1641cc Dual port motor with mild cam - What dizzy and carb?
Bottlejack15
Bottlejack15 is offline
PostPosted: Thu Jul 10, 2025 8:53 pm    Post subject: 1641cc Dual port motor with mild cam - What dizzy and carb? Reply with quote
I am trying to work out my next step forwards with a 1971 1300 Standard beetle I recently picked up.
It would have been a 1300 dual port from the factory but has been rebuilt into a 1641cc dual port with a SCAT C20 cam and a free flow exhaust.
It runs pretty bad when cold and coughs and splutters even when warmed up. I've done some digging and it has the following fitted:
Carburetor : 31 PICT-3 original VW/Solex with a rebuild kit electric choke does not work and its not documented what jetting it has.
Distributor: 021178009 original VW/Bosch but with new points and condenser.
I'm aware the 009 distributor could be half the issue, and I am considering a 123 Ignition distributor to replace it so I can swap between the different spark curves to find the best one for this motor
The 31 PICT-3 is not the right carb for a 1600 never mind a 1641cc motor. I wanted to get a restored 34 PICT - 3 from VolkzBitz but they do not offer oversea shipping. What is my next best option?
tasb
The Distributor Distributor
tasb is offline
PostPosted: Thu Jul 10, 2025 9:42 pm    Post subject: Re: 1641cc Dual port motor with mild cam - What dizzy and carb? Reply with quote
Do you have any friends states side who could purchase it for you and send it over for you? Buy a core and have someone local to you rebuild it or teach yourself to do it? Plenty of tutorials out there. Welcome to VW’s and TheSamba!
Roads Scholar
Member# 2059
bsairhead
bsairhead is offline
PostPosted: Fri Jul 11, 2025 12:23 am    Post subject: Re: 1641cc Dual port motor with mild cam - What dizzy and carb? Reply with quote
Find a local club. You live in a big city.
