Splitless Samba Member
Posted: Thu Jul 17, 2025 7:56 pm Post subject: Pressure plate weights |
Never seen this before, new Sachs 180mm pressure plate. Are these for balancing? Kinda cheesy, would you run it?
EverettB  Administrator
Joined: April 11, 2000 Posts: 71681 Location: Phoenix 602
Posted: Fri Jul 18, 2025 6:29 am Post subject: Re: Pressure plate weights |
I've never seen that either but my first thought is how the hell is it that much out of balance?
The balancing I've seen before, usually done with the flywheel, is very minor with some small divots on the edges.
Examples I found in the gallery
_________________ How to Post Photos
Posted: Fri Jul 18, 2025 7:02 am Post subject: Re: Pressure plate weights |
Thanks for the reply, definitely odd. I think I’ll return it and see what the next one looks like… |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33251 Location: Hot Arizona
Posted: Fri Jul 18, 2025 7:04 am Post subject: Re: Pressure plate weights |
Splitless wrote: |
Never seen this before, new Sachs 180mm pressure plate. ...Kinda cheesy, would you run it? |
I've never seen anything like that, looks so "homemade".
Personally, I'd be wary of using that. I'd definitely contact the supplier.
This is the Brazilian Sachs 200mm pressure plate in my 1970, purchased in 2018 through CB Performance.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
zerotofifty Samba Member
Posted: Fri Jul 18, 2025 8:15 am Post subject: Re: Pressure plate weights |
That is really bad, never seen it done like that ever. The welds look extremely poo, such that I doubt they are good, they might even fail. I doubt it is even factory done. I suspect this is a returned clutch that the prior customer modified then sent back, and now you got it.
Total JUNK, send it back, get one without those junk weld on weights.
I have seen balancing usually with lightening holes drilled around the perimeter, and I kind of recall maybe some neatly attached weights in some instances. But never anything this janky.
Id not want that on my car. return it _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 626 Location: Eastern north carolina
Posted: Fri Jul 18, 2025 10:27 am Post subject: Re: Pressure plate weights |
That looks like it was used for welding practice in a training class. I would not put that in my car. |
viiking Samba Member
Joined: May 10, 2013 Posts: 3295 Location: Sydney Australia
Posted: Sat Jul 19, 2025 4:54 pm Post subject: Re: Pressure plate weights |
Totally agree with all of the comments.
1. That is NOT original
2. Welding so poor
3. The sheer mass that is requited to "apparently" balance the PP shows that something is very wrong with the balance elsewhere.
4. If any one of those weights come off they will damage the bell housing if they come off at speed, not to mention the out of balance vibration that it will impart.
5. My "German" Fichtel(?)and Sachs pressure plate is drilled in on the outside periphery. Adding weights assumes that the repairer does not have the drilling capability to do it the correct way.
6. I wonder what adding that quantity of weights do to the static v dynamic balance? That is, whilst the weights may balance out the out of balance in the X-Y axis, what does it do to the XYZ axis balance. Does the manufacturer know or even care? _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Sun Jul 20, 2025 9:19 am Post subject: Re: Pressure plate weights |
Well I sent it back and they’re sending me a another clutch kit. I’ll give an update on the new one. |
Posted: Sun Jul 20, 2025 9:25 am Post subject: Re: Pressure plate weights |
Good I hope it won't be another one of those ugly looking things! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26137 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 20, 2025 3:15 pm Post subject: Re: Pressure plate weights |
Personally would be wary of having one of those weights come loose to jam into the transaxle case shredding up magnesium/aluminum dust and sparking against the steel of the flywheel. POOF, flash instant VW BBQ....... _________________ In Stereo, Where Available! |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16673 Location: North Florida, USA
Posted: Mon Jul 21, 2025 4:48 am Post subject: Re: Pressure plate weights |
My first impression is that is a core returned to be remanufactured, and that it somehow slipped pass quality control? But you said it was a NEW part, right?
Good call returning it.  _________________ AshMan40
Posted: Thu Jul 24, 2025 9:25 pm Post subject: Re: Pressure plate weights |
Well here’s the new replacement they sent me.
Posted: Fri Jul 25, 2025 2:56 am Post subject: Re: Pressure plate weights |
Are you going to use it or send it back? |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3599 Location: 802 The Pointless Forrest
Posted: Fri Jul 25, 2025 3:11 am Post subject: Re: Pressure plate weights |
whom did you buy that from? _________________ "Albatross"! |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1940 Location: N.W. Georgia
Posted: Fri Jul 25, 2025 5:27 am Post subject: Re: Pressure plate weights |
I see it’s stamped Sachs, I would say there are other less obvious shortcomings with that PP
KEP or Kennedy engineered products make pressure plates domestically
you have been wise to ask here _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
Posted: Fri Jul 25, 2025 6:00 am Post subject: Re: Pressure plate weights |
Bobs67vwagen wrote: |
I don’t think I’ll use this one either. To the other questions, RockAuto and it’s a Sach’s clutch kit. |
Posted: Fri Jul 25, 2025 6:01 am Post subject: Re: Pressure plate weights |
Jeff Geisen wrote: |
you have been wise to ask here |
Yea I might grab one of those or an Exedy kit. |
Posted: Fri Jul 25, 2025 6:19 am Post subject: Re: Pressure plate weights |
I have had good luck with the exedy kits in my Honda Civic. They seem to be of good quality for what it's worth. You have had more trouble with this than there should be. |
splitjunkie Samba Member
Posted: Fri Jul 25, 2025 6:52 am Post subject: Re: Pressure plate weights |
Splitless wrote: |
I have never bought anything from Rock Auto, but with so many legit Aircooled VW suppliers out there, I wouldn't buy anything from them unless nobody else had what I needed.
I see that PP is from Brazil? Was it new or a refurb? Back in the day Brazil was the low cost, roll the dice quality, but that looks really bad. _________________ Chris
Posted: Fri Jul 25, 2025 6:57 am Post subject: Re: Pressure plate weights |
Eric&Barb wrote: |
Personally would be wary of having one of those weights come loose to jam into the transaxle case shredding up magnesium/aluminum dust and sparking against the steel of the flywheel. POOF, flash instant VW BBQ....... |
Back in the day my mom's '65 engine locked up hard. I assumed it has seized. As I was taking it out I noticed the crank pulley moved as I pulled it free. Turned out one of the retainer springs on one of the pressure plate arms had broken free and wedged the flywheel to the bell housing. I would hate to think what one of those weights would do. _________________ Chris
