mrinnovation1 Samba Member
Posted: Wed Jul 23, 2025 10:44 am Post subject: Re: mechanical oil pressure gauge help |
I just finished installing a mechanical(0-100 psi) OPG in my 1985 Vanagon using 16' long X 1/8" diameter copper tubing from a refrigeration shop. The entire 16' was used as I left a couple of coils for movement near the OP sensor termination point. I mounted the gauge alongside the auto trans shifter housing(left side) since dash mounting would have required another 3 or 4 feet of tubing. The gauge is easily read from the drivers seat. It took a minute or so for the gauge to react after initial startup. Subsequent startups pretty much give me an instant reading. For comparison, I temporarily left the digital gauge installed to compare readings. Cold start mechanical shows 70-75 psi. Warm idle reads 20 psi and I get around 45-50 psi warm at 2000 rpm. With the digital gauge cold start psi is 80-85 and warm idle reads 20 psi. The reason I went to a mechanical gauge was because the digital gauge used an adapter and a much smaller oil filter. Once I remove the digital gauge and associated hardware installed by a previous owner, I can go back to the stock size oil filter. |
4Gears4Tires Samba Member
Posted: Wed Jul 23, 2025 10:54 am Post subject: Re: mechanical oil pressure gauge help |
So what is your issue? _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Posted: Wed Jul 23, 2025 11:43 am Post subject: Re: mechanical oil pressure gauge help |
4Gears4Tires wrote: |
So what is your issue? |
No issue. The title says "mechanical oil pressure gauge help" so I provided some. Was that wrong? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18774 Location: Retired South Florida
You didn’t mention bleeding the line. I’d probably start with that. It could get messy, so have a rag or 2 on hand. With the engine running crack the line loose at the gauge that should let any air left escape.
For the difference in readings, not knowing which one is more accurate add the readings together and divide by 2 for an average. My experience is a quality mechanical gauge is more honest, but that’s a long run. Not sure how friction loss would affect readings if at all. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10227 Location: Mt Lemmon, AZ
Posted: Wed Jul 23, 2025 12:14 pm Post subject: Re: mechanical oil pressure gauge help |
I always used mechanical OP gauges on my other cars - but those were older vehicles with notoriously unreliable gauges and senders. They also had an engine not far from the dash so a braided stainless steel line was practical. Hopefully the copper will hold up well enough.
Yeah, having two gauges is like wearing two watches... with one watch you know what time it is, with two you're not so sure.
I get it about the oil filter though of course there are many ways to plumb a sender other than a sandwich adapter. I will say that the VDO gauge and sender combo has been consistent for a great many years (I actually think consistency is more important than precision in this application).
BTW - I never had to bleed the line on my mechanical gauges. Somewhat counterintuitive but they always worked well with out messing with that. |
Posted: Wed Jul 23, 2025 12:23 pm Post subject: Re: mechanical oil pressure gauge help |
mrinnovation1 wrote: |
Oh, I totally read that wrong. I thought you were looking for help. From the write up it didn't seem like it, so I was very confused. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
Posted: Wed Jul 23, 2025 12:29 pm Post subject: Re: mechanical oil pressure gauge help |
I just turned 70 and have always been confused. BTW, I found no need to bleed the line either. |
Posted: Wed Jul 23, 2025 2:05 pm Post subject: Re: mechanical oil pressure gauge help |
You’re not running the copper tube direct from the engine are you? I also didn’t understand you were offering help and thought you were wondering about the difference in readings. There is air in the line with no where to go. The air will operate the gauge just as an air pressure gauge, but the compression rate of a fluid is quite a bit different from air. So yes the gauge would work, but if you are looking for accuracy getting the air out might improve your readings.
Hopefully you aren’t running the copper tube and directly connected to the engine. |
Posted: Wed Jul 23, 2025 3:26 pm Post subject: Re: mechanical oil pressure gauge help |
MarkWard wrote: |
....Hopefully you aren’t running the copper tube and directly connected to the engine. |
I'm guessing your concern is the work-hardening that will occur with the inevitable flex in the line. Anyway, that would be my concern.
