m3456y Samba Member
Posted: Wed Aug 06, 2025 12:46 pm Post subject: Looking for a part… |
I installed an EMPI trigger shifter in a customers Brazilian 1984 bus and it would shift into reverse without using the lock out trigger. I tried re-adjusting several times, and decided to see what the shifter bushing looked like. It seems the part I need was replaced with a bolt causing slop in the shift arm. What do I need (part name) to replace the bolt as shown in the picture. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 43008 Location: at the beach in Northern Wokistan
Posted: Wed Aug 06, 2025 1:34 pm Post subject: Re: Looking for a part… |
you'll probably need to manufacture it. They are welded on prior bays. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4787 Location: Arizona Highways
Posted: Wed Aug 06, 2025 6:18 pm Post subject: Re: Looking for a part… |
i like the bolt.
3rd world engineering right there
these brazilian and mexican busses hide many such surprises.
for real though, get another bigger bolt and turn it down to the right size for the bushing. _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
m3456y Samba Member
Posted: Thu Aug 07, 2025 3:30 am Post subject: Re: Looking for a part… |
| borninabus wrote: |
i like the bolt.
for real though, get another bigger bolt and turn it down to the right size for the bushing. |
That’s exactly what I’m going to do. |
Everpress Samba Member
Joined: February 14, 2006 Posts: 433 Location: Augusta GA
Posted: Fri Aug 08, 2025 6:28 am Post subject: Re: Looking for a part… |
| m3456y wrote: |
| borninabus wrote: |
i like the bolt.
Let us know what size bolt you go with. I'm curious but I think this can also help for folks that have that part overly rusted/burred/broken. _________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
1969 Bay Camper - "Lost 'Cause Mk.I"
1904 DP
EMPI 34 PICT 3
2000 MAGNASPARK II Ignition/Distributor
Refurb, not resto (I’m not made of restoration money!)
It's not a perfect loaf, but it's my loaf. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53270 Location: Surrey B.C. Canada, but thinking of Ukraine
SGKent  Samba Member
Posted: Sun Aug 10, 2025 3:57 pm Post subject: Re: Looking for a part… |
too bad that is not a standard part. This issue comes up often enough someone could make 25 of those and sell them for $60 each shipped, = $1250 net which would cover setting up a system that automates parts like that. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24525 Location: NYC/Upstate/ROW
Posted: Sun Aug 10, 2025 5:18 pm Post subject: Re: Looking for a part… |
Buy a bolt from Belmetrics with the right OD and one third unthreaded, and double nut the side thst bolts up , lop the head of the bolt off. Done. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Sun Aug 10, 2025 6:20 pm Post subject: Re: Looking for a part… |
| Abscate wrote: |
| ......double nut .... |
It'll take a mighty thin nut if you intend to use reverse, second and fourth. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
