice I get here.
Bob
He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Fri Jul 04, 2025 1:11 pm    Post subject: Re: Steering box leak Reply with quote
VW started putting plastic type plugs there in later boxes. Early boxes had a square head pipe plug with just one hole.
you could drill and tap holes and install pipe plugs in the two holes.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Axitech
Axitech is offline
PostPosted: Fri Jul 04, 2025 7:40 pm    Post subject: Re: Steering box leak Reply with quote
Outstanding. Thank you!
Happy Independence Day to all!
earthquake
earthquake is offline
PostPosted: Mon Jul 14, 2025 5:19 pm    Post subject: Re: Steering box leak Reply with quote
When I did the washer trick to my steering box I drilled and tapped mine and drained the oil and pumped the box full of Mobil 1 red Syn grease, it does not run out if the seal blows just make sure to loosen one of the bolts if you try to add more grease. you can just see it in the picture.
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
my3bugs
my3bugs is offline
PostPosted: Mon Jul 14, 2025 5:31 pm    Post subject: Re: Steering box leak Reply with quote
looks like you still need to fish some of it out .
its a small plastic type push in plug , NOS parts in the classifieds has em aka Heimilich , its 3 dollars n change for original .
its just a push in fit they get hard brittle break after so many decades , i recently replaced mine when it cracked to pieces .
https://www.thesamba.com/vw/classifieds/detail.php?id=2174064
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Tue Jul 15, 2025 8:15 am    Post subject: Re: Steering box leak Reply with quote
eQ
+1
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