Though not ideal, nylon tubing is often used for mechanical gauges for that reason. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5713 Location: Bemidji, MN
Posted: Wed Jul 23, 2025 3:46 pm Post subject: Re: mechanical oil pressure gauge help |
Ahwahnee wrote: |
MarkWard wrote: |
have a pilot friend that had to set his single engine plane down in a corn field due to loss of oil pressure. when he landed, he found that the short section of rubber hose between the engine nipple and the copper pressure line had ruptured. that section of rubber hose was meant as a vibration damper between the motor and copper line to the gauge. this SHOULD have been caught as an aging rubber line during the many inspections. while my pilot friend remained calm as he looked for a landing spot, his passenger not so much.
on my airhead BMW, i installed a mechanical oil pressure gauge. i inserted the line in a length of rubber vacuum tubing for vibration and chafe protection. it's difficult to make a copper line oscillate when covered in rubber. also added a compliance coil near the pressure tap and bonded this to the frame with zip ties. this also gives an 'emergency' length of tubing to work with should the end compression fittings go wonky.
i think a mechanical gauge and run of copper tubing can be MORE reliable than an electronic oil pressure sender, of which i've had several leak. HOWEVER, the potential for a poor installation is far higher with the mechanical line. _________________ -dan
www.thefixitworkshop.com |
Posted: Thu Jul 24, 2025 3:37 am Post subject: Re: mechanical oil pressure gauge help |
I should clarify that although I did not bleed the line, there was initially some seepage at the gauge fitting. This was not enough to even drip but I did get another 1/4 turn or so out of the fitting. If that qualifies for bleeding, then it was bled. Yes, the copper line runs directly from the gauge to the engine but I did put 3 coils in the line before the engine connection. |
zerotofifty Samba Member
Posted: Thu Jul 24, 2025 6:20 am Post subject: Re: mechanical oil pressure gauge help |
I recommend a third gage.  _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Thu Jul 24, 2025 6:23 am Post subject: Re: mechanical oil pressure gauge help |
I have a sandwich adsptir but am able to use an oversized filter as i bent the underside pushrod tube protecting metal shield for clearence _________________ Sorry About That Chief.
Words to live by. |
Posted: Thu Jul 24, 2025 7:16 am Post subject: Re: mechanical oil pressure gauge help |
On a cold morning I would be afraid that if something busted like the o-ring between the oil cool and the block, a mechanical gauge mounted at such a distance might not react fast enough to save the engine. I know it's not very popular on any automotive site, including The Samba, but I am a fan of idiot lights as they are attention getters. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10639 Location: Western WA
Posted: Thu Jul 24, 2025 9:14 am Post subject: Re: mechanical oil pressure gauge help |
DanHoug wrote: |
Ahwahnee wrote: |
MarkWard wrote: |
Airplane...... I suspect he changed to electric after that !
On my airhead BMW, i installed a mechanical oil pressure gauge. i inserted the line in a length of rubber vacuum tubing for vibration and chafe protection. it's difficult to make a copper line oscillate when covered in rubber. also added a compliance coil near the pressure tap and bonded this to the frame with zip ties. this also gives an 'emergency' length of tubing to work with should the end compression fittings go wonky.
Solid-mounted engine, and on-the-ground operation seems OK for a small oil line.
A tiny orifice that's right at the block, and bled gauge line.
This would be a period-appropriate mod for an older air-head BMW.
You can't eliminate,
nor want to eliminate
every possible failure on an airhead BMW.
Ya gotta have something to talk about.
It's different for an airplane.
I bet a leaking sender can be replaced easier than a cracked oil line. |
Air in the line makes it look like your engine oil pressure comes up slowly. Especially if there's a restriction (orifice to limit oil loss) at the block. For a mechanical gauge, I'd want to see immediate response.
Incidentally I DO have a mechanical gauge but it's in the engine compartment. I can't see it while driving.
I'm interested to see it while driving but the focus of this $18 project was "a quick checkup".
