johnboy715 Samba Member
Joined: January 30, 2008 Posts: 223 Location: Shawano, Wisconsin
Posted: Fri Jul 04, 2025 8:00 pm Post subject: Convertible rear seat backing material |
Restoring and Re-upholstering the seats in my ‘69 Bug convertible. The cardboard/tarboard material on the back of the rear seat is broken in spots and needs to be replaced. Looking for replacement material. (Photos attached)
Any suggestions?
pinkham Samba Member
Posted: Sat Jul 05, 2025 12:44 pm Post subject: Re: Convertible rear seat backing material |
I am looking for the same, with no luck, for 71 Super convertible. Looks the same. I will be following your thread. |
Posted: Sat Jul 05, 2025 2:09 pm Post subject: Re: Convertible rear seat backing material |
Looking at using 1/8” tempered Masonite for backing material. Use old back as a pattern and cut out. A little thicker but not sure what else to use. TMI Seat upholstery for convertible doesn’t come with a back. |
viiking Samba Member
Joined: May 10, 2013 Posts: 3145 Location: Sydney Australia
Posted: Sat Jul 05, 2025 4:13 pm Post subject: Re: Convertible rear seat backing material |
That doesn't look to be that bad if it just the one crack on the left side and the beaten up bottom section.
Somewhere on the SAMBA here someone repaired either the frunk cover or door cards to maintain originality using PVA glue and some thick cardboard.
From memory they cut the cardboard up into small pieces and the wet the cardboard and ran it through a blender to make a pulp. They then made repairs with the pulp allowing it to dry.
I did something similar on my wiring cover but have no pictures of it now. It looked ok after I painted it. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
lmar Samba Member
Posted: Mon Jul 07, 2025 1:41 pm Post subject: Re: Convertible rear seat backing material |
johnboy715 wrote: |
Any suggestions?
Was thinking of this material and getting it water jet cut.
https://goindustrial.com/products/abs-black-textured-3-16in?_pos=10&_sid=beb00fe84&_ss=r
L |
