bcrazy Samba Member
Posted: Sat Jul 12, 2025 9:46 am Post subject: 1679 SP build advice / or easy way to 75hp single port |
In my 63 beetle i have this SP engine:
1584 (1500 heads with very light porting work, 3 angle valve job)
Scat C25 (1.1 intake rockers, exhaust 1:1)
7.9:1
1 3/8 4-1 header with "quiet pack" exhaust
2xSolex 35PDSIT
This engine runs ok, but compression should have been a bit higher, and especially the deck height ~0.060, should be closer
Got myself a small mill, and now plan to build the engine again.
My aim is 75 Hp and good low end torque
Got a good set of 88mm P&C, but can bore the case for for 90.5 if needed. (put i prefer to no split the case)
So my plan it is to cut the heads for more compression (8.5-9.0?), or if necessary also deck the case.
Is this a good recipe for ca 75 HP, and 130-135 nm? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11074 Location: Oregon
Posted: Sat Jul 12, 2025 10:26 am Post subject: Re: 1679 SP build advice / or easy way to 75hp single port |
Machining on a short block is not a good idea. How would you keep machining chips out of the block?
Also, how would you go about securing the block to the table (<wrong term but, this is the best I can describe it) with the rods sticking out of the case? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
bcrazy Samba Member
Posted: Sat Jul 12, 2025 11:13 am Post subject: Re: 1679 SP build advice / or easy way to 75hp single port |
If i need to correct deck height i will take the block apart.
If deck height measures to less than 1.5mm, i will just adjust the compression by machining the heads. |
RWK Samba Member
Posted: Sat Jul 12, 2025 12:04 pm Post subject: Re: 1679 SP build advice / or easy way to 75hp single port |
Decking the case is always a good idea, a used case is usually sagged between the cylinders. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3842 Location: Eastern WA
Posted: Sat Jul 12, 2025 5:24 pm Post subject: Re: 1679 SP build advice / or easy way to 75hp single port |
If you dont want to split case to correct deck , take it off the bottom of the cylinders _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7833 Location: Videbaek Denmark
Posted: Sun Jul 13, 2025 2:45 am Post subject: Re: 1679 SP build advice / or easy way to 75hp single port |
bcrazy wrote: |
7.9:1
2xSolex 35PDSIT
Easy.
Replace the cam to something proper. CB2280 w. 1,25´s for good overall power. CB 2232 for very good mid rpm grunt. W100 for more rpm power.
Reduce deck to 0,040-0,045"
Set CR to 9-1 (8,8 with the 2232)
Figure out what intake length the engine wants. - Most likely about 20 mm more than what it is.
There is the potential for a true 75 hp sgl port. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Dusty1 Samba Member
Posted: Sun Jul 13, 2025 2:33 pm Post subject: Re: 1679 SP build advice / or easy way to 75hp single port |
Alstrup wrote: |
Easy.
There is the potential for a true 75 hp sgl port. |
There is just about everything I need for my so- called "Formula Street" motor.
I'm going to cheat and use dual port heads.