See thread: DIY oil pressure test gauge
Someday I may add an (electric) sender and a gauge at the dash. _________________
....KTMs, GasGas, SPOT mtb |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23153 Location: Oklahoma City
Posted: Thu Jul 24, 2025 9:49 am Post subject: Re: mechanical oil pressure gauge help |
Sodo wrote: |
DanHoug wrote: |
Ahwahnee wrote: |
MarkWard wrote: |
Someday I may add an (electric) sender and a gauge at the dash. |
An interesting conversation!
Yes, you want no air in your oil pressure line. Those who say its fine and the same accuracy....let me know how that air in your brake system is working?
Not only does it compress and slow "response" as noted, over time that air breaks down into a portion of water which is bad for everything.
Must have a flex link at each end of a rigid line. If you want to use stainless braided/sheathed line...make sure you are not using a piece of brake hose (because you are cheap ).
Brake hoses are lined with EPDM which is eaten by oil and other hydrocarbons. Its a recipe for leaking between the layers and blowing out over time.
Nylon tubing is just fine ....just get the right nylon tubing. DO NOT use Nylon 6. Too much moisture absorption and it gets brittle. If you have the $ use PA46 (used on many aircraft) if you can find it. Its melt/flow point is ~560 F.
If that is too hard to find or expensive, use nylon 12 tubing. Its what they make high pressure air lines from.
You can buy very reliable pressure sending transducers. However, they are not "automotive cheap". They are aircraft expensive. Also as you note, in an airplane when failure is not an option, you put two sending units on one port or have two ports with one sending unit each. Ray |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10024 Location: Where?
Posted: Thu Jul 24, 2025 11:44 am Post subject: Re: mechanical oil pressure gauge help |
I ran a mechanical gauge in a daily driver Vanagon for 6 or 7 years. I just used the nylon tubing. The air should definitely be bled from the line. With the line full of air, the reaction time of the gauge is very slow. Even with the air bled, in very cold weather it would take a few seconds for the gauge to start working on cold starts. I have run electric gauges also, but the senders tend to fail very often, maybe from the vibration from diesel engines. |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2636 Location: Southeast Kentucky
Posted: Thu Jul 24, 2025 12:55 pm Post subject: Re: mechanical oil pressure gauge help |
I'm thinking the 1/8 inch refrigerant copper tube's ID is quite small. I have a roll of it and decided not to use it because of the small ID. Sixteen feet with the small diameter can affect pressure at the gauge and will definitely be slow to come up to pressure with air inside as others have indicated. But, bleeding out the air is by far of more concern for a quick accurate gauge reading.
Below are some comparisons I did using an old VDO Gauge made in Germany that's about 45 years old (the big gauge with 1 psi increments).
These pressures are using compressed air.
Below, the smaller gauge is an el cheapo made in China.
Below, same as above.
Below, is a comparison with a $50 digital.
I used the old VDO Gauge with the 1 PSI increments when working on VWs with the CIS Fuel Injection systems back in the day. It was accurate then and I assume it still is today. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Sodo Samba Member
Posted: Thu Jul 24, 2025 1:05 pm Post subject: Re: mechanical oil pressure gauge help |
raygreenwood wrote: |
Yes, you want no air in your oil pressure line. Those who say its fine and the same accuracy....let me know how that air in your brake system is working?  |
Significantly different systems.
Theres no ‘one pump operation’ in the oil pressure system - as in a hydraulic brake system.
An engine oil pressure gauge with air in the line will show full oil pressure while RPM is steady.
Like a damped electric gauge.
I would not prefer that, but its not a problem to be repaired like air in a brake line.
Vanagon fuel level gauge is electrically damped too.
Beetles had a cable-operated fuel gauge that would slosh with the fuel.
I enjoyed that. _________________
Posted: Thu Jul 24, 2025 1:39 pm Post subject: Re: mechanical oil pressure gauge help |
I've noticed the Westy's (2wd) fuel gauge goes up and down when I go up and down hills. This never happens with the Syncro. There's still some sloshing. I don't know how you prefer that, it makes me nervous. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
