esde Samba Member
Joined: October 20, 2007 Posts: 6360 Location: central rust belt
Posted: Sun Aug 10, 2025 9:55 am Post subject: generator rebuild puzzle, and parts interchange... |
I am in the midst of rebuilding a thin slot generator for my 56 vert
page 6 here: https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=100
to summarize my issue.. the armature tests good. The field windings appear good, though I have not found a way to check the specific resistance. I have continuity where I'm supposed to and I'm not shorted (far as I can tell)
My completed unit will not spin when I attempt to polarize it, so I am going back through it. My first shot will be to swap a different cleaned and machined armature in. If that fails I will swap in a different set of field windings.. and here is the puzzle.Generally I'm pretty good at electrical work and rebuilding, but this is beyond my understanding, so I'm hoping someone with more knowledge can help I have many 180 watt generators to harvest parts from, but no more 160 watt thin slot generators. Could I use the field winding from a 180 watt unit? Or would I have to use the 180 watt armature also? I appears that the later 180 parts will swap straight in to the early 160 watt housing, but then I suppose I would need to use a later regulator.. and the whole reason I'm rebuilding this is to get the correct period parts on my 56. A quick search through parts numbers only shows one number for the field windings, so I'm just not sure what to do..
Any insight is much appreciated.
SD _________________ modok wrote:
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11253 Location: Huntington Beach, CA
Posted: Sun Aug 10, 2025 11:20 am Post subject: Re: generator rebuild puzzle, and parts interchange... |
What tests did you perform on the fields and the armature?
Try this out. These tests were what I was taught.
Have a fire extinguisher close by. I had a generator with bad fields catch on fire one time!
Good luck! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
scottalford Samba Member
Joined: August 13, 2011 Posts: 334 Location: Orange, Australia
Posted: Sun Aug 10, 2025 1:54 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
I'm in the middle of the same restoration with my 56 thin slot generator now in parts on the bench. I took a heap of photos of how the windings go in as I was concerned about putting everything back together.
The two pole shoes are different from each other, are they back in their original positions?
Are the windings wired so that current flows clockwise in one and anti-clockwise in the other to get a north and south pole? _________________ I hate rust!
1959 driver with original 36er
1959 vert in rustortation http://www.thesamba.com/vw/forum/viewtopic.php?t=525582&highlight=
1954 oval just waiting |
esde Samba Member
Posted: Mon Aug 11, 2025 12:55 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
field coil resistance was the same for both coils, about 1.7-1.8
Armature wasn't shorted to the shaft, but you can't test the individual sections without a growler..
I swapped the armature for a spare and it's changed things.. but doesn't want to spin under power. I need to try with a battery and not off my charger maybe.
esde Samba Member
Posted: Wed Aug 13, 2025 4:40 am Post subject: Re: generator rebuild puzzle, and parts interchange... |
So, the only reason I'm doing this is that I have a dozen later 180 watt 90mm generators, and just two 160 watt thin slot generators. And both of the thin slot generators have had a rough life and need everything..
So let's see if I can rebuild 180watt parts into a thin slot case.
Sometimes these things don't want to come apart. Whatever you do, DO NOT HIT THE SHAFT WITH A HAMMER. Use a puller
compare armatures, 160 to 180
dimensionally they are the same, except the 180w has slightly longer magnets.
The shaft is a little chewed up where one bearing was seized. Hopefully I can clean it up
The 180w field coils appear to be a little longer, but it is like measuring a football inside a bucket. Need to get them removed to really see what's different from the 160w coils.
Brush holders are almost identical
Fan end bearing cap is different, I'll see which seems best and decide
My mega ghetto armature surfacing lathe. This is not found in the machinists handbook.
But hey, any port in a storm right?
I cleaned and revarnished the windings, and will finish cleaning it up after that dries.
Posted: Wed Aug 13, 2025 1:57 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
Man, dude! A drill press would have been better, but I do enjoy seeing the creativity! I once laid a drill press on its side to turn a set of Queen Anne legs I was creating!
What is the red application stuff? Rebuilding these is not my area of knowledge. Been way too long! _________________ Jimbo
TDCTDI wrote: |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36025 Location: Conejo Valley, CA
Posted: Wed Aug 13, 2025 2:33 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
Undercut the insulation after turning.
_________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
esde Samba Member
Posted: Wed Aug 13, 2025 4:32 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
VW_Jimbo wrote: |
What is the red application stuff? Rebuilding these is not my area of knowledge. Been way too long! |
I know, I know. And I have a lathe but the 4 jaw chuck is stuck on and it's 20 miles away.... so here I am hacking through it like my shade tree forefathers.
The red is insulating varnish
https://www.amazon.com/MG-Chemicals-4228A-55ML-Ins...9&th=1
KTPhil wrote: |
ABSOLUTELY!
I have a thin kerf mini saw that I use, and need to upend a few drawers till I find it. My son loves to borrow all the little tools, cause he feels that they are "his size" for a reason.
Posted: Wed Aug 13, 2025 5:10 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
The hack saw blades works the best. Put an angle on the business end, like a 30 degree angle. Makes it dig in just the right amount! _________________ Jimbo
TDCTDI wrote: |
esde Samba Member
Posted: Wed Aug 13, 2025 6:55 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
ONWARD:
field coils removed
The pole shoes are the same.
The coil insulation is in good shape so I am leaving it. If I removed it, I could count the windings and take better measurements to see if they differ from the early 160 watt field coils. But it's an abstract shape and hard to measure..
Proof of concept, they fit!
The later case has a step cut end for the bearing cap to sit in, and the bearing cap has a corresponding step. SO early cases get an early rear bearing cap and so on..
more later
esde Samba Member
Posted: Mon Aug 18, 2025 6:14 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
so I didn't unwrap the field coils, but I did replace the positive and field leads, and then used a ring terminal to secure the hot lead to the brush connection. Normally the brush connection is staked to the case with a peened over stud, I removed it and used a bolt with the original insulating bushings
Put the correct early bearing caps on with new 6202 bearings
Soldered on new flag terminal ends and reinstalled the nicest regulator I have
It testes and polarized well, I'll wait to install it till the winter break.. _________________ modok wrote:
Posted: Tue Aug 19, 2025 1:43 pm Post subject: Re: generator rebuild puzzle, and parts interchange... |
Great to hear, and also great to know that we can use the 180w armatures in the thin slot generators. _________________ I hate rust!
